I have a tempstar furnace w/air pgf060k100d what is the sequince of ops.
3 Suggested Answers
FurnaceGuy
  • 74 Answers
SOURCE: i have a tempstar combine air conditioner and
If the unit is around 6 years old then it could be the combustion air motor. If the unit is older then you need to inspect the heat exchanger for signs of cracks. Take the top off the unit to inspect. Check to see if the metal around the reset is hot and if it is then the switch is doing it's job. If the heat chamber is cracked then turn the gas off, because your home will have CO. This can kill you.
Posted on Jan 05, 2010
heatman101
  • 43501 Answers
SOURCE: furnace will just shut off
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Posted on Jan 03, 2011
I need wiring diagram for Tempstar furnace model nhgg100ah3
Request the wiring diagram directly from Tempstar.
Dec 31, 2016 | Heating & Cooling
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
Furnace wont run until i pull a hose from the pressure switch
ok that switch is called proving switch and if it runs when you pull hose off that means switch is stuck-, normal ops- call for heat power fan inducer start and closes proving switch normally two are a dual switch positive connects to fan discharge and negative connects to heat exchanger (fan suction )this is to insure air movement threw heat exchanger( pressure differential )then and only then a trial for ignition starts check for clog in other end of tubes
If you need further help, I’m available over the phone at https://www.6ya.com/expert/mike_9693b5ad75773352
Feb 21, 2014 | Honeywell Furnace Air Pressure Switch...
Tempstar furnace manual
What is the model number?
What vent piping? Do you want to reroute inside the furnace or run a vent to outside?
Jan 28, 2014 | Heating & Cooling
Gas valve clicks when furnace is running
is there a second call for a flame on during the heat cycle..it may be worn out or the signal to open is not strong enough..
Jan 08, 2014 | Honeywell Icp Heil Tempstar Furnace Spark...
I have and older tempstar electric furnace and i have a few questions ccan someone help me
heatman101
Feb 15, 2011 | Heating & Cooling
Furnace will just shut off and blow cool air during cycle. Tempstar brand
heatman101
Jan 03, 2011 | Heating & Cooling
Heating unit blows warm air then turns to cold air
it sounds like unit could be kicking out the low pressure switch or if it is a electric furnace it could be the sequincers
Jan 11, 2010 | Ruud UBHC Air Conditioner
FRESH AIR INTAKE DOSE MY FURNACE NEED ONE
your furnace must have one. look to see where the large filter, that is the fresh air intake. it does not have to be out door air, just air.
Nov 05, 2009 | Jackson 25 in. TempStar-40 Free-standing...
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
