SOURCE: how to fit a belt on a tumble dryer
unplug the dryer,
220v is not fun
dryers are generic inside, regardless of maker
while you got it apart to replace the belt is a good time to clean out exhaust vent pipes and the squirrel cage fan, no lint, better air flow, less $$ to run
the tensioner may push Up on the lower run.
put front panel back on, plugging in door switch
plug in mains
dry clothes
takes longer to type than to do
SOURCE: Problem with Indesit tumble dryer
could be a switch in there or one of these
This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
SOURCE: how can i fix my indesit is70c tumble dryer?
open the back panel , not the the full back just the smaller panel located near the bottom half.
the termo will be screwed onto this panel . unscrew and you will see two circles near the top one will have a small pin hole in it . stick a pin in till you hear a click replace and should work fine
SOURCE: i have just bought an
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
SOURCE: how do you remove the
This easy to use white Indemnity condenser dryer will make a welcome
addition to any kitchen. The 10 minute cool tumble and reverse tumble
option will help keep creases in your fabric to a minimum. Energy
efficiency ratings & performance: Energy efficiency rating: C.
Maximum drying capacity 7kg. Condenser dryer features: 160 minute
timer. Including 10 minute cool tumble. 2 dryness levels. Manual
control. Reverse tumble option. Reservoir full indicator. Fluff filter.
Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle.
Manufacturer's 5 year parts and 1 year labour guarantee. Technical
specifications: Energy consumption: 4.48kWh per cycle based on dry
cotton cycle. Energy consumption: 336kWh per year based on dry cotton
cycle.
please comment on my post or vote for the solution.
