Question about Maytag Dryers
Burner high limit fault
Commercial gas dryer
5 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: mdg2300bww dryer, flame is large hitting high
Hi, A couple of things to look for. Check the 4" vent going to the outside and make sure there is clean. If that is ok, check to see if the blower duct inside the dryer is clean and make sure the blower wheel is turning properly. This model has a problem with the blower wheel coming loose on te motor shaft.
The flame is large because it is not being sucked past the limit switch.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 17, 2009
docjohn174
  • 943 Answers
SOURCE: maytag dryer serial#ldg5914aae
hi. thanks for the question. i would replace the 2 coils at the gas valve . thanks the appliance doc
Posted on Oct 05, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool commercial gas dryer - heating problem
Check the voltage to the switch when turned to high and the power button pushed on. If you are not getting any power there then the setting switch is bad replace it at repairclinic.com
Posted on Feb 14, 2009
heatman101
  • 43501 Answers
SOURCE: The dryer runs but no
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
How to put belt on a whirlpool cgm2941tq1 commercial gas dryer
This video will show you how to do that...the models shown are for domestic dryers but the process is exactly the same to replace the belt on a commercial dryer
http://www.youtube.com/watch?v=CFnXwmUb4f4
GENE
Aug 28, 2011 | Dryers
Short drying time
probably will have to replace timer motor with one that has a longer run time.
Jul 07, 2009 | Maytag MDG16CS Gas Commercial Dryer
Maytag commercial dryer rejects all quarter
Take out the coin slide and inspect for any worn parts. You can replace it for about $40
May 14, 2009 | Maytag MDG16PD Gas Commercial Dryer
Dryer is warm but not hot
Is the model number listed here or can you find the complete model number? May need cycling thermostat or gas valve solenoids. Let me know if I can help, Sea Breeze
Mar 22, 2009 | Maytag MDG16PD Gas Commercial Dryer
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Feb 14, 2009 | Whirlpool CSP2761 Gas Commercial Dryer
Not heating for my MayTag commercial Dryer
You need to remove the front panel and check to see if the glow bar is lighting. If it is and you aren't getting any flame 1 of 2 things can be wrong the gas coils could be bad or the gas valve itself could be bad. the easiest way to check the gas coils is to take off the front panel (you will need either a philips head screw driver or a T20 security star bit) and loosen up the bracket that holds the gas coils down. Don't remove the screws completely. start the dryer and lift up the bracket. If it seems like the coils are pulling the bracket down then the coils are good and you will need to replace the gas valve
Dec 25, 2008 | Maytag MDG16PR Gas Commercial Dryer
Maytag MLG23PD Gas Commercial Dryer
605 5 quarters to start 712 12 minutes per quarter if yu want 1 quarter to start dryer change to 601. if yu want dry time to be 8 minutes change to 708 press whites and colors to select value and then press permanent press to go to next code.
Apr 19, 2008 | Maytag MLG23PD Gas Commercial Dryer
Dryers Logo
296 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
