Since i just mess around with amplifiers i have a new one hooked up to a battery charger and it will make wierd sounds and then cut off
  • 1,512 Answers
Hey trevor
If its car amps yo messing with, you need to drop a car battery(even a suspect one will do it) across the charger as well to "tank" the ripple off the power from the charger. Even though the charger is DC, it is what we call unsmoothed, providing power that is like pulsed DC power. Most chargers are also not that high power and will sag when you crank up the amp. The battery will provide enough juice to carry the current drawer This is exactly what I use in the past for repairing high power amps on the bench. If you have any questions, happy to help you out. Cheers
regards
robotek
Posted on Oct 28, 2008
Phonic max 860
Check your speaker wiring, looks like you have a short somewhere and the amp is going Thermal. Use a tester, if the cables into the amp read below 4 ohms you are in overload. Blessings...
Aug 15, 2014 | Phonic Audio Players & Recorders
Hi, I own a lightning audio B300.4 amplifier, it is hooked to battery and grounded to boot with same. Remote cable from headunit is hooked up. All of these cables are in the right places and nothing else...
sounds like amp is grounded. use a multimeter with ohms and test from pos to neg, should be o.l if there is any reading or resistance there the amp is grounded and junk
Feb 19, 2010 | Car Audio & Video
New amp
Something is def. wrong. did you check the fuses on the amp after the light went out? probly have a bad connection somewhere. check ground wire and power make sure they have a good connection and arent cut up and shorting out.
Oct 21, 2009 | Pioneer Car Amplifier GM-7100M - Mono Bass...
Car wont start-not a gig
it sounds as if you might have to replace the battery, if your battery is shot you can still get a boost and the car will run because the alternator produces electricity which should take car of the cars functions and top up the charge on the battery. if the battery is no longer taking the charge or not holding it as soon as you shut it off it will not have enough power to start the starter. A lot of automotive place will do a check on your battery if you take it to them.
please note that i'm not a mechanic and this is just based on my own experiance
Feb 12, 2009 | 1995 Pontiac Grand Prix
Problem with battery or battery connection or alternator
sounds like the altenator or voltage regulator
Jul 09, 2008 | 1993 Ford Tempo
No sound?
Check the outputs on the stereo. Maybe there's no audio signal going to the amp.
Mar 24, 2008 | Crunch Powerzone P2200 Car Audio Amplifier
Amp cuts out at certain volume
is the output signal distorted? if not one of the subs could be damaged subs are capable of playing even when damage ,try them 1 at a time to see what happens.
May 17, 2007 | Kicker 04KX350.2 Car Audio Amplifier
Me just asking
I need more to see what your problem is ??? what you mean you had a cap attached to it and almost caught on fire.?? and why would something inside be touching?? have you had the unit open?? as parts dont ussally move around and "touch" all by themselfs Please respond back with more info!!
Mar 25, 2006 | Hifonics Brutus BX 1605D Car Audio...
26 people viewed this question
 Grubhead
Grubhead
