Question about Microwave Ovens
Panasonic nn-c703bbpq dimension 4 oven bulb
Anyone got any idea where i can get a replacement bulb for the panasonic nn-c703bbpq dimension 4 ?
5 Suggested Answers
SOURCE: Panasonic Dimension 4 the Genius
i had to take the entire cover off the microwave (it is held in pace by screws at back as well as the bottom). Take the busted bulb to hardware store (bunnings) or panasonic spares and replace. Note I have a slightly different models (nn9853, nn9807).
AH
Posted on May 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Dimension 4 microwave model
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
Posted on Aug 03, 2008
SOURCE: Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
Posted on Aug 27, 2009
Testimonial: "Hi - and thanks Martin for an excellent description of the process. Perfect assistance for a handyman-challenged guy like me. Thanks Grant"
  • 178 Answers
SOURCE: Need a users manual for a Panasonic Dimension 4
http://www.retrevo.com/samples/Microwave-manuals.html
Hope this helps!!
Posted on Sep 14, 2009
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
www.panasonic.com/repair
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
Dimension 4
I have this NN-C780P Microwave/Convection Oven. The microwave mode is not working and baking was ok until recently, the turntable cannot rotate when the temperature, timing and baking are ok.
When I bake, there are knocking sound.
Please advise.
Sep 10, 2013 | Panasonic NN-T888S Convection/Microwave...
Dimension 4 microwave stuck on demo mode
Here are is the manual:
http://service.us.panasonic.com/OPERMANPDF/NNT888S.PDF
Page 13 tells how to shut off Demo mode. (Press FUNCTION-0-2.)
Aug 12, 2009 | Panasonic NN-T888S Convection/Microwave...
Martin
May 10, 2009 | Panasonic NN-S540 Microwave Oven
Operating instructions how to set the clock etc con my mircoware
hit clock button press in the time with the numbers on the pad and press the clock button time solved
Apr 03, 2009 | Panasonic NN-P794SF Microwave Oven
Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Sep 24, 2008 | Panasonic NN-C980 Convection/Microwave...
Panasonic Dimension 4 microwave model NN-C703BBPQ not working. Display is not illuminated as if fuse has blown. Have changed fuse in plug, but still no visible sign of life. Anything obvious that might...
Jul 29, 2008 | Panasonic Microwave Ovens
Panasonic Dimension 4 the Genius Microwave/Convection NN-C888W I cannot seem to get into this to replace the electric light bulb. Please can you help me.
AH
Apr 30, 2008 | Microwave Ovens
Need replacement bulbs for over-range hood
These are 20W 120V bulbs with what's called the intermediate base. The new Panasonic part number is ANE6030540AP and you can get them at Tritronics at http://www.wehaveparts.com or Vance Baldwin at http://www.vancebaldwin.com You should also be able to get them at local appliance parts stores, Lowe's (or similar) or even a large grocery store. You can also use Sharp part # RLMPT0003YBE0 from either of the above sites.
Dec 13, 2006 | Panasonic NN-2505A Microwave Oven
Microwave Ovens Logo
163 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
