Question about Samsung WF338AAB 4.0 cu. ft. Front Load Steam Washer
Samsung wf338aaw
I am looking for the electrical wiring diagram for the samsung wf338aaw front load washing machine
SOURCE: I have a samsung front
WF316LAS
In the washer owners manual it shows "PF" code with the following explanation.
Meaning
Electric service was lost when the washer was running.
Solution
Restart the cycle by pressing the cycle selector dial.
I hope this helps a little bit.
Posted on Apr 21, 2008
SOURCE: my samsung front load washing machine wont unlock
Just turn the power of from the socket & it should just unlock.
Posted on Jul 17, 2009
  • 1531 Answers
SOURCE: How to replace the door diaphragm on a Samsung
remove the lid.then you need to take off the control panel move it out of the way.there will be a spring that holds the boot in place on the front where the door closes remove this spring the rmove the boot from the front panel then remove the front panel.there will be another spring that holds the boot to the drum.i have found it easy to remove the counter balance weights to remove and reinstall the new boot. i hope this helps sounds like alot but not real bad
Posted on Sep 19, 2009
SOURCE: Our samsung j845 front load washing machine won't
SAME THING HAPPEND TO ME, SORRY BUT YOU NEED A NEW WATERPUMP, THEY GO ON THEM WASHERS ALL TIME. I REPLACED 2 AND HAD MY WASHER JUST OVER A YEAR. NOW ITS THE DOOR
Posted on Sep 29, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
Is there available any circuit diagram for an Electrolux Front Load washing machine model EW1050F cotrol PCB part number: Procond 451513103.
Pull back cover off. Get flash light and look for brown envelope that has all the
electrical information you need
Sep 27, 2011 | Electrolux EW1000i Front Load Washer
When i switch my hotpoint washing machine on it trips the mains electric switch
Most likey a short in the motor or the start capactor is bad, however if you turn it off and then turn it on with the motor off and are just filling the tub and it kicks the breaker you may have a bd switxh or a wire has come off. to look at this machine go to www.appliaancepartspros.com amd look up the parts and wiring diagram to see if yo can figure out what your problem is. Many times a wire comes off (Spade Termnial) be sure to unplug the machine before working on it.
Nov 20, 2009 | Hotpoint Aquarius WF000 Front Load Washer
You have a blockage in the drain pump or sump on the machine, it could be anything from a coin, bra wire or an elastic band, best thing to do is switch off the electricity and incoming water, remove as much water from the machine as possible, pull machine out place a suitable container below the drain filter and then open up the filter (if fitted) once cleaned check hoses and drain pump internally for blockages.
Sep 07, 2009 | Samsung WF337AA Front Load Washer
WIRING DIAGRAM FOR A FRONT LOADER WASHING MACHINE
go to macspares.co.za
They have couple of diagrams
Aug 13, 2008 | Washing Machines
I have front load wasching machine Wf810w
open the front panel 3 screws on the bottom there is a pump clean out plug it is most likly clogged with somthing i am not sure what board you are talking about but this is the first place you should look. One other thing the resistor valve wont be on the wiring diagram the whole board will need to be replaced hope this helps
Jan 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Samsung WF338AAB 4.0 cu. ft. Front Load Steam Washer Logo
44 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
