ACER NETBOOK D255 FREEZING AND HIGH PITCHED NOISE
  • 641 Answers
SOURCE: High-pitched noise
Could you specify if noise is coming from : - The freezer - The outside back of the refrigerator - The bottom of the refrigerator
Posted on Jun 13, 2006
bigg t
  • 640 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Posted on Feb 24, 2008
aborcass
  • 2651 Answers
debris caught iside pump assy is what it sounds like
  • 11 Answers
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Posted on Jan 15, 2009
heatman101
  • 43501 Answers
SOURCE: constant high pitched noise emitting from furnace
This is probably a dry bearing in the vent motor. Those motors run at high RPM's and can make a deafening high pitched squeal if they become dry and need oiling.
Some of the motors have oil cups on them for dripping oil into and others;s are much more difficult as you need to guess where the bearing is and try to drip oil down into them or run the oil to them.
Any light weight small motor oil ike a sewr machine oil will work.
Many hardwares have small oil bottles with extending spouts made just for oiling motors for just a couple of bucks...
The other thing that can cause this is if the blower wheel is coming loose and has moved to the side and is hitting the side of the blower housing. Take the bottom cover off and check for play or movement side to side in the blower wheel. Spinning it with the power off by hand may give you a clue as you will hear it scraping the side of the housing.
Heatman101
Posted on Dec 29, 2009
My Acer aspire one D255-2301 netbook keeps restarting by itself, how do I fix this problem?
Your laptop battery needs to be replaced as they have a limited number of charge/discharge cycles.
Also the restarts are caused by overheating of the CPU, you need to clean the CPU cooler fins, best left to a professional as it involves taking the netbook apart.
Mar 23, 2015 | Acer Aspire One D255-2301
I cant open movie maker in aspire one d255
Depends on usif it's even installed... Which would depend on your Windows version. If it isn't, ups have to download Windows Live Essentials.
Sep 04, 2014 | Acer Aspire One D255 Netbook
Why my acer netbook can't detect my battery?
Is the Battery a replacement? Does it need to be replaced? SOME aftermarket batteries don't play well with your Laptop. If you need to but one ,always buy a genuine Acer recommended replacement , stay away from inexpensive replacements that are suspect. (Priced way to low) Use you best judgment.
Mar 28, 2013 | Acer Aspire One D255 Netbook
FORGOT PASSWORD TO LOGIN MY ACER D255
peform a system restore. this is a common solution.
Jan 16, 2012 | Acer Aspire One D255 Netbook
I want to know if the acer aspire one has only one speaker which is located at the left side? thank you
the Acer Aspire One D255 has stereo speakers, one on each sides. but the Aspire one D255E has only one speaker.
May 01, 2011 | Acer Aspire One D255 Netbook
My Acer Netbook AOD150 squeals during the Acer start up process. It has a very high pitched noise that is constant until the bios gets to the point that it starts to load Windows XP. What can I do to get...
what you're hearing is the hard drive spinning up. The only way to get rid if noise is to replace hard drive. Your laptop must have been dropped or bumped around where arm that tracks over hard disc is rubbing.
Jan 05, 2011 | Acer Aspire One Netbook 8.9" Notebook
I upgraded to win 7 ult. from starter fresh install on a acer d255 netbook and now i cant find the wifi driver
http://downloadnew.org/software/acer-aspire-one-d255-notebook-broadcom-wlan-driver/
scroll towards the bottom of the page...look for your chipset.
Dec 28, 2010 | Computers & Internet
Format n reset acer aspire one d255
Can anyone please help? I brought an Acer one d255 as a christmas present for someone. When we open the box, we found that the computer had been used and set up. The computer is locked with someone else's password. I need to reset the password, bcz Walmart refuse to take the netbook back bcz the computer was purchased during Black Friday and the return policy has expired. Can someone tell me how to reset the password?
Oct 21, 2010 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
