Question about Kodak Office Equipment & Supplies
Why does the paper keep jamming in the esp office 2100 series
Paper feeds in but jams when its pulled back in to print
  • 167 Answers
SOURCE: HP 1020 Issue
Pls check the fusing assembly,something might be stuck or the flag of paper jam sensor might be broken or could have come off.
Happy printing
OMNIPRESENT
Posted on Oct 17, 2007
SOURCE: ESP 7 paper jam error
I had the same problem, but after pressing the OK button when the paper jam came up again I pressed the CANCEL button and was able to print my document. See if that works for you too.
Posted on Apr 12, 2009
  • 72 Answers
SOURCE: HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Posted on Jul 22, 2009
SOURCE: not printing glossy A4 paper / paper jam / no paper feed
dont use thick photo paper like 230 gsm up, instead use 180 gsm papers. but if you dont want to waste the purchased thick photo papers, you can open the back and manually insert the paper once the printing process started. i tried this as a trial & error basis until i had perfected it.... hope it works with yours.
Posted on Aug 17, 2009
  • 25 Answers
SOURCE: I had a paper jam and got the paper out but still shows E2
E2-2 = No paper (ASF)
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error (bagian cleaning head)
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = ink absorber full or platen waste ink absorber full > reset dengan toolsnya
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
which error message exactly your printe show?
Posted on Sep 19, 2009
ESP Office 2150 all-in-one
Shows paper jam. no paper in machine
Apr 11, 2016 | Kodak Office Equipment & Supplies
Paper wont feed
Paper not feeding in all-in-one printer - Kodak
support.en.kodak.com/.../paper-not-feeding-in-all-in-one-printer
KodakPaper not feeding in all-in-one printer. Published 10/19/2010 04:38 PM ' Updated 09/23/2014 01:38 PM ' Answer ID 19640. What should I do if the paper does ...
Basic troubleshooting - Kodak
resources.kodak.com/support/shtml/en/manuals/.../urg01238c11s1.shtml
KODAK ESP Office 2100 Series All-in-One Printers - Extended User Guide ... If you experience an error with your printer, restarting your printer will ... For wireless connectivity issues, go to www.kodak.com/go/inkjetnetworking. Carriage ... If thepaper is not stacking properly in the output tray, remove the pages as they exit.
[Solved] Kodak ESP Printer Paper Jam - YouTube
? 20:50
https://www.youtube.com/watch?v=jpkitdHmkuc
Aug 15, 2014 - Uploaded by Sabretooth Barnacle
This is probably a common issue amongst all Kodak Printers. ...thanks for the video, these same instructions worked on theKodak 2150! ... What do you thinkthe pproblem is, Kodak offered me another one for ... the printer realises they don't match so rejects the paper until you feed in the size it's expecting.
Paper won't feed on kodak 2150 printer - Fixya
Dec 21, 2015 | Kodak ESP Office 2150 All-in-One Inkjet...
My Kodak printer wont grab the paper in the paper tray
Amandasplace:
There is a sensor that is located where the front edge of the paper sits when you load paper. If you take all of the paper out of the feed tray and use a flashlight to look in the throat of the paper feed area, you should see a small piece of plastic (in the shape of a blade) sticking up. If you do not see that sensor flag it may be broken off, or there may be a small piece of paper jammed against the sensor flag, keeping it from moving downward when you load the paper tray. That can happen if you pull a mis-fed piece of paper out of the machine in the opposite direction that the paper normally travels when printing. When you load the paper in the machine, it pushes that sensor flag down, telling the machine that there is paper loaded. either the sensor flag is broken off or there is something jamming the paper sensor, keeping it from being pushed down by the paper.
Nov 23, 2012 | Kodak ESP Office 2150 All-in-one Printer
Paper jam
You are receiving this error message because there is a paper jam or the top (photo) tray is not securely in position and the printer cannot initialize. This error message can appear for an ESP 7, ESP 9, ESP 7250, or ESP 9250 all-in-one printer.
To resolve a paper jam, we have an easy Step-by-Step Solutions and Repair tool. Within the tool, select All-in-one printer, then Paper jam.
When you clear the paper jam:
  1. Make sure you open the paper output tray and inspect the top tray for photo paper that could be jammed inside or that remains in the nip at the entrance.
  2. Pull out the bottom paper tray and clear any paper jams.
  3. Remove the duplexer from the back of the printer and clear any paper jam.
NOTE: Curled photo paper could induce a paper jam. To prevent curling:
  • Store un-printed paper in a tightly closed plastic bag or in its original packaging.
  • Store sealed packages of paper flat, and not on
  • When you are ready to print, take only the paper intend to use immediately.
To remove curl in photo paper:
  1. Place the paper in a plastic bag or in its original packaging.
  2. Gently bend the paper in the opposite direction of the curl, then insert it into a tube-a paper towel tube works well.
    NOTE: The tube should be larger than 1.5 in. (4 cm) in diameter.
  3. After a few minutes, remove the paper from the tube.
  4. Remove the paper from the plastic bag or packaging.
  5. Verify that the curl has been removed from the paper. Repeat the steps above if necessary.
If the top paper tray is not securely in position and the printer cannot initialize (you may hear a grinding noise, and the top paper tray will not open), contact Kodak.
Nov 02, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Cannot printer... it keeps giving me out of paper error, even when there's paper in the tray.
Sir,
Try these steps it may be solve your problem...
Step 1. Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step 2. Turn off the printer.
Step 3. Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step 5. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step 6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step 7. If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step 8. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step 9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Thanks
Good Luck
Aug 04, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jamming in printer. Pulling one side before the other causing it to jam... Brand new, bought Sunday
Answer:
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
1.Turn off the printer.
2.Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
3.Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
4.Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
5.Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
•If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
•Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
•Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
•Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
•Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
Jun 24, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
My Kodak ESP5 keeps saying "Paper Jam please remove paper jam" But there is no paper in it?
My esp 5 gave me this same message. I'm not an expert but here is what worked for me.
I turned off and disconnected both cables (usb and power) then reconnected and turned on.
At this point it still read paper jam, so I took ink cartridges out and paper out.
I then reinstalled ink cartridges and PULLED OUT THE PAPER TRAY to it's FULL capacity, added about 5 sheets of paper, and on the main menu I chose the allignment function and printed a test page and suddenly....no jam!
Hope this works for someone. For some reason pulling the tray all the way out cleared the "jam" message for me. Now if I could just get the new ink cart to work I'd be all set! Good Luck!
Dec 20, 2008 | Kodak ESP 5 Printer
62 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
