Question about HP Computers & Internet
THIS HP PC WAS NEW IN MAY 08 - IT HAS ALWAYS HAD A SETTING IT IT SOMEWHERE THAT CAUSES THE SYSTEM TO LOSE 2 HOURS ON BOTH CLOCKS, EVERY SATURDAY. I HAVE SENT AT LEAST 10 MESSAGES TO YOUR COMPANY - NONE OF WHICH HAVE BEEN ACKNOWLEDGED. I WANT AN ANSWER AS TO WHY THIS IS A VISTA MODEL A6303.W WHY AM I BEING IGNORED? HOWARD.
  • Andy Bathgate
    Andy Bathgate May 11, 2010
    hi howard
    which company is ignoring you ? Hewlett Packard or are you referring to Fixya?
  • 149 Answers
Your time zone is wrong on the computer if you double click on the clock it should give you the option to change the time zone
Posted on Oct 28, 2008
Trouble with precisetime atomic wall clock several hours behind
Check the time zone setting for your local time zone. If you are Eastern Time Zone but setting is for Pacific Time Zone, then the difference will be several hours. Check your manual for proper setting.
Mar 02, 2015 | Home
Setting tochigi tokei co quartz westminister chime
the 2 hour buttons and 2 minute buttons represent a 24 hour clock ie 2:55 is 1452 hours so press first hour button onces the second hour button 4 times then the first minute button 5 times then the second minute button 2 times
Nov 25, 2012 | Seiko Mantel Clock
How do you manually reset a Lacrosse Atomic Clock. Ours is always 4 hours behind and has not caught up. We already changed the batteries.
There are many LaCrosse atomic clocks. Which model do you have? Support for most is available here: http://www.lacrossetechnology.com/support/home.php . Use the drop down menu to select the model.
For the analog clocks, there is a manual set button on the back of the clock. Press the button and wait for the clock to advance to the correct time. Then make sure the correct time zone button has been pushed. Then make sure the clock is in a location where it can hear the signal overnight. (For best results stand the clock upright in a window.)
For WT-2165U travel alarm, press and hold Set to enter the setting function. Then select the time zone (with + or -) then press and release Set. Set the DST setting to on or off as needed, then press and release Set again. The next setting option is the snooze alarm duration. Press and release Set again to change the hour manually (+ to increase). Press and release Set again to set the Minutes. Correct the date (year, month, day, day of week) similarly. Then set the display to 12 or 24 hour time. Press and release Set to finish and exit the set functions.
For some of the digital clocks you can set the time manually by pressing and holding Set. First set the time display mode (12/24), then press and release Set again. Then set the hours, followed by Set and then the minutes. Continue through other menu options or just do not press any buttons for several (30) seconds.
On the digital clocks, the item being changed will flash.
To avoid interference with the signal reception, place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal.
I hope this helps.
Feb 03, 2011 | La Crosse Radio Controlled Atomic Clock
I purchased my tx1019au new June,07. Global guaranty costing US$350. p/yr Jan, 08 WLAN card failed, HP Service center first declined to honor warranty telling me to mail it to the country of purchase....
The NVIDIA GPU (Graphics Processing Unit), located at U20, sharing the heatpipe heatsink with the main processor, has an issue with the reflow soldering to the motherboard.
If you can find a good PC board shop that mounts BGAs (Ball Grid Array parts, have them resolder the part to the motherboard.
Quanta Computers, of Taiwan, built the boards originally. (http://www.quantatw.com/Quanta/english/service/serviceinfo.aspx) They sell new MBs for $400. If you can get the NVIDIA part reflowed, it will probably cost less and work better.
The heat of operation causes the part to lift from the motherboard, causing separation of the solder joints, and intermittancy, or a complete failure with increased temperature - these parts are designed to run pretty hot.
Good luck.
Aug 15, 2010 | HP Pavilion tx1000z Notebook
HP Pavillion laptop sleeping
There is another setting in the power options and it is above the sleep settings. It has to do with closing the lid. Click on that listing and choose "Do Nothing" as the choice, hit apply and ok. I do not believe there are any settings in the bios that deal with the sleeping of the system or components.
Nov 24, 2009 | HP Pavilion dv2500t Notebook
Setting time zone
found manual--
Remove from email listing and send no further communiques.
Oct 31, 2009 | SkyScan 86709 Atomic Wall Clock
Have installed a 1/2 HP wayne jet pump, getting water ,
If we go down the list of possible causes, it may help;
  • All fitting on the new pump and jet are tight.
  • No break in the well line
  • FOOT valve operating OK. If the foot valve is not operating correctly, the pump can lose its prime and **** air into the system.
  • New pump has been purged of air(primed adequately)
  • holding tank has appropriate pre charge
  • bladder in holding tank not ruptured.
Jun 20, 2009 | Plumbing
Disk space problem in hp dv6000 series
Hi
Probably ur system is infected by a rootkit.Search on the net for antiviruses that find out rootkits in the system. Avg 8.0 or Panda 08 can detect rootkits also.
B4 that just deactivate system restore and see whether this solves ur problem.
I had this problem once and this was due to rootkits, but i hav seen sum systems where its due to system restore.
Jun 09, 2008 | HP Pavilion dv6000z Notebook
Radio controlled clock won't set
it sounds like its working but its setting daylight savings time mine has an option to turnoff .that's makes scents if it always 1 hour off exactly.
Feb 15, 2008 | La Crosse Radio Controlled Atomic Clock
Netgear FR114P Time Checks
Most likely the router if you have the option turned on. Look at Schedule section of the configuration. Another possibility is Windows XP clients, assuming your clients are XP. The default installation has XP checking its time against time.nist.gov. Check the clock setting for this.
Feb 19, 2006 | NetGear FR114P Router
Computers & Internet Logo
49 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
