Question about Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
Chuck fell off te25 hilti hammer drill - Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
5 Suggested Answers
  • 61 Answers
SOURCE: Cordless Hammer Drill Sfh 151 A 2.0Ah: Hi, How do you change the chuck on the Hilti SF 15...
Hi. open the chuck to the max. inside the chuck you will see a screw. remove it. put the drill in reverse. hold the chuck. a vice may be needed. pull the trigger. this may work, however in my experience, they are very tricky to get off. I have never had a faulty chuck but have had many faulty gearboxes. i have had to buy ney chuck to fit with the new gearboxes because i couldn't get the good chuck of the damaged gear box. good luck.
Posted on Jun 06, 2010
  • 123 Answers
SOURCE: te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Posted on Jul 23, 2010
  • 123 Answers
SOURCE: How do i replace the jacob chuck on a hilti hammer
Open the jaws of the chuck all the way open. Inside the chuck you will see a slotted screw. Use a large flat head screw driver and remove screw. It will have left handed threads.
After you remove the screw put the end of the chuck in a vise where the 6 flats sides are. Put the drill in low gear and reverse. Hold tight and turn on the drill. This should run the chuck right off the spindle.
Posted on Aug 08, 2010
rowdy45176
  • 2176 Answers
SOURCE: The chuck on my Hilti TE 24 hammer drill keeps
the header list 2 different drills, if yur chuck has a colllar with a quick release, I would suggest thoroughly cleaning and then using a lubricant, usually there are steel balls that lock into detents in the spindle and they might be stuck the collar should move freely.
Posted on Sep 25, 2010
It has broken chuck slot, need to be replaced
You can purchase replacement chucks from Hilti. 800-879-8000. Just put the end of the chuck in the palm of your hand. with your fingers pull the sleeve towards the palm of your hand. Then just pull the chuck off.
Aug 07, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
I nide a chuck for a hilti model te 805 chiping hamer
That chuck is not just one piece. If in the U S contact Hilti @ 1 800 879 8000
Jan 20, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Chuck fell off!
You did not state which model you had but normally on Hilti drills with a removable chuck you just put the nose of the chuck in the palm of your hand. Take your fingers and pull back the sleeve. Slide it back on the guide tube and then turn it until it catches. If that does not work then something is wrong with your chuck.
Nov 14, 2010 | Hilti Drills
Te70 hilti hammer drill
Jul 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
How do i replace the jacob chuck on a hilti hammer drill?
Jun 28, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
How to remove sda cuck from hilti te2 110v drill
Manual for Hilti Te2 is here.
Per Page 11, "Pull the chuck release ring towards the front and remove
the chuck completely. When fitting the chuck, pull the
release ring towards the front and hold it in this position.
Push the chuck onto the guide tube as far as it will
go and release the ring. Rotate the chuck until it engages
and the ring snaps back into its original position |3|. The
TE-C interchangeable chuck or quick-release interchangeable
chuck may be tited to the TE 2-M with chuck
interface |2|."
If this helps, please vote. Thanks!
Jun 14, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
May 05, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
Have a te6c and the chuck fell off- how to put it back on? looks like may require a large vise to press it on?? phil
pull back on the collar of the chuck and slide it on and then release the collar and turn till it locks onto the spindle.
Oct 01, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C Logo
290 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
