Question about Microsoft Xbox 360 Console
My xboxs error code is 4124
Every time i start up my xbox, it has those 2 red rings on the left hand side, vertically. i have cleaned out my xbox 360 and this still happens...
  • 34 Answers
SOURCE: 360 Xbox problem Three red rings
Unfortunately there is nothing that you can directly do to fix this problem.
You have a hardware failure. Microsoft will repair your unit for you under warranty / recall.
http://support.microsoft.com/kb/907534
Sorry to be the bearer of bad news.
If my solution was helpful, please vote for me!
Posted on Nov 16, 2007
  • 44 Answers
SOURCE: my xbox 360 is not displaying any picture just sound
its overheating but will give u red light eventually try googling X-Clamp fix i fixed many with same problem
Posted on May 14, 2008
edo333
  • 55 Answers
SOURCE: 2 left side red 1/2 ring ligts
These two lights are actually an indication of overheating. Typically this happens if the heat synch is not making good contact with the cpu or gpu, or the cooling fan is not working properly.
If the fan gets really loud just before it overheats and turns off then it is likely a heat synch issue
You can try searching for the xclamp replacement fix (I won't leave my own tutorial here as there are a plethera of them out there, just use a search engine to find them)
If the fans do not make noise - it may be that they are not working properly, you may want to replace it with another cooling fan. Talismoon fans are widely available and very quiet.
Try cleaning the console - dust and debris trapped inside the console traps heat as well.
Other than that if the console is usuable for more than a few minutes and it overheats after an hour or more, then you can try removing the heatshield (metal piece located under the top plastic cover) and or replacing the cooling fan with a more effecient fan. Please note that removing the heatshield is not recommended as it protects the top of the console from the extreme heat built up by the console, but removing it does allow for a much more significant amount of air flow.
Try and keep the console off the ground - along with the power supply
Play it horizontally instead of vertically and keep it away from carpets which trap heat and other sources of heat.
As always contact microsoft for warranty info prior to opening the console or letting someone else fix it for you.
Hope that helps.
Posted on Jul 04, 2008
SOURCE: Xbox problem
check this website and follow the steps in it:
http://ezinearticles.com/?Xbox-360-3-Red-Lights-Fix---The-Simple-Solution-To-Your-Xbox-360-3-Red-Lights-Fix&id=1201271
Posted on Aug 25, 2008
SOURCE: TWO RED LIGHTS ON XBOX 360.
that means it overheating........
Posted on Oct 15, 2008
Xbox360 red light comes on and console will not start
Christina, you have what is know as the "Red ring of *****". Your Xbox is on it's last leg and you need to have it repaired. You can try cleaning the vents, running a dvd cleaning disc but, in all likelyhood, it's gonna need to be professionally repaired.
Sep 18, 2015 | Microsoft Xbox 360 Console
Tip
XBOX 360 Error Codes
There are several error codes you can get with an XBOX 360, the first step to resolving any problem is finding the root cause. The fault codes are primarily shows on the "ring" on the front of your console (this is the ring split into 4 segments that shows when controllers are connected and what player position they are).
  • 1 SEGMENT FLASHING RED - Thisindicates a displayable error code, the specific error code will bebeing displayed on the TV you have it connected too.
  • 2 SEGMENTS FLASHING RED - The console has overheated.
  • 3 SEGMENTS FLASHING RED - This is the somewhat infamous RROD (Red Ring Of Death).
  • 4 SEGMENTS FLASHING RED - AV cable not detected.
If you have 1 segment flashing red indicating a displayable specific error code then you can identify the fault from the list below.
  • E45 - Update Error.
  • E64, E65, E66 - DVD Drive Error.
  • E67, E68, E69, E79 -Hard Drive Error.
  • E71 - Update Error.
  • E72 - Unknown.
  • E73 - General Hardware Error.
  • E74 -AV cable error.
  • E76 - Unknown.
This is a basic overview of all the fault codes for the XBOX 360, for more in depth information on the faults and how to repair them please see my other tips!
Thanks!
on Mar 25, 2010 | Video Game Consoles & Games
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Red ring
hi there,
your xbox 360 need service open it and remove all dust around the fan and prosseser every thing fine again.
Jul 11, 2010 | Microsoft Xbox 360 Console
My xbox360 has an error one red light on the bottom right hand side
Greetings,
Please go through the Website link mentioned below.
http://support.microsoft.com/kb/907536
Please let me know if you have any issues.
Regards,
Feb 09, 2010 | Microsoft Xbox Console
What can i do to fix my xbox 360 with 2 red rings
its simply overheated just take a wet cloth place on top of xbox and wrap the power supply in a wet cloth too (not soaking wet moist) Hope this Helps@!@
Nov 26, 2009 | Microsoft Xbox 360 Console
Xbox360 show 2 rings
2 rings means overheat
leave it in a cold place for some hours and it should be ok
Oct 21, 2009 | Microsoft Xbox 360 Console
Code error 74
Your console has the E74 error message. Your system is dead, call Microsoft cutomer support. It is covered by the warranty so repair is free.
Jul 30, 2009 | Microsoft Xbox 360 Console
I have 2 red rings on my xbox 360 but i dont understand what they mean...
The 2 flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. The main thing that causes the 2 red lights to start flashing is because of overheating and as the motherboard within the console takes more heat it actually warps and bends until the solders become loose.
Once this happens you will receive the 2 red lights. Even before you get the 2 red lights you may have noticed your games freezing and this is caused in the same way, by overheating. As the chips take more heat they shut off to prevent lasting damage, although they can only do this a number of times until you get the Xbox 360 2 Red Lights.
To fix the problem you need to stop the level of heat the motherboard takes and you can do this in a number of ways, but it will involve opening up your Xbox and working on it. In addition, you could always send your Xbox back to Microsoft as they are offering free repair for this error, you will just need to wait 3-4 weeks that's all.
There is one more option available in the form of DIY Video Guide, that will explain you step by step approach to fix red ring of death within one hour without any technical knowledge.
Jan 13, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
131 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
