Question about Dishwashers
GE dishwasher model # GSD2200Z02AD
I have a GE dishwasher model #GSD2200Z02AD. I guess I would say that the timer is stuck. When I turn the control knob to start, it stays on start and doesn't progress. I did a load of dishes before I went to bed the other night and turned it to start. When I got up the next morning, it was still making the noise like it was on start and the knob had not progressed so that it never went through any cycles. Doesn't look like I can wash the dishes without maybe babysitting it and trying to turn the knob to different cycles.
    Habit-Forming:
  • 154 Answers
Yep you need a new timer part. on your search engine type in ge dishwasher model number then scroll down to find timer part number order it only if your can take broken one out if u cant then u need to call repairman.
Posted on May 13, 2017
  • 641 Answers
SOURCE: dishwasher wont progress to next step
Does after the manual moving to the next step, the dishwasher complete the cleaning process properly ?
Posted on Jul 27, 2007
Rotu
  • 175 Answers
SOURCE: bosch dishwasher
I'm probably sounding like a broken record, but id f its got buttons on the front and not a knob, its probably the control board. Unplug the unit or flip the breaker.Take off the outer door and the control panel by removing all those torx screws down each side, then pop that control board with all the wires out of the housing. once you have that in your hand, open the control assembly itself (should open like a book, into 2 halfs) once you spot the half without the buttons and lights, take that half out of the plastic housing and look on the back. If there is a burnt solder joint there (it will be obvious if it is) you will need to have that joint repaired, or get a new control board..bout $150 if memory serves. that joint that burns powers the heater, so its likely thats your problem. It can also cause some other isuuse as well, such as the time display freaking out (if you have one) Good Luck!
Posted on Aug 16, 2007
bigg t
  • 640 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Posted on Feb 24, 2008
aborcass
  • 2651 Answers
SOURCE: Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Posted on Jan 25, 2009
  • 120 Answers
SOURCE: the dish washer fills and wash cycle begins,
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Posted on Nov 04, 2009
Our Kenmore dishwasher model number 665.13163K701 display is always showing the heater cycle indicator on. Tried some reset instructions I found online and turned off breaker for a few minutes and still...
please follow the next steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. 87af5b68-272e-404a-951c-cd453d3cd7fe.jpg
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer/electronic control
Jul 06, 2013 | Dishwashers
How do I get my ge dishwasher to run? the lights
Hello there and welcome to fixya
If electrical power is available to the dishwasher but the appliance doesn't run, the problem is likely to be a defective door switch, timer, or selector switch. Make sure to turn off the power to the dishwasher before attempting any repairs
To solve a door switch problem, you may be able to adjust the door latch's strike slightly, using a screwdriver
then make sure the door closes securly, if this doesent work
please check the timer as follows
Dishwasher timer concerns can be classified into two general categories: the timer cannot be advanced manually and appears to be stuck or intermittent automatic timer advancement.
1. The timer dial cannot be advanced manually and appears to be stuck. Stuck timers are generally caused by objects that prevent the detergent cup from opening, or by a sticky substance between the timer dial and the control panel.
  • Objects that prevent the detergent cup from opening: If your timer will not advance, open the dishwasher door and check for items that may be blocking the detergent cup.
    Also, check the detergent cup:
    • It should be fully closed at the start of a cycle.
    • It should be fully open at the end of the cycle.
    • Almost fully open between main wash and final rinse.
    If it is in any other position, try to open or close the cup while at the same time rotating the timer. This should free it up. To prevent a reoccurrence, make sure nothing blocks operation of the detergent cup when the dishwasher door is closed and operating.
  • Sticky substances like orange juice that get between the timer knob and the front of the control panel on some models will bond the timer knob to the control panel. If you have this condition, it will be virtually impossible to rotate the timer knob while gently pressing the knob in toward the dishwasher. It will rotate normally if the knob is gently pulled away from the dishwasher while rotating the knob.
    This problem can be solved by gently pulling the knob away from the control panel and cleaning behind the knob with a damp cloth. Do not use excessive force because the knob is attached to the control panel on models affected by this problem. If this operation cannot be performed, service should be contacted to repair the problem.
2. Intermittent automatic timer advancement. This can be described as the timer can be advanced manually, but it does not advance automatically in spots for up to 30 minutes.
  • This is almost always a normal condition and always occurs on models with a "Delay Start" feature.
    Delay start timers increment or advance a couple of degrees once every minute or so during most of the cycle. However, during certain parts of the cycle they increment once every 30 minutes. This gives the dishwasher time to do the job of cleaning your dishes. The long increment times occur during "Delay Start", "Hot Start", "Normal Wash" and "Dry" cycles.
    The timer will not move at all during these delay periods. This is normal operation and service is not needed. If you notice delay times substantially longer than 30 minutes, replace the timer
  • Also ensue that you are getting adequate water pressure and the unit is getting water inside and that the water is at the right temperature 140 is the min. for most units
  • Please check the above and let me know what you have found so i can continue to help there is a lot of things to check but these that i have provided are the most common thing that need to be checked first ok?
  • Best regards Mike
Aug 21, 2011 | GE Dishwashers
Ge profile dishwasher runs for hours
HI, this will occur if there is a major control fault in the timer module or, main control board. Depending on you model, you will need to replace the timer or, control board in this case. this will fix this issue
Jul 15, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
My GE monogram dishwasher won't drain. The (3 different) repairmen who came to my home checked the hoses, replaced the pump and replaced the motor. Nothing worked, and they suggested that the home warranty...
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly
If this model doesn't have a drain solenoid to inspect(uncommon), this will lead to a control issue with the main control board or timer module. replace if found to be defective.
remember, the drain command is initiated by the control.once the command is issued, the pump will carry out the actions of draining the unit. if the control is faulty, it will not issue the command properly.
Jul 10, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
I have a GE roll around dishwasher, Model GSC3200Z03BL. It worked one night, did not work the next. After hooking intake/discharge hose to faucet and turning to start, no water is pumped in. Only a...
First off.. the pump does not let water in.. it takes water from your sink faucette via the hose and allows it to enter the DW via an inlet electrically operated valve. If that valve is not commanded by the control system to open, then no water will enter the DW and a wash cycle will not start. Please find the informaton shown below that decribes some reasons why your DW may not be filling with water. You should go thru this series of checks to make sure you've set up the DW correctly aqnd it is not in mid cycle.If by chance you are setting it up correctly and are not in mid cycle then you may have a hardware problem with the system. I would be happy to assist you if it comes to that but I am hoping that the information below will get you started,...
Copied directly from the GE website for your refererence..
Dishwasher - No Water Fill
Often the cause of a dishwasher not filling at the start of its cycle is not electrical or mechanical. Often times you may be starting your dishwasher model incorrectly which results in the machine skipping its first water fill period.
There are presently three different types of starting procedures being used:
  1. Pushbutton type. This system is found on all POTSCRUBBER models.
  2. "Turn-to-start" timer type. After latching the dishwasher door, you turn the timer dial until you hear a click. By advancing the timer dial beyond that point, its possible that the first water fill would be skipped. The first fill is necessary for automatic pre-rinsing of the dishes.
    View a short video about turn-to-start timers:
    Play Video
  3. The most common type is a "push-to-start" timer dial. All that is required to initiate the cycle is to push in on the timer dial. It is NOT necessary to turn the dial.
If you are unsure as to the starting procedure used by your model please consult the Owner's Manual. Download a free copy of the Owner's Manual and/or Installation Instructions.
Here is a link to the website too.. http://www.geappliances.com/search/fast/infobase/10001005.htm
Hope this gets you going..
Sep 02, 2008 | GE Dishwashers
GE Nautilus Dishwasher - The soap door is stuck partcially open
Advance the timer, with one hand on the dispenser door. The timer should release the door at times during it's cycle, it may need a little help, but not very hard to turn.
Jun 27, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher knob is stuck
dont turn the knob counter clockwise it could damage timer try prying the knob off it could be shoved in to tight
Dec 13, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwasher Does Not Cycle
IA, these GE pumps have a habit of sticking if the unit hasn't been run for a while. First you want to verify that the motor is in fact getting power, this will eliminate the timer. You can use a meter on the quik connect from the motor while in the wash cycle. If the motor is getting power, see if the pump is stuck by turning the motor vanes (Do this with the power off). If it's hard to turn and then frees up than this was more than likley your problem. You remove the bottom toe panel and will be able to check this out without removing the dishwasher. Catriver..post back
Dec 29, 2006 | GE 24 in. GSD2230Z Built-in Dishwasher
Dishwashers Logo
113 people viewed this question
Top Dishwashers Experts
