Question about Microwave Ovens
Broken spring on door Neff H5972N0GB
How do I take the door off
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave door hook broken
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Posted on Dec 02, 2007
I have a NEFF H5972N0GB. I am trying to change the language from german to english. Can anyone help?
1. Press and hold the "M" memory button for 4secs approx. until "Sprache" appears in the first line, and "deutsch" appears the the second line of indicator screen.
2. Press the button with the two triangles on each other to highlight "deusch"
3. Use the function selector to choose the required language
4. Press the "M" once to save the selection
5. Language should now be in your required language
Apr 08, 2013 | Neff Microwave Ovens
Broken Neff microwave hook for tension spring on door. Can I reconnect spring to metal frame or will there be too much tension?
If you very carefully prise off the inner trim of the door you should be able to see where the lug broke that was originally holding the screen. Use a small cable tie to fix one end of the spring to one a the angle pieces of metal around where the window is, about the same level (make sure the other end of the spring is on the hook assembly). You can secure the cable tie and adjust how tight you pull it to get to roughly the same tension it would be if still on the original lug. Cut off the excess of the tie and clip the frame back in position. Door should open and close now.
Hope this helps
Mar 28, 2013 | Neff H5430 Convection Microwave Oven
Neff H7871 oven door does not stay closed. Catches do not appear to be working
The door latch is either cracked or broken.The door when gets closed the door latches clicks.But if the door latch is loose or cracked it will not click and door will not close.The door needs to be disassembled and the door latch has to be replaced, if the latch is cracked.Also to check the latch from inside the door needs to be removed.-------- This will help.thanks.Helpmech.
Jun 29, 2011 | Neff Microwave Ovens
Neff h5972n0gb keeps cutting out after 5 seconds, any idea what the problem could be please. Thank you
Is it cutting out while working as oven or microwave or just after 5 seconds of switching on ?
Mar 13, 2011 | Microwave Ovens
NEFF H5430NOGB Integrated oven - door won't close, the ;hooks on the door itself seem to have gone loose so they ill not clikc inot place when trying ot close, door just flops open.Amy ideas???
I had this problem. The spring inside the door which pushes the the latches down had broken (plastic peg had broken off).
I managed to fix it by attaching the broken end of the spring to the door frame using a small nylon cable tie using the small hole in the plastic fingers which was already there. Note you need to remove the inside door surround.
See the following link to remove the plastic cover on the door
http://www.fixya.com/support/t1267577-replace_front_glass_door_neff_microwave
I had an interim solution which was to tie some thin string to the latch and feed it under the door and pull on the string when closing the door (when it should be latching.
It was
Dec 06, 2010 | Neff H5430 Convection Microwave Oven
I need to change the door catch, so how i take the door apart to replace the catch ??
if you mean the door hook inside the door this is quite easy you need a flat small bladed screwdriver to split apart the plastic inner part of door from the outer keep working around till you have released all the catches there are several, the inner skin will pull away revealing the hook and a spring the hook just slides out refit new hook with spring and reassemble. easy.
Jun 04, 2010 | Neff H5642 Convection / Microwave Oven
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Oct 27, 2008 | Neff H5470 Microwave Oven
Neff microwave combination oven
no solution sorry but we also have a Neff mw/combi oven which keeps blowing for no apparent reason, the Neff repair man has looked at it 4 times and practically replaced every component -power module, operating module,relay board, door switches but it`s just gone again! The model is a H5972N0GB/01 and it is approx 3 yrs old, no problem for the first 2 years .Time to write to Neff -is yours the same model?
Apr 23, 2008 | Microwave Ovens
Broken door hook
The plastic cover on the inside of the door is purely push fit.
To force it off I used 2 strong stainless steel dinner knives.
By easing one knife between the internal glass and the plastic cover I managed to spring one corner by using the other knife on the external bottom edge of the plastic cover.
Try concentrating on one end and once this springs out it is easy to free the rest without having to take it off completely.
The hook is simple to do but be careful with the spring.
All in all it took 3 minutes!
Jan 13, 2008 | Neff B7740N0GB Microwave Oven
Oct 20, 2007 | Microwave Ovens
Microwave Ovens Logo
115 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
