Question about Epson Office Equipment & Supplies
Epson TX100 , Have replaced cartridges, orange ink light stays on socstantly, not flashing but does not print
jacklee366
  • 541 Answers
SOURCE: Epson 2200 ink replacement light stays on
this means that your printer wast pad is full this now you reset your printer but make sure you have put new pads in 1st
  1. Turn off the printer power and unplug the power cord from the wall. Disconnect the computer interface cable at the back of the printer.
  2. After one minute reattach the power plug to the wall, but don’t reattach the computer cable.
  3. Hold down the ROLL and the PAPER ADVANCE buttons simultaneously.
  4. Turn the printer on. after 2 blinks, all the ink lights come on, then release the buttons being held down.
  5. Press and hold the ROLL button for 10 seconds.
  6. Release the ROLL button and the printer will initialize, which resets the Waste Ink Pad Counter.
  7. Once initialization is complete, turn the printer power off.
  8. Reconnect the interface cable.
  9. Turn the printer on and print a document.
Posted on Dec 04, 2008
SOURCE: Epson Stylus CX7400 Ink Light Problem
You need to open up the maintenance window and go thru the motions that you are changing the cartridges and this resets the ink levels back to full and sends data to the printer saying that they are full and the ink light disappears and it prints fine !!!
Just changing them doesn't seem to do the trick like on a lot of printers
Posted on May 15, 2009
aicaxz
  • 511 Answers
SOURCE: EPSON tx100 refuses to print - ink light on
ink light on? Check status monitor. Usually after jammed paper, printer trouble to recognized ink. Do change ink tank procedure, unplug and plug again ink tank.
Posted on Jun 13, 2009
  • 5 Answers
SOURCE: Epson Tx100 does not recognize my ink!
there is a chip re-setter located just above the cartridges. it is actually a small button switch. if that does not work, try to remove the cartridges. just lift them (1 by 1) slightly then put it back again
Posted on Aug 21, 2009
cns assoc
  • 677 Answers
SOURCE: Epson TX100 won't recognise ink cartridges.
Yes, Genuine Ink Cartridges.
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 05, 2010
Testimonial: "Thanks for your help. I have started using generic cartridges as I did with my Canon for years. Your help is much appreciated."
Print head doesn;t move at all in epson stylus tx100
Anon, epson stylus tx100 print head doesn't move when turned on.
epson printer problems
Feb 08, 2014 | Epson TX100 Series
How do i install new cartridges into my tx printer first time user never changed before
With the printer on but not busy (flashing light), open the scanner unit. (Lift the scanner until the bracket on the right locks.)
If the cartridges are completely expended:
Press the Stop button on the printer, the print head should move to line the expended cartridge with the empty ink mark. Press Stop again and the next empty cartridge should line up with the mark. Continue to press Stop until the print head moves to the cartridge replacement location (after noting which cartridges need to be replaced).
One cartridge at a time, shake the new cartridge 5 times before opening the package.
Remove the new cartridge from the packaging and remove the yellow tape from the cartridge. Be careful not to damage the hooks on the side of the cartridge and do not touch the green IC chip. Leave the transparent seal in place.
Squeeze the tab at the back of the cartridge you want to replace and then lift the cartridge up. Then put the new cartridge straight into that slot and press down until it clicks.
Repeat this for all empty cartridges. Then close the scanner unit and press Stop. Wait until the light stops flashing and the empty ink error light goes out. The unit will charge the ink system while the light is flashing.
If the empty ink remains flashing or is on with the print head in the home position, then a cartridge may not be properly inserted. Press Stop and then push down on the cartridges. See http://support2.epson.net/manuals/english/spc/stylustx100tx101/guide/html/ink_4.htm for pictures and images.
If the ink isn't expended, use the Ink Replacement utility in the Epson software. For Windows, this is part of Printing Preferences in the Maintenance tab. Open the Devices and Printers (slightly different name in older versions of Windows) control panel. Then right click on the printer and choose Printing Preferences.
I hope this helps.
Dec 04, 2010 | Epson TX100 Series
I've just replaced the black ink cartridge for my Epson Stylus TX100, ink level is ok as the indicator shows. But i get blank prints for black, other colors are fine. What's wrong with the black ink...
There is nothing wrong with the black ink. Just run the head cleaning for better printing.
1. Go to printer and faxes
2. Right click your printer ( Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet)
3. Click printing preferences
4. Click Maintenance Tab
5. Click Head Cleaning
6. Run head cleaning for 5 times then try printing.
Nov 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Printer does not go
After few head cleaning, ink counter running low, so ink ligh (red) flashing. Then ink counter runing out, so the light stayed on. After replacing both of ink, red light stayed on, because the compatible ink (chip) not recognized by printer. Check epson status monitor. Use original ink or refill and reset ink level counter.
May 26, 2010 | Epson Stylus C60 InkJet Printer
I don't know how to change the ink cartridge of epson tx 110
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
SEE IMAGE BELOW
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Mar 21, 2010 | Epson Office Equipment & Supplies
There's a general problem to my Epson TX100. the two orange light is blinking. What should I do? Do I have to reset my printer? What software should I use?
You have to reset your printer. Go to this link to download the program.
http://www.ngedownload.com/epson-tx100-resetter-wast-ink-pad-full.htm
NOTE: you have to replace the waste ink pad inside your printer to prevent flooding of waste ink.
Jan 19, 2010 | Epson Stylus NX400 InkJet Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Aug 13, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Jun 13, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Replace ink cartridge on Epon Stylus DX6050
Power on the printer and open its cover. The print cartridge carrier comes and stays at the centre with its orange light flashing. Simply remove the particular cartridge and replace with the other. Good luck
Jun 03, 2009 | Epson Stylus DX6050 All-In-One InkJet...
226 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
