Question about Pioneer SX-315
Pioneer sx-316 no sound from optical input
Everything works except trying to run from panasonic viera tv to the optical input and can't get it to work. Tried turning off tv speakers... and nothing.
5 Suggested Answers
SOURCE: how do i reset my
1. Switch the reciever into standby.
2. While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3. When you see RESET? appear in the display, press the ENTER button. OK shows in the display.
4. Press SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default settings.
Posted on Sep 09, 2008
  • 4234 Answers
SOURCE: no sound from speakers?
This is likely to be th output relay having corroded contacts. The headphone output is taken directly from the sepaker output but fed through resistors. The output relay has failed.
Dan
Posted on Mar 09, 2009
dunnbiker
  • 8546 Answers
SOURCE: I was using my vsx D510 with a hiteker dvd player
Each digital input is assigned a name and a function by you. You have to dig out the manual and assign the digital inputs.
My $.02. Why do you not want to use the coaxial imputs? There is no functional superiority of one over the other BUT coaxial is a) cheap, since it uses standard RCA cables; b) adaptable, since you can splice or split them among two devices; c) not delicate or prone to failure due to tight bends. I share one coaxial input between two digital device with an RCA splitter cable. Just have to make sure to turn the one I'm not using OFF. Try that with optical.
Posted on Jan 19, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a Pioneer Audio Multi Channel Receiver
DVD audio straight in from its highest quality audio output. Use the stereo audio output to run straight to the TV for casual watching through TV speakers without the Pioneer involved.
A TV is just a glorified night-light, not a sound source - get its related audio from the Cable Box, ditto the highest quality
Posted on Mar 04, 2010
I have a 42 inch Panasonic viera comes on sound is there everything works except picture. Sometimes I have lines of color flash on the screen what's going on.
Replace the video cable and make sure your video input is matched properly with the audio (audio on input 1/video on input 1) or whatever input you are using.
Feb 25, 2015 | Panasonic Televison & Video
How do I hook up a powered subwoofer to a pioneer sx-316?
Many subwoofers accept both line level (RCA jacks) and amplified inputs (+ and - speaker terminals). The Pioneer SX-316 does not offer line level output, only amplified outputs via the PURPLE + and - speaker terminals. This means that in order to use any subwoofer with an SX-316, the sub woofer will need to accept a + and - speaker wire connections for input Your manual speaker connections are on page 11 of the manual which can be found here: http://www.manualslib.com/manual/260358/Pioneer-Sx-316-S.html#manual
Starting at the rear of the SX-316; run a speaker wire from the PURPLE + and - terminal (SUBWOOFER) to the + and - speaker input terminals on the subwoofer. See your subwoofer manual or experiment (at your own risk) with connecting the speaker wire from the SX-316 to the subwoofer's + and - LEFT only, RIGHT only or BOTH left and right speaker inputs. Do not connect wires from the SX-316 to the speaker OUTPUT terminals of your subwoofer.
Finally, adjust any variable low pass filter knob or setting on the subwoofer to the lowest frequency that your main speakers are capable of producing. If you're not sure what that value is, try setting the subwoofer to 100Hz and judge how it blends with the main speakers. If it seems a little too bass heavy and thick then reduce the setting to 80Hz. On the other hand, if the sound seems to be slightly thin and lacking weight, try increasing the setting to 120Hz. By careful listening and a bit of patience you will be able to get the sound to seem balanced and well blended.
Apr 06, 2014 | Audio Players & Recorders
No sound output from turntable on sx-780 receiver
do you have in connected to a phono input? be sure you haven't connected it to another input..........turntables are low-level (20ma) output, cannoit drive high-level input (200ma).........good success, meder's tv service
Dec 18, 2012 | Pioneer Sx 780 Stereo Receiver
How to connect a panasonic tcp50gt25 tv audio out (opictal) to a pioneer amp.with opitcal. i connect the cable but no sound,any idea for setting,i did the setting for optical on the amp but still no sound
What is the source? if you are using an HDMI connection from an HD source you should have digital audio. also, if you are connecting digital cable directly to the TV it will send digital audio out as well. check the optical cable at the amp end to see if it is working. it should glow red at the tip if it is.
there are digital input mode settings as well on some receivers. if it is set to DTS it won't work on PCM audio. if it is set to auto Digital it should work on any standard. check the PCM or DTS options in both the TV, and receiver if those settings are there.
Mar 12, 2011 | Panasonic VIERA TC-P54Z1 54 in. Plasma TV
I have a new Panosonic Viera TC-P54VT25. Everything seems to work well except for the sound on the Viera Cast. Viera Cast is connected through a hard wire ethernet connection directly into the TV. ...
I have had my Panasonic Plasma tv for 5 months there was a loud pop and the tv went off and now there is a red light blinking 10 times and the tv will not turn on.
Jun 15, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
I have a Pioneer Audio Multi Channel Receiver model SX-316-S and I can't seem to figure out how to hook up my TV and DVD to the receiver so that all sound comes through the receiver
Mar 04, 2010 | Pioneer SX-315
Auxilliary audio connection
I don't expect a 2 channel amp would have a digital input such as optical. More likely you would be able to pull analog stereo (red and white RCAs) off the Panasonic and run to the JVC.
Dec 29, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Distorted sound coming out of SW channel only
try turnind down the sub from the amp itself it might be putting out more volts than the subs input can handle check your standing wave feature to make sure the trim is not up too high
Jan 13, 2008 | Pioneer SX-315
Pioneer SX-315 Logo
458 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
