Question about Panasonic PT-47WX42 47" Rear Projection Television
47wx42 - wavy red and green "bars" on top and bottom of screen
Turned on the tube and am now seeing red and green bar areas at the top and bottom, along with seeing these red and green areas offset (like a convergence problem). Is this the evil STK392-180 chips gone bad??!! Thanks
Replacing the two STK392-110 ICs didn't do it for me. But you can try. I am experiencing the same problem, and it appears that is not possible to correct the problem with the ajustments in Service Mode. Please let me know if you find a solution to this problem. TIA.
Posted on Dec 30, 2006
When battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there....
when battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there. I've tried soft reset, system reset, and hard reset...nothing works.
Jul 18, 2009 | Palm Treo 650 Handheld
My top screen looks like a tv that has static looks wavy and bars
well more than likely you closed it to hard. you will have to call a nintendo ds repair man. sorry. your reading from someone that had the same experience. i had to ship it to get a new top screen. sorry bout that.
Mar 31, 2009 | Nintendo DS Lite Console
Program columns are out of place
See if you can click and drag the start menu bar back to the bottom of your screen and then try to do the same for your program panel to attach it back to your start menu bar.
Also make sure your task bar is not locked by right clicking on it and seeing if there is a check next to it.
Dec 12, 2008 | Dell Inspiron 530 Desktop Computer...
RED, GREEN, BLUE AND WHITE HORIZONTAL BARS APPEAR ON THE SCREEN...
Remove battery , let sit for 2 miniutes . Re install battery , in proper position , hold on button for a few seconds and this should work ...
Jun 11, 2017 | HTC TYTN GSM Phone
Wavy Red lines
hi there,
if you are familiar with electronics you can do this :adjust voltage at hight voltage block it has screen and focus written on it and comes from flyback transformer,but be careful cause it can be to dangerous if you touch something else,ah,ah adjust only the one that says screen and has a R on top,that means red,ok,thanks.
Jun 19, 2008 | JVC AV-48WP30 48" Rear Projection...
RED AND GREEN DOUBLE AND BLUR PICTURE HELP PLEASE
You have a convergence problem. Components are shorted out and must be replaced. Unless you're a technician, there's really nothing you can do at this point.
C-Dog
Feb 03, 2008 | JVC AV-56WP74 56" Rear Projection...
I am told my Hitachi 61SDX01B (UltraVision/Ultrascan) has "Green Geometry"
Sounds like a convergence promblem.
Here are some of the most common symptoms of a convergence problem.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Oct 15, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 61SDX01B
The problem is called green geometry.There is nothing wrong w/the green pix tube.It is critical to get the green geometry
accurate because the red and blue convergence overlays on
the green.If you have more than an alignment issue,that will need
repair before adjustments are attempted.
What is the life of a big screen tv?
Sounds like the veritical circuit has a bad capacitor. The cost is dependent on the servicers in your area. It can also be dependent on whether you take it to the shop or have a servicer come to your home. Look on a Mitsubishi website to find a servicer in your area.
Feb 07, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Panasonic PT-47WX42 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
