Question about Foxconn 865G7MF-SH Motherboard
Como conectar los cables de encendido de placa base foxconn 865g7mf
MysteryFCM
  • 187 Answers
SOURCE: fone de ouvido
Não tenho certeza se eu entendi como eu não falam Português, mas, se eu sou, então você está perguntando qual a cor auscultadores em ir? caso em que, headphones e alto-falantes sempre ir para a luz verde jack. My reply in English; Not sure if I understand correctly as I don't speak Portuguese, but if I am, then you're asking which colour the headphones go into? in which case, headphones and speakers always go into the light green jack.
Posted on May 25, 2008
SOURCE: help need support cd for the foxconn 865g7mf-sh motherboard
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=865G7MF-SH&TypeID=en-us0000004
This whole complete list of drivers of Foxconn 86576MF-SH
Posted on Aug 31, 2008
SOURCE: LAS LUCES EXTERIORES NO ENCIENDEN
i am getting the problem in graphic card . dispaly cannot change ,and cannot change setting in display , plse give solution or solve this problem.
Posted on Feb 05, 2009
rulds2008
  • 3866 Answers
SOURCE: no encuentro los drivers de foxconn n15235 para
los drivers se encountra en la pagina www.driverguide.com Si esta informacion es ayuda por usted por favor dejar una voto de Fixya Gracias por Su vista a Fixya.com Moy amable
Posted on Apr 28, 2009
puertobori
  • 7733 Answers
SOURCE: necesito el drivers de audio
Dirijase a http://www.foxconnchannel.com/support/downloads.aspx
Posted on Oct 25, 2010
COMO CONECYAR EL PANEL FRONTAL
Para esto necesitas desarmar la PC, hay unos cable que van del panel frontal y hay que conectarlos a el Motherboard. Vasa necesitar una lupa o espejuelos de aumentos para poder distinguir en donde va cada cable.
Sep 26, 2014 | Acer Computers & Internet
NECESITO EL MANUAL DE Placa base 945GCT-HM PARA CONECTAR LOS CABLES DE PW ETC DE ESTA PLACA
Apr 25, 2011 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
NECESITO UN DIAGRAMA DE COMO CONECTAR LOS CABLES DE LAS BUJIAS AL DISTRIBUIDOR DE UN ASTRO 1996
NECESITO UN DIAGRAMA DE COMO CONECTAR LOS CABLES DE LAS BUJIAS AL DISTRIBUIDOR DE UN ASTRO 1995
Jun 15, 2010 | 1996 Chevrolet Astro
Necesito saber la pasword de la bios ayuda
Hola,
Esta no es mi lengua así que por favor desnuda conmigo.
1. En la placa hay una batería de reloj pequeño. Quitar la batería
junto con el cable de alimentación de la fuente de alimentación. Mantenga presionado el poder
botón para descargar completamente el sistema. Espere 2-3 minutos y luego vuelva a instalar el
batería y conectar el sistema. Su restauración se ha completado
2. Algunas placas base tienen un jumper de 3 pines de la batería. Digamos que
el puente está en las patillas 2 y 3. Quitar el puente mientras la máquina está apagada
y colóquelo en los pines 1 y 2. Encienda la máquina por un minuto. (Nota:
El sistema no POST). Apagar la máquina y colocar el puente nuevo
a los pines 2 y 3. Su restauración se ha completado
Este es un gran paso para solucionar problemas para los de usted teniendo problemas POST
o si no se POSTeando en absoluto. Como medidas de solución de problemas, esto no
siempre funciona, pero por lo general en función del problema.
Por favor, hágamelo saber si usted tiene alguna duda o inquietud.
Gracias
May 08, 2010 | HP Compaq 6735s Notebook
La tarjeta no me pita y no me da video
Una pregunta, cuando esta conectada la fuente de poder y enciendes el ordenador, el ventilador del procesador se mueve? Si no se mueve quiere decir que hay un problema de corriente.
Esto se puede deber a:
1. los cables/la conexión de encendido no esta bien conectada (eg. Los cables que van del gabinete a la placa madre)
2. La fuente de poder esta pagada, desconecta o defectuosa.
3. La placa madre no esta bien aislada. Es decir la placa madre esta siento “tocada” en sitios donde no debe. Eg. las monturas del gabinete están haciendo contacto fuera del las zonas aislada, o un tornillo/tuerca esta tocando la placa madre fuera de sitio.
Suerte,
Ed
Oct 04, 2009 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
Feb 04, 2009 | Foxconn 865G7MF-SH Motherboard
Drivers placa base Foxconn N15235
Foxconn drivers can be found at this webpage: Driver Update Software for XP Vista 7 8. Use their software to update all of your drivers.
Wish you best of luck
Hans
Sep 09, 2008 | Foxconn 6627MA-RS2H Motherboard
Cde 9841 r
Bueno,el codigo de colores es el siguiente:
AMARILLO 12v+ memoria (este cable debe tener voltage todo el tiempo)
ROJO 12v+ accesorios(este cable va al switch de encendido del carro)
NEGRO Negativo AZUL(solo)Antena electrica
AZUL/BLANCO enciede los amplificadores
BLANCO +altavoz izq.frontal Blanco/negro -altavoz izq.
GRIS +altavoz derecho frontal GRIS/negro -altavoz derecho
VERDE +altavoz izq. trasero VERDE/Negro -altavoz izq.
VIOLETA +altavoz derecho trasero Violeta/negro altavoz derecho
Te recomiendo revisar los cables y los altavoces que no esten haciendo corto en algun lugar.
Jan 22, 2008 | Alpine CDA-9847 CD Player
Foxconn 865G7MF-SH Motherboard Logo
646 people viewed this question
Top Foxconn Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
