Question about Neumann Audio Players & Recorders
My Neumann M149 is making noise. Sounds like a bad tube
3 Suggested Answers
robotek
  • 1512 Answers
SOURCE: i have problems with my m149 neumann
Hi wirus
This mic is worth more than $4,500 to purchase. I strongly recommend that you refer it to a Neumann service agent(with power supply) to have it checked out. There are no user serviceable parts inside the mic, and cleaning should only be serviced by qualified and trained personnal. I expect that you have already checked leads and so on.
Go to this site, for a service agency in your part of the world. Good luck with sorting out the drama. Hope you get back to recording real soon :)
regards
robotek
Posted on Oct 31, 2008
  • 28 Answers
SOURCE: My Neumann M147 is making noise. Sounds like a bad tube
tube should be in power supply just replace it
Posted on Nov 06, 2009
Popping sounds only during video/ you tube on tv from my computer.
Because of the amount of voltage required to run the older-style "tube" televisions, many problems, sounds and noises occur in tube televisions than in the newer, flat-panel televisions. Sounds occur for multiple reasons, with some being just part of the normal process these televisions run through in order to operate. On the other hand, some of these noises may indicate a problem with the television that could warrant repair.
Worn Insulation
Voltage against metal. Inside your television's tube, there are many wire parts that electricity runs through in order to make the television run. Usually, these parts are insulated with a rubber or foam casing that prevent the sound of the electricity. If the insulation surrounding these components is thin, weak, worn or absent, you are bound to hear buzzing, popping and cracking sounds coming from your television. While this may not mean you have to run out tomorrow and get a new one, the chances are that your TV's tube is working extra hard to make it all happen for you, and you may want to start pricing new sets for the near future. b> Static During Warm-Up b> Just like rubbing your feet on a thinly-carpeted floor can cause static electricity, the same can also build up inside your television. If the noise is relatively subtle, only occurring when you first turn it on, and not overly-disturbing, the chances are that the cracking and popping sounds you are hearing are just the television's way of warming up and getting rid of the unnecessary electricity. Bad Lamp b> Deep inside the heart of your tube television, there is a light-bulb fixture that makes the entire unit light up so that you can see a picture. If the cracking and popping sounds you are hearing tend to go along with the picture on the TV becoming unclear, it could be that the picture tube is failing. It is very difficult and costly to replace the picture tube on a tube TV, so this is an instance where you may benefit more from buying a new television than taking the old one in for repair. Hope this helps.
Dec 21, 2012 | Computers & Internet
Neumann TLM mic is inoperative when connected to PA with same cable that worked with Shure SM 58 mic
The Shure SM58 is a dynamic microphone instead of the electret one Neumann TLM 103. This means that Shure does not need a phantom power supply voltage, instead of Neumann TLM 103; this one needs 48Volts. Here are the specifications for each one of the microphones: Shure SM 58 - Neumann TLM 103. In case you use a pre-amplifier or an audio console try to locate a switch marked as "Phantom Power" and turn it on. Typically there is no problem supplying a phantom power at the SM58. In case you have no phantom power switch available, either post back the mixer brand / model to check it for you, or post me a question to suggest you one. Details about the usage and the mixer you are already using will help me to clarify the total audio situation.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Jan 27, 2011 | Neumann TLM 103 Professional Microphone
When plugged into the board, it just makes a rumbling noise, similar to the sound of wind against the mic. No other sound comes through.
First try another cable. If still bad, try another channel on the mixer. Obviously , you know this microphone requires phantom power.
If all fails, then the capsule o the microphone is shot. Either from being dropped, or excessive spit/moisture getting on the capsule.
Hope this helps.
Apr 13, 2010 | Neumann KMS105MT Professional Microphone
What resistor do I replace when changing transistors on u-87? Mic has low output now. I replaced the old SK 103 transistor for a 2n3819 transistor from neumann and it came w/ a resistor for matching but no...
Try contacting them through this link and ask to speak to a tech. Write or email them if you have to:http://www.neumann.com/?id=service_servicepoints&lang=en
Oct 19, 2009 | Neumann U87 Professional Microphone
I need a tube replacement for neumaan 147
Vacuum tubes are available, but in order to maintain the very high quality of such a wonderful sounding microphone I would very highly recommend paying extra and getting your tube direct from Neumann. They list dealers at http://www.neumannusa.com/dealers-neumannusa.asp so find the one nearest to you. As long as you are talking to them, you may want to consider asking if there are any alignments or updates that would apply to your unit either because of the tube replacement or just general product updates.
Apr 22, 2009 | Audio Players & Recorders
1997 Honda Accord ABS makes a "grinding" noise when turned on
Have you had the master cylinders replaced? Mine made this exact noise and they replaced the master cylinder.
May 11, 2017 | 1997 Honda Accord
Frequency responce for km130
http://www.neumann.com/?lang=en&id=current_microphones&cid=km100_publications
Jan 21, 2009 | Neumann KM130 Professional Microphone
NEUMANN U89 SOUNDS VERY FAINT
Your mixing board may not be supplying 48 volt phantom power, which is required by the U89. Check with a voltmeter from pin 2 of the XLR to pin 1, see that it's 48 +/- 4 volts.
Nov 25, 2008 | Neumann U 89 i Professional Microphone
I have problems with my m149 neumann
Hi wirus
regards
robotek
Oct 21, 2008 | Neumann M-149 Professional Microphone
57 people viewed this question
Top Neumann Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Neumann Audio Player and Recorder Expert? Answer questions, earn points and help others
