Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Proper temp. range in freezer
I would like to know the proper temp. range in a frost free
upright freezer. My freezer varies from 0 degrees to 20
degrees. The Freezer control is set at 4.
  • 3 more comments
  • David Glen Harris Oct 28, 2008
    Thanks Mike, that confirmed my thoughts.
  • Anonymous Jan 18, 2009
    proper
  • David Glen Harris Jun 30, 2009
    Even with new defrost thermostat and defrost timer, the temperature stays between 24 and 28 degrees.
  • David Glen Harris Jul 14, 2010
    I have changed the defrost thermostat. The feezer worked
    for a few weeks. After it stopped cooling again, I changed
    the thermostat timer. It would have times that the temp.
    would be in the teens, but not consistant. The fan is running, but I'm not sure about the compressor.
  • Anonymous Mar 13, 2014
    IT IS MAKING A VERY LOUD ALARM SOUND! IT HAS A THREE WAY SWITCH IN THE INSIDE, BUT KNOW WHAT THIS IS FOR
  • 172 Answers
Hi dgh1,
The freezer should stay within 5 degrees of 0 while in operation. While in defrost the freezer may reach as high as 20 to 25 degrees. If any higher temperatures are reached your food will spoil as they are defrosted and refroze everyday. If you find that the temperature is allowing your food to defrost you may want to replace your defrost thermostat. This device is located on top of the evaperator coil inside the back of the freezer. It is made to turn the heater off when a temperature of 55 degrees is reached. One other possible problem could be your defrost timer is taking to long to restart the cooling cycle after defrosting. I hope this will help you and please send any other questions you may have, I am happy to help. and dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Posted on Oct 28, 2008
Have upright frost free freezer alarm is going off about once or twice a day.Put a thermometer it is around 20 degrees I mute the al;arm and it beeps again and again after several hours. looked to clean...
Hi most deep freezers operate at 0 dergrees. your model may have 2 temp zones. 0 or 20 deg.I'm gessind that your sensor is going off when the defroster is on to melt ice (defrosting). Lower the setting. monitor and repeat as needed. if it continues you may need to replace the unit or ad freon. If the unit is over 13 years ge a new one.
Jul 21, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire freezer LFFH21F7HWG. the temp gauge outside registers only 0. I have 3 thermometers inside all register 18 degrees. ice cream is soft in the box. machine was delivered last Tuesday. the freezer...
these freezer are designed to run about 70 percent of the time the temp displayed can vary by +/- 3 degrees..make sure you have fan operation in the freezer and the air flow is not blocked or restricted. also make sure that the door is sealing properly
Aug 31, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
In addition to the popping noise/coils are froze with orignal
turns out the coils were not defrosting or at best working intermittently. I defrosted the coils and ordered a defrost timer the old timer continued to pop from intermittently.I replaced the defrost timer
and it quit popping and noew the freezer works fine temps range between 9 degrees F and
14 degrees f.
Jan 19, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Not cold enough?
is this a chest freezer or upright frost free fridge freezer . nead more info
Oct 19, 2008 | Freezers
Freezers Logo
614 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
