Question about Toshiba DVR620 DVD Recorder/VCR
New Toshiba DVR620KU Cannot figure how to record from tv with cablebox hookup
The cablebox is comcast box RNG150N, I have my tv and dvd/vcr combo hooked with HMDI cables and can view recorded vcrs and dvds but cannot figure how to record from tv and program with either vhs tapes or dvd blanks. The manuel states I need an external device to be able to record. Any advice or what type of device is needed and how to connect devices to work together would be appreciated.
4 Suggested Answers
  • 6 Answers
SOURCE: recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Posted on Jan 27, 2009
SOURCE: Toshiba DVR620KU error E 25 cannot put VHS onto DVDs
Probably copy protection.
You can remove it with a Grex or similar
device.
Posted on Jan 22, 2010
  • 104 Answers
SOURCE: Can DVR620KU play" PAL" DVDs
yes some do. Just have to change to the region that you prefer. Europe would come under region 1 and pacific-Region 4 and so on.
Thanks
G.
Posted on Jun 28, 2011
I have a Toshiba DVR620ku DVD/VCR combo. I have the Format Mode properly set to "Video mode." I put in a new, unformatted DVD-R, and the player should format the DVD, but it doesn't. I click...
My brother had the same problem. Toshiba tech support said the disc was already formatted, so the DVD MENU option would not be available. He went straight to dubbing and recorded to the disc. After recording, the DVD MENU option was then available. He thought the disc was not formatted since it was straight out of the package and he always had to format other new discs. Perhaps your disc was actually already formatted?
Oct 27, 2010 | Toshiba DVR620 DVD Recorder/VCR
device.
Jan 08, 2010 | Toshiba DVR620 DVD Recorder/VCR
I have a DVD1001 DVD VCR combo how do I hook DVD combo to my tv
Use output of combo player to input of TV. Use what ever available input you have left on you TV. HDMI or Component input is best, but others will work.
Dec 30, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Vcr/dvd combo recording problems
You can use a normal set top box, plugged into the AV inputs on the combo, you could even use a seperate VCR for this, as long as it's recieving the signal you want to record.
Apr 21, 2009 | Toshiba SD-V295
Recording with comcast hd box and toshiba VCR/DVD
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
Jun 07, 2008 | Toshiba Televison & Video
HOW to hookup,connect, dvr cablebox to DVD,VCR Recorder(Panascnic)threw HomeTheater ?
Connect cablebox output video cable to DVD recorder input. Connect Audio cable to Home theater. Connect DVD Recorder output to TV.
Hope this helps!
May 02, 2008 | Televison & Video
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Feb 08, 2007 | Sylvania (SRDD495) DVD Player/VCR
Toshiba DVR620 DVD Recorder/VCR Logo
201 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
