Question about HP Officejet 5610 All-In-One InkJet Printer
Cleaning of printer
How to clean HP Officejet 5610 All-in-One Printer because my ink will only last for 3 to 5 days even if it is a new ink cartridge?
  • 849 Answers
Clean can improve the print quality not the quantity, this is the matter of use that how much u use ur printer if u printer lot of papers in a day then it will last only for one day.
Posted on Oct 28, 2008
Hp office jet 5610 wont print colors correctly
Some printer software that detect ink levels won't recognize a cartridge that's been refilled. They treat the cartridge as empty although you've filled them with ink. You can try removing the HP software that pertains to the printing functions only (not the scanner abilities). You can also do a Power reset. Remove the printer cartridges, turn off the power, remove both the Power cord and USB cord (if applicable) for 10 minutes. After reconnecting the USB and power cords, install the cartridges as you normally would. The printer should treat them as new.
Oct 22, 2011 | HP Officejet 5610 All-In-One InkJet...
5610 hp printer shows insert cartridge on right when i changed to new cartridges. they are new cartridges and are inserted correctly
try this
- Remove the cartridge that is not working. - look for a lint free cloth "coffee filter" then dump w/ water - clean the copper contacts of the cartridge - make sure that the air vent is open; if not pinch it a bit - remove all the cartridges - check if there are are inks spills - use lint free cloth to clean the part where you are have trouble with - install the inks again - run alignment and clean cartridges on the panel
if still nothing works, call HP tech support and ask for replacement of the ink.
note: they will do the same steps again for troubleshooting and documentations. the reason why this happens: - that the copper contact does not touch each other - cartridge air vent is sealed - not an orig HP ink - Print head problem, needs cleaning
Jun 05, 2011 | HP Officejet 5610 All-In-One InkJet...
Printer says-
Remove the Cartridge.
Clean the Electrical ( golden ) contacts using lint free cloth.
Clean the Contacts inside the Cartridge slot.
Put then back in the Printer and follow the instructions on the Printer Screen.
If this does not resolve.. Contact HP Support if you are using Genuine HP Cartridge for more Help.
Jun 16, 2010 | HP Officejet 5610 All-In-One InkJet...
I just added new ink in my HP Officejet 5610. The
check expire date
your have clog printhead try cleaning from printer menu
and if it still not alligne s*ck the old ink from the cartridge and refill it with fresh ink
check here how
utube.png You-Tube video "sOriLrbuBao" placeholder (do not delete) utube.png
utube.png You-Tube video "II9gpIXs_lE&feature=related" placeholder (do not delete) utube.png
Feb 14, 2010 | HP Officejet 5610 All-In-One InkJet...
Hi, I replaced the black ink cartridge on my HP Officejet 5610-All-in-One successfully but the Tri-color cartridge (HP 57) clicks into place but the machine won't accept it and says Error. Please advise,...
1.check the tri color remove it from the printer then use clean cloth to clean the mess on memory chip like dust.
2. put it back into printer then try a sample page to print
3. if still don't work re-instal the software to refresh all cartridges u replace
Feb 10, 2010 | HP Officejet 5610 All-In-One InkJet...
Cartridge Error - HP Officejet 5610 - All-in-One
Are you using a factory new ink cartridge?
Then your ink cartridges are replaceable under the product warranty.
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Nov 05, 2009 | HP Officejet 5610 All-In-One InkJet...
Troubleshooting a HP Officejet 5610 All-In-One InkJet Printer. Installed new ink cartridge but it's still acting like its out of ink ie, spotty printing. Suggestions?
50% or stronger isopropyl works well as a solvent, 91% dries very quickly. Try cleaning both the contact-film surface of the ink cartridge and the print-head (carriage, actually) in the printer with a lint-free cloth or swab and solvent (swabs reach to the carriage contacts better) CAREFULLY. Clean the print head on the cartridge itself by pressing straight on, not rubbing back and forth, with a lint-free cloth and solvent. Use the HP print head cleaner program first, then check alignment with HP's program, then print a test page. Is this not exactly what the help file on maintenance tells you?
Oct 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Says that I need ink even though I just replaced it
Replace all the ink cartridges??????? If this is HP's idea of how to sell more ink my printer will be floating down the Ohio River very shortly.
May 21, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Cartridge error
when the printer shows cartridge error that means. 1)the cartridges r either faulty .it can be 1 out of 2 cartridges or may be both the cartridges faulty.if this is the case replace the cartridges. 2)it could also be the case that cartridge is not fitted properly if this the case remove the cartridge and reinsert them properly. 3)it could also happen if there is dirt on the printer and cartridge circuit.if this is the caee remove the cartridges and clean both the printer and cartridge circuit.and then reinsert and check.
Nov 30, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
167 people viewed this question
Ben Johnson
