Question about Air Tools & Compressors
I have a 120 /230 emerson model t63bxcct 1233 on my compressor and i would like to change the 120 to 230 .what do i do?
4 Suggested Answers
SOURCE: electric compressor motor problem
Unloader valve on switch. That switch is not bleeding off cylinder head pressure,when it shuts off.
Posted on Apr 07, 2010
Testimonial: "thank you, this has had me stumped for days now. simply flipping the pressure switch off then back on again solved the problem. "
  • 1388 Answers
SOURCE: Hi. I have a Dayton Air Compressor, operated by
I have a similar compressor from grainger. Same motor as yours with 10hp speedair compressor, however a newer model. The graninger number of my pump is 5z405. and can be seen at the link below:
http://www.grainger.com/Grainger/SPEEDAIRE-Two-Stage-5Z405
If your pump looks similar then contact grainger and ask them for info relating to your serial number. Every time I call grainger for info or parts, they ask for the grainger number of the complete unit. These pumps do not change much over the years so maybe the info above will be helpful. Good luck
Posted on Mar 29, 2011
al_kupchella
  • 843 Answers
SOURCE: have a magnum air compressor
Yes. There should be a label on the motor indicating how to wire it for either voltage, something like the one shown here (which is also reversible - if yours is reversible, be sure you get the correct direction if you are going to change the wiring.) http://www.pirate4x4.com/forum/showthread.php?t=681437 The label is sometimes under the cover where you connect the wires. If not, you should be able to find a wiring diagram for it on-line once you determine the model number of the motor. Good luck, Al K
Posted on May 19, 2011
I have an Emerson Refrigerator Model No: CR286BSE and it out of nowhere it stopped working and know it is making a clicking noise and will not cool anything at all but the compressor gets hot.
Your compressor is shot, I would recommend not letting it run, it could over heat and develop a leak, the refrigerant is extremely toxic, and if it ignites creates Phosgene gas which is incredibly dangerous. IF, you can find a compressor for the model it may be worth it to replace it, or buy a new one. Good Luck!
Dec 04, 2016 | Emerson Refrigerators
Emerson mini model cr501e frig and freezer both quit working what should I check No
check to see if the compressor in the back is running. This is not easy to hear has they are really quiet. If it running and its not cooling then it is low on refrigerant, if the compressor is not running then it could be a bad compressor, or the thermostat is not working or adjusted right. Thermostat is likely located inside the frig.
Sep 19, 2016 | Emerson Refrigerators
How to remove compressor start relay and overload protector cover from an Emerson CR519BE2 compact Refrigerator
they usually just snap out or there may be a ***** to remove it should be visible
Mar 19, 2016 | Emerson Refrigerators
What's a troubleshooting code # 1233 on a ford
The problem is in the fuel system.Can you here the fuel pump cut on when you turn the ignition switch on.
Jan 15, 2012 | 2004 Ford Freestar
I have an Emerson OF200B small refrigerator. It clicks when it comes on. IS there any way to stop this?
There are rubber bushings that your compressor are mounted on and over time the rubber may break down causing the compressor to rub directly on the pan or the bracket that is holding the compressor
Jan 31, 2011 | Emerson Refrigerators
Electric compressor motor problem
Apr 06, 2010 | Campbell Hausfeld 26 - Gallon Air...
Wiring Diagram for a Emerson Motor in a Tempstar Central A/C
EMERSON 1/4 HP MOTOR 5 WIRES BLACK BLUE BROWN WHITE RED LOST MY DIAGRAM 115V1075 RPM 3 SPD HOW DO I WIRE IT TO THE COMPRESSOR
Sep 26, 2008 | Emerson Heating & Cooling
Air Tools & Compressors Logo
274 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
