Question about Tao XM2go Satellite Radio Receiver
Tao XM2go shuts off for no reason
My Tao XM2go shuts off for no reason during operation in both my car and at home. Pressing the power button will turn the unit back on. The unit may operate for several hours or several minutes but it will turn itself off again. The does not seem to be heat related and there seems to be no pattern to the failure.
  • bilshup Dec 09, 2007
    Mine does not stay powered on when I disconnect from charger. Bought new battery, no change. Not sure why???
  • mellowde Mar 07, 2008
    Mine works fine in the house but turns off frequently while driving. I assume it's a problem with the cigar lighter power plug unit or intermittent connection issue at the point of contact where it makes circuit with lighter receptical. I moved it to the other port in my truck (vehicle has two). It ssems a little better in one than the other so that may be a clue. I'm about to figure a way to hard wire this thing into my truck's 12 volt power. I would imagine taking the power unit apart and connecting wiring directly would be the way to accomplish this re-engineering. Any thoughts would be appreciated. coastal1234567@yahoo.com
    Problem Solver:
You could try taking the batteries out and cleaning the contacts, replacing the batteries and/or using sellotape to hold the batteries in place. They could be loose and disconnect when you move it in a certain way. If not the batteries, you could try further dismantling and cleaning, but you may just end up with a clean ball of sellotape that still has problems...! worth a try. stoodleysnow
Posted on Aug 30, 2006
No sound comes out of radio?
Turn up the volume by pressing the top of the center cluster of buttons. Does it work in the home dock or car dock without headphones?
Nov 23, 2012 | Tao XM2go Satellite Radio Receiver
Xm2go is not receiving
Did you try removing the battery to reset the unit?
Feb 27, 2008 | Tao XM2go Satellite Radio Receiver
My tao xm2go unit is transmitting a very weak fm signal to my car radio. I can barely hear the audio.
You likely need to directly connect. In most cases the FM transmitter is too week to broadcast through FM stations, and a direct connection will clear up your issue. It could be as simple as connecting via an Auxiliary cable or Cassette Adapter. If you don't have the ability to use one of those, you can get an Auxiliary Input Adapter. Another solution would be an external FM Transmitter, with a larger range.
Jun 26, 2012 | Tao XM2go Satellite Radio Receiver
My Tao xm2go quit working. I've tried re-setting it. I've replaced the battery, I double checked that the charger is putting out the correct voltage with a multi-meter. it won't turn on, either with the...
Try plugging the power adapter directly into the bottom of the radio without using either base/cradle - wait a minute - then see if you get a battery indication.
Jan 18, 2010 | Tao XM2go Satellite Radio Receiver
Radio shuts off for no reason w/ or w/out battery, home and car
Check "Delayed Power Off" under "Time Set" of Menu. Make sure it's off.
Sep 07, 2009 | Tao XM2go Satellite Radio Receiver
Failure of the battery to charge while in the home cradle
Wall transformer is bad or was replaced with lower amp unit. Same thing can happen with aftermarket car charger. Possible solution without replacing transformer: turn off LCD backlighting....
Sep 03, 2009 | Tao XM2go Satellite Radio Receiver
My tao xm2go will not turn on
Dear Glen,
My Tao solution is to buy the Delphi MyFi which appears to have an identical interface. See page 10 here: http://file.xm411.com/manuals/MyFiUserGuide411.pdf . This is expensive but service in not available.
digitally,
(/\/\<erwin
Nov 21, 2008 | Tao XM2go Satellite Radio Receiver
Atenna connection when using Altec Speaker or Car Kit
Dear xm2go,
I could not find any service options for my own Tao XM2go unit. The only option appears to be the Delphi MyFi unit which appears to be identical (see page 10 here: http://file.xm411.com/manuals/MyFiUserGuide411.pdf )
digitally,
(/\/\<erwin
Oct 07, 2008 | Tao XM2go Satellite Radio Receiver
Tao won't start
Dear Jim,
My own Tao unit is dying as well. Servicing does not appear to be available. The only solution I have found is to buy the Delphi MyFi unit which appears to use an identical interface (see page 10: http://file.xm411.com/manuals/MyFiUserGuide411.pdf ). What a bummer!
Digitally,
(/\/\<erwin
Jul 29, 2008 | Tao XM2go Satellite Radio Receiver
Tao XM2go Satellite Radio Receiver Logo
196 people viewed this question
Top Tao Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Tao Audio Player and Recorder Expert? Answer questions, earn points and help others
