Question about Amana ALW480DA Top Load Washer
How do i remove the top panel on a amana lw8303l2 washer
4 Suggested Answers
SOURCE: im trying to replace the outlet hose it goes into
I just opened mine... the top does no good... you go through the front... two screws on the bottom... then 2 screws on that pannel... you can reach the pump from there and feed the hose...
Posted on Feb 23, 2009
  • 1122 Answers
SOURCE: I have water coming from the bottom. How do I take
remove the 2 bottom front panel screws-mike
Posted on Jul 29, 2009
  • 125 Answers
SOURCE: can't remove front panel on Amana washer
access through the back panel about 10 screws. Its likely the drain pump or one of its hoses.
Posted on Aug 23, 2009
Amana washing machine (ALW880QAW). Does not work in spin cycle. Washer works ok in wash cycle, and in draining water, just the new belt is too loose when it switches to spin. It just burns up the belt....
probably the lid switch is faulty,remove screws behind control panel,then pull control panel toward you and lift up and lay back,now remove 2 screws in the lower front panel by the floor and remove the cover,then 2 more screws to remove upper front panel above the lower one,then 2 more screws in front hold the top on then raise top up like a car hood and the lid switch will be under the top cover
Mar 23, 2011 | Amana ALW880WH Top Load Washer
Amana LW8303L2 will not spine
http://www.washerhelp.co.uk/washing-machine-repairs.html
http://www.repairclinic.com/Washing-Machine-Repair-Help
Belt replacement on these is a slightly intimidating job to the uninitiated, but possible.
http://www.american-appliance.com/se...stic-Chart.htm
http://www.applianceaid.com/amana-wash.html#belt
Lots of pictures and help at these sites.
Main thing is use ONLY the factory-authorised replacement belt on these. It is designed to have the right amount of slip/grip to enable your washer to work properly. This is CRITICAL on Amanas.
Apr 14, 2010 | Washing Machines
Can't remove front panel on Amana washer
Aug 23, 2009 | Amana ALW480DA Top Load Washer
HOW DO YOU OPEN THE WASHER TO TAKE A LOOK AT WHAT IS GOING ON?
most washers after you remove the back control panel the top panel will pop off.  You may need a small screwdriver inserted in the panel gap to facilitate the process.   Also the back will remove after you remove a few hoses and a few clips.
Mar 29, 2009 | Amana DLW330RA Top Load Washer
Amana Washer LWA50AW doesn't spin
Ifi t does not spin it may be the timer. Try it in the delicate cycle to see what happens. Actually try all teh cycles to see if it spins in one of them. IF so it most likely is the time and is a 15minute job to replace.
Feb 26, 2009 | Amana ALW480DA Top Load Washer
Belt amana washer replace mod lw6501w2
I have a similar amana top load washer and just changed the belt. Here are the steps I used to change the belt:
1) Unplug the washer
2) Slide the washer away from the wall about 12"
3) Remove two screws from the bottom of the front panel, slide the front panel down (there are 2 metal tabs that slide into slots on the top of the front panel - observe how they slide into/out of the slots). Set the panel aside.
4) Remove the electrical connector (upper left of motor). Press down on the top of the plastic connector - this will undo the catch hook holding the connection in place). Observe how the belt is routed before proceeding.
5) Remove 4 bolts holding the motor in place. You can remove the motor - even with the water pump and hoses in place - they will flex.
6) Remove the water pump from the motor. There are 3 torx - head screws to remove. Note: You will need a star shaped (torx) head driver (Looks like a screwdriver but with a "star" head on it. The one I used measured just under 3/16 in diameter.
7) carefully remove the water pump. - remove the old belt from main pulley under washer drum and also from the water pump. Insert the new belt - be sure to put the tension pulley on the outside of the belt.
8) Reinstall the water pump to the motor. Reinstall the motor. Route the belt correctly in the water pump body area first - them slide the belt around the left side of the main drum pulley - rotate the pulley counter-clockwise and the pulley will tug the belt onto the pulley. Once in place - check bolts and belt - then reattach the electrical connector (remember to press the plastic lever on top of the plastic connector before sliding it in place). Reattach front panel - slide the top of the panel onto the metal tabs - then attach screws at the bottom.
Feb 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Im trying to replace the outlet hose it goes into the back how to remove the the top panel iys a amana top load washer
Feb 22, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Diagram of installing belt on amana washer
show diagram on how to install a belt for Amana washer model number ALW410DAW Serrial number 0006303339
Nov 02, 2008 | Amana ALW480DA Top Load Washer
Amana NAV5800 - How do I take off the lid/cover
Jon,
There should be two screws at the bottom of the front panel. Undo these screws and the bottom of the panel should swing out. The top will be held by clips or pins that will release as the bottom of the panel moves out. I suggest you lay a folded towel on the floor to prevent chipping the enamel finish when the panel drops free.
By the way, please ensure the machine is unplugged before you attempt any work on electric appliances.
Good luck
Bob Thompson (Australia)
Dec 22, 2007 | Amana NAV5800A Top Load Washer
Amana ALW480DA Top Load Washer Logo
37 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
