Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Compressor not running
Kenmore coldspot 2003 model side by side, found a part attached to the compressor that seems brunt inside. Was this caused from a bead compressor?
    Scholar:
  • 112 Answers
This is the overload/relay assembly. Although a burned up overload can sometimes indicated a defective compressor, in most cases you can fix the problem by replaceing the overload/relay.
Posted on Oct 28, 2008
Kenmore coldspot 106.53769202 will not cool fridge, have deg=frosted,vacuumed underneath and emptied drip pan, no air blowing into fridge. Had gnats inside while power was off for over a month.
Does the compressor run? Does the small tube get warm? is the inside fan working? does it have an outside condensor fan? Is power getting through the thermostat due to gnats between the contacts? Does the inside light work? need more info.
Oct 16, 2013 | Kenmore 50522 / 50524 Side by Side...
I have a Kenmore Coldspot Side-By-Side. My wife said her ice Cream was to hard so she turned the left freezer knob down one number. Now the whole Refrigerator quit working. The compressor is running but...
either the cold control is bad now or the ptc overload on the compressors bad you can bypass the cold control to check if the compressor starts then if so just replace this control
Aug 07, 2011 | Kenmore Side by Side Refrigerator
Side by side unit not working on both sides
Check your modeel number again as I can not locate the model you gave.
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • Let me know and I will help you find the problem, Thanks, Seabreeze
Mar 26, 2009 | Kenmore 51572 / 51574 Side by Side...
Kenmore Coldspot Side by Side Model 51559101
Unplug the Ref for 15-20 min., plug it back in and listen for the compressor to start. You will need to be behind the Ref so you can tell if the compressor or the fan is running. It will help to take the cover off so you can see the compressor.
Compressor not running but you hear a clicking noise. The relay needs to be replaced.
Compressor runs but not cooling. Low on coolant
Feb 06, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore Coldspot is on but not cold after power blackout
The reset is called a klickson it is inside that black cover on the side of the compressor.
sometimes they do fail.
Dec 28, 2008 | Refrigerators
What size is this fridge?
there is a sticker some where inside that will tell you cubic feet
Dec 12, 2008 | Kenmore 53542 / 53544 Side by Side...
Kenmore coldspot model:10653502330 does not stay cold
hi thanks for the question i would check the back by the compressor make sure its clean . then check the fan in freezer to see if it works then see if the frost built up in freezer you could have just a dirty condenser thanks the appliance doc
Sep 08, 2008 | Kenmore 53642 / 53644 Side by Side...
I also have the same refrigerator model 106.56566400 and periodically when the power goes off in the house the refrigerator & freezer will stop cooling. Try pushing the on/off button located inside the refrigerator to the left of the digital temperature controls. Hold the button down, this turns the unit off, then press it again to turn it back on. This basically resets the refrigerator, and most of the time works to get the refrigerator cooling again. Try this first before calling a repair man.
Nov 22, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
269 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
