Question about Kenmore Refrigerators
Kenmore Elite Model 596.73503201 Cooling Issues. The refrigerator and Freezer have stopped cooling. About a year ago I replaced the Overload Switch Relay but reused the capacitor. It is now doing the same thing as before. Ordered a new overload Switch relay. Replaced it. Now the comperssor will click, buss for 5-8 seconds click again and run for 2:1 minutes and repeat. What do you think the issue could be?
  • 1462 Answers
SOURCE: Refrigerator not cooling.
compressor has failed. not a diy job
Posted on Apr 25, 2007
  • 66 Answers
SOURCE: The starter/overload and overload protector
The easiest way to find this out , is to check the condenser. Make sure that the condenser is not clogged up with dust and that the condenser fan is working. Replace the start relay. Turn it back on. If it starts right up then it probably overheated and melted the relay due to the condenser fan not working or the condenser clogged with dust. Air circulation through the condenser and air being circulated over the compressor in how it cools itself. If the compressor will not start or if it runs for a little while and then shuts off from overheating, then you have a bad compressor.
Posted on Nov 12, 2008
peyton32034
  • 410 Answers
SOURCE: frig and freezer not cooling
it is possible that a start relay has gone bad but more likely is that the compressor has seized up. if the unit is under 5 years old most likely the comp will be under warranty from sears. peyton
Posted on Jan 20, 2009
carldc3
  • 82 Answers
SOURCE: I NED TO CONECT 3-1 RELAY OVERLOAD CAPACITOR IN MI FRIDGE
first take all the relays and capacitor off of compressor , then attach black wire with terminal on "C" terminal post usually top terminal, white wire with terminal goes on "S" terminal post on compressor, red wire with terminal goes on "R" terminal post on compressor. then take the two black wires one connects to white neutral wire and the other connects to the black power wire if tis fridge has a condensor fan then you will also need to connect it two the two black wires also thanks hope this helps
Posted on Jan 23, 2009
peyton32034
  • 410 Answers
SOURCE: replacing overload relay/capacitor on compressor of maytag fridge
replacing a start relay is very easy to do. usually its a swap the part wire for wire operation. in some cases you get a different looking relay but they normally have good instructions for the replacement part. if you'll post the model numebr fo your unit i can give you detailed instructions. thanks peyton
Posted on Mar 16, 2009
Freezer fine but fridge warm
The fan seems to be out looks like you need a new fan motor for freezer component
Nov 14, 2013 | GE PDS22SIS Bottom Freezer Refrigerator
Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite bottom freezer making a clickbuzzzzzzclick sound
you need to check to see if you have a control board by compressor.if not change relay and overload to compressor if you have a grey box with a board in it then you need to most likely change it
Mar 14, 2009 | Refrigerators
Frig and freezer not cooling
Jan 19, 2009 | Kenmore 73503 Stainless Steel Bottom...
KENMORE ELITE REFRIGERATOR MODLE #106.53606201
Compressor is cycling on the overload protector. If refrigerator is over five years old the warranty may be expired. I which case I never recommend replacing the compressor if the customer is to bear the full expense.
Jul 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Warm refrigerator/freezer
very good chance it is the same problem or possibly a leak of refrigerant due to joint failing where compressor is joined to pipework
Jun 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
47 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
