Question about Husqvarna Chain Saw 20" Bar
Replacing brake assemble for husqvarna chainsaw model 141
Pulled apart the asssembly to replace brake however now I cannor assemble it back without the brake being on and therefore cannot put it on again
  • 211 Answers
Hi Hope this link help you a little http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF&app=EWSS&session=b091f8d2-6ba8-44df-9037-edddf1788be6&cat=10&TF=epcFrame&assem=148&ignoreHist=Yes&level=1
regards savumihai71
Posted on Dec 15, 2008
REPLACE CHAIN BAR STUDS 55 RANCHER
Tom, Check the attached links,instruction and guides on Husqvarna chainsaw, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna rancher 55 chain bolt replacement
http://www.husqvarna.com/ddoc/HUSO/HUSO2002_USen/HUSO2002_USen__1140106-95.pdf
How to Change Chain on Husqvarna Chainsaw Model 445
How to Adjust the Oiler on Husqvarna 55 Rancher
Apr 02, 2016 | Husqvarna 36 41 50 51 55 136 141 154 254...
How to reassemble chain brake on an Echo CS-350T that jammed and was pulled apart by someone else?
From what I see you will need assemble thing leaving the main spring and brake cover off. Before attempting to put the main back in install a clutch drum inside the brake band. Then you slip on the main spring and pry the end on with a flat blade screw driver. Now install in the cover for the spring and brake. Reset the chain brake and remove the drum.
Now install the chain brake on the saw and test. Do not trip the chain brake without the clutch drum in place. If these are anything like the Husqvarna version after they get worn they will get where it is nearly impossible to reset.
Echo CS 350T Chainsaw CS350T Parts Diagram Page 7
Jan 12, 2015 | Echo Garden
How to replace fuel pick up,line in Husqvarna 1414 chainsaw?
You need to remove carb and then you can access the hole for the fuel tank. you need to go to a Husqvarna dealer and get the correct line. if too big wont go in if too small will leak replace fuel filter when you do it.
Oct 14, 2014 | Husqvarna Garden
How to remove the chain from a husqvarna 235e chainsaw?
Like this or pretty close.
  1. Cock brake while expanding chain brake binder by pulling brake handle towards left-hand (wrap-around) handle grip, hard, until it locks in place.
  2. Loosen 2 brake-asssembly-and- bar retaining nuts but do not remove yet.
  3. Unscrew (turn CCW) bar adjustment screw on front face of unit in order to shorten bar and slacken saw chain.
  4. Slip chain off bar over bar tip and towards inward side of bar.
  5. Remove two nuts loosened in step 2 and pull brake assembly and bar straight out and off bar mounting studs.
  6. While rotating clutch/brake-drum, maneuver saw chain off sprocket and around drum perimeter to remove from saw.
  7. Repeat/reverse steps 6 thru 1 in that order to reassemble.
25045742-0m3nstwfcb55vn4usb1qox2f-3-0.jpg 25045742-0m3nstwfcb55vn4usb1qox2f-3-2.jpg
Sep 01, 2014 | Husqvarna 14-Inch 34cc Gas Powered...
Check valve falls out leaks gas 2000 141 EPA PH1
The decompressor valve is a complete assembly and not a serviceable component. These valves are readily available and many reputable Husqvarna shops will carry them in stock.
To replace one, use a long tube socket and unscrew it. Replace in the same manner.
Mar 27, 2014 | Husqvarna Chainsaw Decompression Valve
Husqvarna chainsaw blade not engaging
I cannot remember a 141LE, there was a 141 petrol machine, there was a 1400EL electric machine, please let me know weather it is electric or petrol.
Mar 06, 2012 | Husqvarna Garden
Top handle, model # 2040 jonsered. is the same as what model # husqvarna
Husqvarna never used this model in there range, they used the same cylinder,piston and crank assembly in the 41/141 but all other components were different to the Jonsered, the part no. for the Jonsered top handle is 530038327
Aug 28, 2011 | Husqvarna Garden
How do i put the brake assembly back to gether
If your saw is indeed a Husky there is likely an illustration of the chain brake on the IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Oct 26, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Re-assemble after replacing chain
the brake is more than likely on,pull back on back should go back on
Oct 21, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
503 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
