Question about Kitchen Ranges
Wolf oven cavity replacement
What is involved to replace the large oven cavity?
2 Suggested Answers
  • 30 Answers
SOURCE: Oven won't heat past 150 degrees.
you either have a bad bake element or control. also check wiring between
Posted on Mar 27, 2010
Wolf MWC24 turns on and spins. Does not heat on microwave or convection. Any ideas?
The Wolf DCM24 is a rebranded Sharp, similar to the Sharp model R-930AK, etc.
The Sharp version service manual is here, and while cosmetic parts won't interchange, internal ones will.
The problem you have is usually caused by a bad bottom door switch, or that switch's mount may be loose, misaligned, or broken.
See my help info on door switches here and here.
Once you look all this over, if you have other questions, please feel free to contact me by e-mail here.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 15, 2017 | Microwave Ovens
Sparks inside a wolf mw24 inside in right wall cover plate
The right side wall cover plate is the "waveguide cover."
It protects the waveguide and the magnetron at the other end from moisture, grease, and food particles.
If these remain stuck to the waveguide cover, arcing can occur, which will damage and / or destroy the cover, the waveguide or even the magnetron or the oven chassis.
As with most problems, this should be addressed sooner rather than later or it will only get worse, and may become unrepairable.
The similar Sharp model R-530E-series service manuals are here and here. They will help with disassembly, but the external / cosmetic parts will not interchange.
The Wolf waveguide number is 801798 and Wolf part ordering information is here.
The oven cavity and waveguide must be clean and if any spot is scorched or chipped, it must be sanded smooth, cleaned and dried, then touched up with appliance paint, available from local big box stores, home centers, appliance parts stores, and hardware stores.
Leave the door open overnight to dry the paint. Then install the new waveguide cover.
If the chassis or waveguide have holes in them, the oven must be scrapped and replaced.
For more free DIY and other help & advice, feel free to contact me via my site.
Dec 05, 2016 | In Microwave Ovens
I need to replace my 1987 approx. Chef wall oven Balmain fan forced and grill. Does anyone know the cut out dimensions. I want to buy anew oven that will fit the existing opening. Thanks
when you buy the ovens replacement
instructions are given in the paper work how to adjust the cavity to suit
there will have to be an air gap on back and sides of the new oven
you should call an electrician to wire in the new oven
to check , even replace the 1987 wiring and connections
if needed to meet the 2016 house wiring standards
you will need
tape measure
pencils
a square
straight edge
reversible hand drill and bits
two levels .... for inside the cavity to level oven
approx a 15 inch .one 6 inch
a hand saw or circular saw
, i found a jigsaw helpful
self tapping screws different lengths
as per the oven fitting requirements
you can use any paint to finish the job
white board or MDF board is ok
some extras strips of timber to level the new oven
maybe required
if imperial was used for the cavity of the old oven
metric might be for the new oven
some DIY about wall oven installs are found on youtube
Oct 14, 2016 | Ovens
Hi my oven suddenly started making loud weird noises and now does not heat any food. I smell smoke. What might be wrong?
Seems to me that your magnetron is a goner, check also the antenna shield, cover inside the oven cavity and replace both, you may need to clean and repaint burn surfaces inside oven cavity.
Jan 08, 2016 | Panasonic NN-S676BA Microwave Oven
Why does the fan mode on the bottom oven on my zanussi Zou575 not working?
Because in Main Oven Cavity (large) around the convection fan is very powerful ring heating element 2500W (not visible) who works in the Fan mode. Therefore, it is not necessary that all heaters work because it will overheat the oven.
Dado
Aug 25, 2014 | Zanussi Ovens
Where to buy cavity for microwave oven?
Sorry, but the best and probably only safe option is to replace the whole microwave. I have been working on microwaves for 25 plus years and anytime I came across a hole anywhere in the cavity we replaced the microwave.
Feb 22, 2014 | Sharp Microwave Ovens
I have sparkin and arching in the magetron cavity
remove cover inside microwave oven and clean the cover and the metal around it if it still arks replace the megnatron
Dec 06, 2013 | Maytag UMC5200BA Microwave Oven
Wolf oven door
Refer these issues to the manufacturer.
Nov 09, 2013 | Kitchen Ranges
Is there anyway to remove scratches from inside glass on inside oven door of a Wolf?
There isn't any safe way to sand down glass by yourself. If the scratch is really bad, I suggest contacting Wolf for a replacement glass. Here is their site for replacement accessories.
Feb 22, 2013 | Wolf Range 24" Natural Gas Range w/ 4...
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
