Question about Hotpoint WF430 Front Load Washer
Hotpoint WF430 Hope some one can help!!! my hotpoint wf430 goes through a normal wash cycle, but when it comes to spin mode it spins a few times slowly and then stops.... at this point the on/off button flashes along with the mini-load button to the left of the machine... i cannot switch the machine off then unless its done at the plug. i have tried changing the load and the speed of the spin but the same problem happens... i phoned hotpoint who only seemed interested in sending an engineer (costly, no doubt), should i just phone a pro or is there something im missing:( any advice would be fantastic
    President:
  • 1,294 Answers
Plug off the wall first. Take the pipe from the wall socket and lay it on the floor for the water to spill out. The spin normally does not work when the outlet filter is clogged; if the filter is clean you should then check your pipe coming out from under the tub. Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground. Do not push the pipe too much down the stand pipe.
Posted on Nov 30, 2007
Did you find a solution to your problem? I have the same issue?
Posted on Feb 28, 2007
Try holding in tour start and on button together this should put washer into test mode let it do its test then hold same buttons in again to take out of test mode try washer again i hope this fixes your problem if not e mail me ashnash2007@yahoo.co.uk i'm a aqppliance engineer
Posted on Jul 07, 2007
Hotpoint wf430
The tick is probably the door lock engaging the machine should start filling with water after this, try putting it on a spin cycle if this works ok then it is more than likely to be a faulty inlet valve as a spin cycle only operates the drain pump and motor
Oct 18, 2013 | Washing Machines
Wf430 stuck in wash cycle runs continuously No error codes, am able to stop it then pump out / spin Can you help please
try to check the pressure is not faulty, unclip the pastic tube and blow into it, should to clicks - that mean's it ok and then check plastic tube has no leaks and make sure it is firmly attached at both ends.
Sep 08, 2010 | Hotpoint WF430 Front Load Washer
Leak from lower door section and from powder door thing.
This could be a partially or completely seized/failed pump.
Before a machine goes in to a spin cycle, it runs the pump to empty all the water out. It used to be quite common that the machine does not check all the water has gone before spinning, it just runs the pump for a set time which if the pump is okay, is long enough to empty it.
If a spin is then started with quite a lot of water left in the drum, it gets thrown everywhere including back out of the powder/conditioner draw. Also the sheer strain of spinning a large amount of water can force water through an otherwise okay door seal.
Unless you are comfortable working on the machine yourself, call an engineer.
Sep 07, 2009 | Hotpoint WF430 Front Load Washer
Need to replace drive belt on hotpoint wf430 but to tight to get
Put it on the motor spindle first then feed it onto pulley. It is tricky with such limited access.
Hope this helps &thanks for using Fixya.
Jan 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WF430 Noisy on Spin Cycle
Hi.
It could be loose balance weight, or worn drum bearings.
Remove belt and spin drum by hand from the inside, if you can hear a rumbling noise, or any noise, or it feels stiff to turn then the bearings have failed
If it is under 5 years old, then it should still be under warrenty provided you did not buy it from Comet or Currys.
If it is balance weight, you will be able to feel movement, there is one at top and one at bottom of m/c.
Nov 23, 2008 | Hotpoint WF430 Front Load Washer
Hotpoint wf430
Had similar problem. Blocked filter and faulty pump, clean filter replaced pump approx £25. Took about 20 mins
Jul 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 24, 2007 | Hotpoint WF430 Front Load Washer
Washer doesn't stop
select a hot wash of some kind and check if the water heats. if not, problem could be heater or associated stat
Mar 30, 2007 | Hotpoint WF430 Front Load Washer
Hotpoint WF430 Front Load Washer Logo
214 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
