Question about Craftsman 4 Cycle Blower/Vac
Can't start my leaf blower
My craftsman leaf blower after runnig well it stop working ,now I can start it. I can't pull the rope it is stuck!
You might have damaged the "spring re-wind" or the cord is jambed. If you know how to disassemble the housing (see owner's manual), then check to see if the cord is stuck, then manually re-wind it and pull it slowly and then let it rewind slowly. Do not attempt to remove the spring housing unless you have several hours to spare to rewind the spring, as it will "unspring" with great force - all over the place. Zing! The only other solution, of course, is to take it back to Sears for repair. Yuck. Have had several in the shop for other reasons that couldn't be easily DIY repaired - time after time.
Most ****-smen products cause more headaches than they prompt smiles of joy. I have pretty much determined that the manufacturers of ****-smen (who ever they are) plan it that way. Most home-owner products of this sort only last for 3-4 years, if you're lucky. I have also tried other brands; none are much to rave about. You could always do what I do, if I don't have any warrantee time left, or an extended agreement; give it a nice funeral (or run over it with a tank and send the remains to the CEO of Sears) and spend the money for a new one (any brand - even Craps-men) or use a rake..... :(
If you do get it to work, try pulling the cord with less force and NEVER let it "spring back" by letting go of the handle. Let is rewind as you hold it. GOOD LUCK!
Posted on Nov 09, 2008
Probably used wrong gas ie no oil mix and froze engine.
Posted on Oct 30, 2008
How to repair rope pull in craftsman weedwacker gas trimmer model No. 316.791940"?"
If you go to searspartsdirect.com an enter the model number for your weedwacker if will show you a diagram of how to remove the rope pull. Hope this helps.
Sep 26, 2016 | Craftsman Garden
How to fix the starting rope on a craftsman weed *******
is the pull rope in front of the engine ???
yes ???
you dont wanna know
Aug 05, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
The pull cord on my leaf blower will not re-coil. I have it torn apart but can't figure out what is wrong. Any ideas? Craftsman 32cc 360 cfm gas
How far did you take it apart? It is more than likely just jammed, take a small screw driver and stick it in one of the fins and try to work the pulley back and forth. When you pulled it, it went past the end and pulled the rope back in when it should be pulling it one way now it is pulling it the other way and it is locked. Or the spring is broke. Not likely. Here is a video on it.
http://www.youtube.com/watch?v=zelPN20xVrM
Oct 01, 2010 | Craftsman Garden
Hi, I have a Poulan gas blower, the rope will not pull out
remove spark plug for inspection
1) silver or aluminum color
STOP the piston is seezed. TOO costly to repair
2) plug dark brown or black (pretty much normal)
remove recoil housing for tangled rope or broken rope rotor
Nov 08, 2009 | Poulan Garden
Gas leaks from air filter. sears craftsman leaf blower,chipper.
engine is flooded,
spark plug fouled,
choke has been on too much while pulling recoil rope
ignition coil or switch is malfuncitoning
Nov 07, 2009 | Craftsman Garden
I have a craftman leaf blower model#368794963 hand held 25cc it was running fine but now it wont start
hello
if you have spark remove the sparkplug and priming the engine(put some gas in sparkplug hole into the cilinder).Pull the rope for starting engine as many times as you need until the engine starts but without any choke and the switch on the on position.Please let me know what is going on.
regards savumihai71
Nov 04, 2009 | Craftsman Garden
Broken pull starter rope
remove pulley that rope goes on, wind it with new rope, wrap it till it is full, then feed rope thru hole in housing, put pulley back in place, put rope thru pull handle, pull thru till you feel spring catch tie a knot and that should do it......be careful when removing pulley not to dislodge recoil spring
Oct 22, 2009 | Garden
My Craftsman leaf blower will not start. Why not?
Inside the carb is yet another fuel filter in the form of a screen. It is located just under the inlet needle and it would be included in a carb REBUILD KIT (not simply a diaphragm kit).
Replacing the screen and rebuilding the carb take nearly the same amount of labor so buy yourself a kit. Roughly $10.00 for most Hand-Held blowers.
Hope this helps.
Oct 04, 2009 | Garden
How to check for spark on leaf blower ?
hi
ground the sparkplug at the cilinder and pull the rope.see if there is a spark.if not try changing the sparkplug
Sep 23, 2009 | Craftsman 4 Cycle Blower/Vac
Pull starter handle is locked in it's orginal position,pulling on the handle does nothing
Unless the starter rope jumped track and is causing the problem, it sounds like the engine is locked up.
Sep 20, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman 4 Cycle Blower/Vac Logo
467 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
