Question about Husqvarna Viking 1
Husqvarna/Viking #1+ embroidery unit disengages when attempting to sew.
The embroidery unit slides into place and clicks loosely into its detent. The hoop is then installed, fabric feed is disengaged, presser foot is lowered and embroidery is attempted. As soon as sewing commences, the embroidery unit snaps out of its detent and shifts to the left about 1/4 inch.
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Suggest that it be serviced and cleaned by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
My machine does not recognize that the embroidery unit is attached. It keeps saying attach embroidery unit. Has anyone had this problem
What make and model of sewing machine do you have? I have seen this problem with a Husqvarna Viking Designer I (or similar older Viking machine). In that case, the problem was corrosion on the contacts between the embroidery unit and the sewing machine. The solution was to use an electronic contact cleaner to clean the contacts; this is one product: http://www.amazon.com/CRC-05101-QD-Electronic-Cleaner/dp/B000CCMLD0 . Make sure that the machine is unplugged. Spray the contact cleaner on the contacts. (In some cases, you should then connect the embroidery unit to the machine and remove it a few times.) Allow the product to dry before you plug in the sewing machine again.
In another case, the solution was actually easier. The owner had two similar embroidery machines. She managed to mix up which embroidery unit went with which sewing machine. Neither embroidery unit could be properly seated on the machine that she attempting to use it with. Once the embroidery unit was paired with the correct machine, both pairs worked.
I hope this helps.
Aug 03, 2015 | Sewing Machines
Upgrade it to rev 1.7
if it is an electronic unit with a os program then the manual should show where to hook up a usb cable so that you can down load the new version from the web site. from your computer.
May 10, 2015 | Husqvarna Sewing Machines
I the floppy discs that control my Designer 1 embroidery machine
You can have replacement discs ordered from Husqvarna Viking. Visit an authorized Husqvarna Viking dealer for them to order the replacement discs. However, you might luck out and they have some already on hand from a scrapped machine or a trade-in. You can find your nearest dealer by visiting the Husqvarna Viking website - http://www.husqvarnaviking.com and clicking on dealer link down the left side of the page.
Good luck.
Dec 29, 2009 | Husqvarna Designer I
When I sew with the regular portion of my Designer One, all is fine. I've been using the embroidery attachment and when I embroidery a simple design, the top looks great, but the bobbin thread is sooo taut...
The bobbin tension sounds ok if regular sewing is ok. The upper tension unit may be the culprit in that there are loose threads or fluff causing the discs not to tighten enough for embroidery. The best solution is to have it serviced by an authorized husqvarna viking dealer. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Oct 30, 2009 | Husqvarna Designer I
Screen is frozen
Remove the embroidery unit and see will come on then. If not, it is probably the PC board. If it does come back on, it may be the embroidery unit or the connection. Take to authorized Husqvarna Viking dealer for service or have them send it to Husqvarna Viking (SVP) Technical Service Department for repair. A list of authorized Husqvarna Viking dealers can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Feb 26, 2009 | Husqvarna Designer I
Husqvarna Rose embroidery unit stopping mid picture.
Could be the design you're trying to stitch out is eroded. Try rewriting the design to the card and see if that helps. If not, take your machine along with the embroidery unit, peddle, hoops, etc. to your tech for a once over. It may just need an adjustment.
Jan 02, 2009 | Husqvarna Rose
Embroidery stick
Four questions:
What model Husqvarna sewing machine are you using?
Are you using a Husqvarna formatted USB stick?
Is the embroidery unit attached when you put in the stick?
Is your machine using the latest version of its software?
I might be able to give some more specific help once I know the answers to the above.
Pamsquilt
Oct 06, 2008 | Husqvarna Viking 1
Finding affordable Box and Card that will work with Viking 1+
You will need a keypad card that goes along with one of the original Husqvarna embroidery cards. This keypad gives you the controls for using the embroidery unit and selecting your designs.
Jan 29, 2008 | Husqvarna Viking 1
Sewing Machines Logo
140 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
