Question about Timex T5E231 Ironman Triathlon 100 Lap with Flix System Watch for Men
Ironman watch fault code 814017
Screen keeps resetting its self and when it blanks out a number is at bottom of screen.. 814017. then the date and time resets to midnight 01012000
5 Suggested Answers
SOURCE: Error Code Display
I have the same problem. Timex has made sure the internals of the watches hate having their battery changed. It's just so they can make us think "Why change the battery, just buy a new one." And really, it works. I've given up on mine. Time to move on to a nice Casio. Sorry. Unless you are a really technical expert on watches, you're pretty much SOL.
Posted on Dec 17, 2007
SOURCE: How do I change the
To find out how to set your watch, go to http://assets.timex.com/instructions/w130Instr.pdf and it has instructions in several languages. IF this link does not work, go to www.timex.com and click on help, then click on manuals and downloads,then click view all watch manuals,go down the list until you find Ironman combo and click on it. You need a pdf reader to view this info. I hope this helps.
Posted on Jan 10, 2009
VOTIT
  • 2071 Answers
SOURCE: how do you set Timex Triathlon Ironman watch?
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Regards;
VOTIT
Posted on Jun 08, 2009
SOURCE: Random display resets of TIMEX Ironman Triathalon(100 lap memory)
Hello RLOWE803,
While I was looking for pictures specific to resetting this watch, I came across your post and thought to reply. I recently replaced the batteries on my watch, which I have owned for nearly 7 years. It is an Ironman Triathlon 100 Lap watch. When I replaced the batteries this time, I forgot to reset, in essence reboot the system, by using a metal needle point tweezers to briefly connect the positive side of the battery to the "AC" pad on the small circuit board for at least 2 seconds. I remembered to do this with at all the other times I had replaced the battery and did not have any troubles after it. This time I forgot and now have the same issue you described. I am not sure where the "AC" pad is on the back of the module. But, it should be apparent if I did it correctly in the past.
Give that a try before sending it off to be repair and wasting time, money and trouble.
Good luck,
CAZ
Posted on Aug 30, 2009
How to set the time and date on my times ironman triathlon watch
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Sep 01, 2010 | Timex Ironman Triathlon 50 Lap Digital...
Timex Women's T5K188 Digital Ironman Pulse
manual download"
May 13, 2010 | Timex 24101 Wrist Watch
Set time and date
At the
manual download"
Feb 08, 2010 | Timex Sports Ironman Triathlon 100-Lap...
New Ironman - screen is blank. How do I get started
It could be that the battery has an insulating paper fitted. Have you no instructions?
You can get instructions from the Timex web site "timex.com". At the bottom of the screen click on "manuals/downloads", then on "product manual download"
Feb 04, 2010 | Timex Sports Ironman Triathlon 100-Lap...
Can't turn off chime on timex ironman watch
Go to the timex website, scroll to bottom, click on Product Manuals and Downloads. Then at the bottom of next page, find your watch by model number and look up how to control chime in instructions. It is usually something in the alarm menu... in my case, hitting stop/reset in alarm mode toggles the chimes.
http://assets.timex.com/user_guides/W9_M814/W9_M814_AllLanguages.pdf
Jan 20, 2010 | Timex Ironman Triathlon Sleek 50 Lap 5G301...
Hello RLOWE803,
Good luck,
CAZ
Jul 22, 2009 | Timex Sports Ironman Triathlon 100-Lap...
Setting time/date on Ironman Triathlon 8 lap
Press & hold set button the seconds will flash.
Press split/reset to set seconds to zero
Press mode to select hours
Press split reset to advance hour digits go through 12 hours to get to AM/PM
Press mode to select minutes
Press split reset to advance minutes
Keep repeatin the above steps to set month date day and 12/24 hour diplay
Press set when done.
Mar 09, 2008 | Timex Sports Ironman Triathlon 50-Lap...
Error Code Display
Mine did the same thing after changing the battery and would reset intermittently without warning. For some unknown reason I decided to open the watch again. This time I reset the time and date with the back off the watch while deprssing the small spring that is there on the inside . Haven't had a problem since. Don't know if this is the solution but it worked for me. Good luck!
Les H.
Oct 30, 2007 | Timex Sports Ironman Triathlon 100-Lap...
Screen goes blank
I put a new CR2025 battery in my T5e671 Timex and it solved the problem.
The screen no longer goes blank at any time.
PS:Timex manual says "remove battery strap" to replace the battery.
But it doesn't say HOW.-& I couldn't google an answer to that.
Here is how:
The metal strap goes across the middle of the battery and then goes over the edge of it on both sides.
At both edges the metal strap goes over a nylon tab.
One of those nylon tabs is notched, if you put the end of a paperclip in the notch, you can release the metal strap edge that runs under it.
Oct 14, 2007 | Timex Ironman Triathlon 51931 wristwatch
Timex T5E231 Ironman Triathlon 100 Lap with Flix System Watch for Men Logo
100 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
