Question about Texas Instruments TI-Nspire Graphic Calculator
Stuck ti-nspire keyboard
My keyboard is stuck and whatever I go to it types wqke.
  • 4 Answers
SOURCE: Can keypads only for the ti-nspire be purchased?
http://epsstore.ti.com/OA_HTML/ibeCCtpItmDspRte.jsp?section=11092&item=76072&JServSessionIdrootdlek22=umke2gv3m1.n6LzoN8M/AzOnMTOogTxpQOUtxCLbx0Ka0--
Posted on Jan 25, 2009
SOURCE: TI-nspire will not turn on
Yes we changed out the batteries on now the TI-84 will not turn on HELP
Posted on Nov 25, 2009
  • 8073 Answers
SOURCE: TI-Nspire 84 Plus keypad problem
Remove the TI84 Keyboard, insert the TI-Nspire keyboard and try to reset the calculator with a starightened paper clip.Calculator has a reset button on the back.
Posted on Feb 01, 2010
  • 24 Answers
SOURCE: I have issues turning on my TI-Nspire using TI-84 Plus SE keypad
i would say use the normal key pad or send it in to T.I to fix.
Posted on Mar 12, 2010
  • 12 Answers
SOURCE: I downgraded my TI-Nspire's OS
I had this same problem myself and I had to look everywhere to find a solution. You will have to remove the current OS from your device. Heres how.
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=101985&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZGC81E19298A9321E38D51491551F331C8CCDA6801E50CC672F84B3EFDF0F6ACEF9DD42026E6C2FF1F9579670CF87CEAF79D
I couldnt use option 2 for some reason and had to use option 4 (complete format, luckily I had backed the files up earlier) but once it was reformatted the device showed up in the software and told me to update the OS. From here you just install the latest OS as you would normally.
The problem with what you and I did is that previous OS versions (1.7 in my case) dont support the keypad, you may be able to use the older version with a different keypad but I'm not sure.
Anyway, I hope you can fix it, good luck.
Posted on Jan 08, 2011
How do i install the ti-84 operating system to the ti nspire
You do not. The TINspire with TI-84 keyboard works as a TI-84 Silver edition. Its OS is update when the TINspire OS is updated. The Ti 84 OS's you find on the TI website are not for the TINspire with TI84 keyboard.
May 12, 2014 | Texas Instruments TI-Nspire Graphic...
I am own a Ti-nspire and trying to download the latest Ti-84 silver plus os however when it begins to transfer to my calculator it says transfer error what can i do to fix this?
The standalone version of the OS for the TI84Plus/TI84Plus SE are not for TI-Nspire with TI84 keyboard. The 94 Plus part of the TI-Nspire is updated when you update the OS of the TI-Nspire. The version numbers are different.
To update you TI84 portion of the TI-Nspire, update the OS for the TI-Nspire. Thy are now at Version 3.2.3.1233
Sep 26, 2013 | Texas Instruments TI-Nspire Graphic...
Os transferring error
Sep 26, 2013 | Texas Instruments TI-84 Plus Silver...
TI Nspire CX keeps rebooting?
This is the easiest way to fix a restarting TI nspire cx cas!!
Just follow my simple tutorial, I had the exact same thing:
https://www.youtube.com/watch?v=mEYRWhMNGn8
Jan 27, 2012 | Texas Instruments TI-Nspire Graphic...
I am going to be getting a tinspire and I was wondering how you switch from ti-nspire mode to the ti-84 mode?
I am going to assume that you are buying the non-cas version as the Cas or computer algebra version of the nspire doesn't support the ti-nspire mode.
The tinspire will come with two key-boards. One will be the nspire keyboard, the other the ti-84 board. To switch between them there is a small toggle on the back of the calculator. Push the switch and the keyboard will pop out. Put the ti-84 keyboard in and then press the on button!
Cheers
Sine Wave
Apr 09, 2011 | Texas Instruments TI-Nspire Graphic...
I just got the TI-Nspire. I'd like to solve a problem with undefined variables using Negative Exponent and things like the Expanded Power Rule. The Nspire will not let me store "x" as a variable. How...
You need the TINspire CAS (Computer Algebra System) to do symbolic manipulations. The Blue TINspire (with TI 84 keyboard) can only perform numerical computations.
If you use variables, the calculator will assign the numerical value stored in the variable.
Aug 17, 2010 | Texas Instruments TI-Nspire Graphic...
The calculator crashed two times several days ago while I was using it. It worked fine the following day, but after that the screen became very dark. So dark that I need a flash light shining at it to see....
I will address one part of the question only: I will avoid the speculations.
How to change the screen contrast
  1. (TI-Nspire with native keyboard): With the TI-Nspire keyboard in place,
  2. Press the ON button to turn calculator ON.
  3. Press and HOLD the Control key [CTRL]
  4. Press [+] to darken the screen
  5. Press [-] to lighten the screen (Your case)
  6. Stop when contrast is adequate.
  • TI-Nspire with TI84PLUS keyboard: With the TI84PLUS keyboard in place
  • Press the ON button to turn calculator ON
  • Pres the [2nd] key and RELEASE it
  • Press the [UpArrow] of the NavPad to darken
  • Press
Feb 15, 2010 | Texas Instruments TI-Nspire Graphic...
I had not used the calculator in a year. I replaced the batteries. The calculator will not turn on.
Here are some quick tests.
  1. Verify batteries are correctly inserted (I have to rule this out) and that the polarity diagrams are respected.
  2. Try to turn the calculator ON with the TI-Nspire keyboard and with the TI84Plus keyboard.
  3. With the TI84Plus keyboard in place, try to adjust the contrast of the screen by
  • pressing the [2nd] key and releasing it.
  • Then press [UpArrow] to darken the screen if it is too light OR the DownArrow if screen is too dark.
If you fail to get any meaningful response from the calculator, put the TI-Nspire keyboard in place/ Make sure you do not press the ON key (put the slide cover to protect screen and keyboard) and press the RESET button on the back of the calculator. For that, use a straightened paper clip.
If all fails, I suggest you reinstall the Operating system. The procedure is detailed in this article.
Feb 09, 2010 | Texas Instruments TI-Nspire Graphic...
Jan 23, 2010 | Texas Instruments TI-Nspire Graphic...
Ti 84 nspire,replaced batteries and now it says "operating system not found,install OS" Of course my son has a finals exam tomorrow..help!!
Hi
A. Download the TINspire OS from education.ti.com
Use the Ti-Nspire computer link to reload the OS onto the calculator.
  1. Remove the Ti84 keyboard and insert the Ti-Nspire keyboard.
  2. Make sure the battery are good.
  3. Connect the TI-Nspire device (with the Nspire keypad) to the computer using the USB Standard A to Mini B cable
  4. Run the Ti-Nspire computer link software.
  5. The select device dialog should appear, and detect the device.
  6. With the mouse cursor, select the OS, drag it and drop it on the main window (file browser window) of the TI-Nspire computer link software.
  7. Alternatively, click the menu Tools and select Install OS. A Select file window opens.Use the browse button to point to the OS and click Open/OK
B Installing from another Ti-Nspire ( not a TI-Nspire CAS) if availabe)
  1. Connect the two devices using the USB Mini A to Mini B cable
  2. The end marked A should be inserted into the sending unit, while the end marked B should be inserted into the receiving unit.
  3. Both units must be turned ON
  4. On the sending unit, access the document chooser by pressing [Home](the house icon).
  5. Once in the document chooser, press [Menu] and choose 9:Send OS…
Hope it helps.
Thank you for rating the solution.
Dec 11, 2009 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-Nspire Graphic Calculator Logo
1,126 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
