Question about Hotpoint TDL15 Electric Dryer
Hotpoint dlb1550 squeeks extremely loud. Otherwise works fine
  • Anonymous Mar 30, 2014
    squeeks loud
  • 67 Answers
The squeaking that you hear is probably the belt slipping. it needs to be replaced. they are easy to find on the internet, just search by your model number of dryer and search for parts. if you need directions on how to change it, let me know
Posted on Oct 28, 2008
My hotpoint washing machine WF620, squeeks when it is washing and spinning
On most hotpoint wash machines you cant replace or grease the bearing you have to replace the whole drum which cost around 100 pounds from hotpoint and a couple of hours labour its a common problem on hotpoint machines.
hope this helps.
Jan 07, 2014 | Hotpoint Aquarius WD63 Front Load...
Loud squeeking sound while operating
Possible slipping belt. Probably time to replace it (The belt).
Apr 23, 2010 | Hotpoint NVL333EY Electric Dryer
Very noisy when Hotpoint Aquarius WMA46 is on spin
It is the main drum bearings that is causing the noise.
There is no provision made for lubrication.
It can be done as a DIY fix, but it is a very involved repair, as it means having to remove the whole inner workings of the washer,
Not a task I would recommend unless you know what you are doing, and feel competent to tackle it.
Good luck.
Dec 05, 2009 | Hotpoint Washing Machines
On the final spin the washing machine is so loud you cant even be in the same room as it, it is not vibrating externally as far as i can tell
Remove rear access panel, and remove the drive belt.
Spin drum by hand, and if it feels rough or noisy, then the main drum bearings have failed, if no noise, then check motor for noise, if no noise, check the concrete wieghts are not loose, and that the dampers are not broken or worn.
Please rate my solution.
Nov 07, 2009 | Hotpoint Aquarius WD640 Front Load...
Hi,i have a hotpoint aquarius wf340.which makes a very loud banging noise every time it spins,it works fine otherwise!
I had the same issue with a similar machine. Need to replace the spindle assembly (or otherwise make sure) that the belt is tight. Try replacing belt first.
Make sure machine is level. test it by putting some stuffed sockes in the machine, let them get thrown around. Listen for the banging noise, apart from the soft socks hitting the tumbler.
Aug 08, 2009 | Hotpoint Washing Machines
Hotpoint Over the Range Microwave is LOUD
It is very likely that the motor that spins the plate is wearing out. You can find a replacement on ebay and many other sites.
Jun 06, 2009 | Hotpoint Microwave Ovens
Squeeky agitation (loud)
there are 4 rods that the tub hangs from. the plastic pieces at the top of the rods are supposed to wear in, but many of them continue to squeak. had the same problem with mine for the last 4 years. in year 1, the GE repair guy said this is common and showed where to lubricate. open the front panel (stick a screwdriver or stiff butter knife to depress the 2 clips.) you'll see the rods. (altho the back ones are kind of hidden). a quick spray of silicon will quiet the squeak. usually lasts about a year.
Apr 24, 2009 | GE WJRR4170E Top Load Washer
How to replace drum bearing for hotpoint aquarius+ wf740
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
How to replace a Hotpoint Aquarius+ WF740 drum bearing?
I had the same problem and it turned out to be the ballast securing bolts had sheared off and the back of the drum had to be replaced
Kenmore Elite model: 22932
Washing machine works fine UNTIL spin cycle. Loud engaging sound and then it makes a squeek, squeek sound...not really a squeek, but if you were to listen to it, eee, eee, eee, eee, eee and loud.
Dec 10, 2007 | Washing Machines
Hotpoint TDL15 Electric Dryer Logo
326 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
