Question about Kodak EASYSHARE 5100 All-In-One Printer
Window glass the glass base were I put the paper for scan or copy is broke I jus want to know if I can replace or I have to buy a new one
    Genius:
  • 1,605 Answers
You need to buy one. unless your local glass shop can make you one. (you still need the sheild around the glass.
Posted on Oct 28, 2008
KHOW DO I GET THE PRINTER TO MAKE A COPY OF SOMETHING
No make/model, so here's a generic method:
[based on Samsung Multi-function]
Presuming printer is a MF unit:
Place paper-to-copy face down on the flatbed glass.
Close lid.
Ensure blank paper is correctly loaded in feeder tray.
For a once-off direct 'photocopy':
Press COPY on printer .
For copying (scanning) to a file:
Printer on, drivers installed, blank paper loaded, original on flatbed.
At computer, go to Start.
In search-box type in scan
Left-click magnifying glass to confirm search.
You should see Scan a document or picture appear in icon list.
Click this.
A scanning window should pop up:
Oct 11, 2017 | The Office Equipment & Supplies
Tip
Black lines on faxes or copies
Do you have black lines in your scanned or copied documents? The typical problem is ink, correction fluid or trash blocking the image sensor. Look at the picture below, the image sensor is marked by the gray box. Use a paper towel dampened with window cleaner to clean this glass strip. Do not spray windows cleaner on the glass just the paper towel. Gently scrub the glass to clean off any trash or marks that may be there. Let the glass dry for a few minutes and then try to copy or scan something.f86a7c5.jpg
You should have a clean copy now. If you have any questions you can contact us at: tech@ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
on Dec 14, 2009 | Office Equipment & Supplies
We have a Canon Image Class MF5900. When we put items through the feeder on the top of the machine to feed through for either copying or scanning we get the copies/scans but they also have line through...
Yes, this machine has what the call a scanning glass.Its the small thin glass where the paper goes down through the doc feed.its on this glass. A real close visual or take a clean piece of paper. Wad it up a and clean glass with that paper. It works. But if you don't have a line when you print or from the platin.(glass,main).its on that reader glass.
Feb 13, 2015 | Canon Office Equipment & Supplies
When I copy papers on my Canon imageRunner 2800 there are 2black lines in the middle of the copied paper. How do i solve this problem?
Hello mike,
You may have a fairly easy problem to fix, and that's good thing ! If the lines only appear when you use the document feeder then we can handle this. Please place a document on the platen glass and make a copy. If the copy looks good then we need to clean your "scan" glass. The scan glass is the small glass located to the left of the large platen glass. It's about 3/4" by 14",and will only cause problems when you use the automatic doc feeder.If it gets dirty then thin lines will show up. If indeed this is the problem then I have a test u can use that will help you Take a plain piece of paper. Mentally divide it into 4 squares and then simply write the numbers 1,2,3,4 on each quadrant. At the top edge of your newly formed test document place an arrow pointing away from the body of the paper, and it needs to point "UP".. Now draw an arrow on the test document that points to the left "lead " edge. Put your newly constructed test target in the document feeder and make a copy of it. Now, you KNOW how you placed the test document, so lets look at the copy. If you have lines only thru the document feeder, then look at the copy you made and notice where the lines are. Ok, now you know where the lines show up on the copy, so lets take your "test" document and compare them side by side.Once you have made this comparison, and can see where the lines show up, take the ORIGINAL test document and place it IMAGE UP (1,2,3,4) on the glass. This will point out exactly where the dirt is. By looking at the copy that has lines, and where they show up on the page, you can use the test page that is laying face up on the glass and compare the 2. BOOM !! You can look towards the small scan glass and find the dirt that is causing the lines. With your copier, IF you place a document on the glass then the scanner moves to "scan" the document. But if you use the document feeder, the scanner stays in one spot and the motion of the document moving ACROSS the scanner and is scanned like a bar code. If there is dirt on the scan glass then a line occurs instead of a "blob" as you would see if you used the platen glass.I hope this all makes sense (I tend to ramble) and I hope it helps you. You of course could have far more complex problems. But your description of the problem sounded like my remedy/idea might be just what you need. Take care and good luck. if I helped you please let "fixya" know. SPINAL
Apr 02, 2011 | Canon Office Equipment & Supplies
I can not copy from glass scanner of HP L 7680 all in one, when I load paper into the lid then press copy, printer just load paper in ADF not run copy from glass scanner
Is your system on? If it is on, then you press copy, it scans it and a window showing your scanned document is displayed. Then from here (the system) you can print it. Try it and tell me what happens.
Dec 08, 2010 | HP Officejet Pro L7680 All-In-One Printer
Single narrow black vertical line about 1 3/4 inches from right side of copy. Line runs the entire length of the copy. Happens only during copying color or black and white.
The line issue is caused by something on the image sensor. To get to it and clean it just pull the front up where you put the paper into it to scan. Inside you will find a glass strip, this is the image sensor. Use a paper towel dampened with window cleaner and gently scrubbing the glass strip, After cleaning the strip let it dry for a minute or teo before you close the cover and try a scan. It should be clear and should copy great again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
Jun 18, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
Black line down center of paper while using manual feed
I had this issue once before on a Canon Multifunction printer and when I talked with Canon they said it was a malfunctioning scanning bed. They sent out a new one and I replaced it and had no further problems.
Jun 18, 2009 | Dell 1600n All-In-One Laser Printer
Scanning
Open the top Auto Doc Feeder. (The area where you insert the original to copy) It lifts up when pulled up gently but firmly. You will see a strip of glass. Clean the glass strip with Windex or alcohol on a paper towel or rag. Put the cleaner on the rag, not sprayed on the machine so it doesn't get on unwanted areas. Carefully examine the glass as you have smudges of ball point pen or white-out on the glass.
It appears as a line because the paper is moving past the fixed scanner and it can scan through whatever you have on the glass.
Hope that helps you. :)
Sep 30, 2008 | HP LaserJet 3050 All-In-One Printer
Re Smeg 60cm electric oven model SA370 EB/1. I need new door glass and rubber seal for glass door.
I have one for sale I am jus putting it up on ebay buy it and replace yours.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=110291356746
Jun 23, 2008 | Smeg Kitchen Ranges
Kodak EASYSHARE 5100 All-In-One Printer Logo
62 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
