Question about Morphy Richards Kitchen Appliances - Others
My kettle produces a strong smell of fish as the water comes to a boil. The water, however, tastes normal. What is tha cause of this?
I have tried cleaning the kettle by boiling water and vinegar together but it didn't help.
4 Suggested Answers
  • 274 Answers
SOURCE: new kettle breville
There's several home remedies you can try: Try 50% "White Vinegar", 50% Hot Water or 2 Denture tablets in warm water over night or Baking soda in warm water. These remove the alkaline, minerals, and nitrates that build up on the surface. There is even a commercial product you can use to clean it. I can't recall the name but look in any supermarket, you should be able to locate it.
Posted on Sep 11, 2007
  • 417 Answers
SOURCE: smell and taste from water
It must be the kettle causing the problem from what you say. If th e kettle is new the problem should reduce with use but if it is old it will get worse (possibbly due to rubber washers/seals perishing)
Posted on Oct 17, 2008
  • 78 Answers
SOURCE: Strong metal taste, how do I get rid of it.
Professional chefs face this problem many times over with their stainless steel wares. Fill the coffee pot with water. Add a tbs of bleach. Let set for 2 hours. See if that helps. If it doesn't, please let me know.
Posted on Oct 20, 2009
How do i get rid of a taste when making a brew
Water and white vinegar will descale your kettle which may be causing the taste. Follow these instructions:
http://www.topcleaningsecrets.com/house/kitchen/how-to-clean-an-electric-kettle.html
Jan 19, 2015 | Kitchen Appliances - Others
Ibought a jug kettle a while ago for a spare i boiled it out twice but we get an awful taste out of it can you give any ideas how to get rid of it please
Try washing it out with hot water with soda in it
I had something similar with the fridge and washed the smell away doing this
Aug 17, 2014 | Kitchen Appliances - Others
Russell hobbs kettle
You will need to first shock that kettle first bold hot water then remove it and replace with very cold or ice water. The smell like plastic is brought by the Plastic which over heats and somehow weakens to a point of melting thus releasing a smell into your water, Shocking the kettle would help if not then you will need to buy another kettle as that one might not be original or just wasn't tested for regularities and standards.
Sep 21, 2012 | Russell Hobbs Kitchen Appliances - Others
We have a sunbeam peace and quiet kettle ke7500s it is approx 3months old. When we reboil the water there's always a tainted water taste in the tea and coffee .The taste is so bad we tip out the hot...
As you know friend, some water when it is boiled it really taste bad so I suggest use a water purifier to filter other out dirt, dust, other particles in a water street supply. Sure when you drink the water (not boiled) it doesn't taste bad, that's normal because we can't distinguish it easily. Also try to clean your kettle using baking soda it will eliminate tainted taste.
I hope my advice help you with your problem.
Mar 23, 2011 | Microwave Ovens
Why does the water boiled in this kettle smell and taste chemically? Any boiled in a plastic kettle in my home is fine.
hello,
the chemical taste of smell from your kettle means that the element in the kettle which provide heat to boiled the water has gone bad due to over heating
this occur when there is shortage of water level in the kettle when the power supply is on
to fix up this problem of smell and chemical taste in your boiled water you will have to make a change of the element (heater)because it has gone bad you can get a replacement of it in the store .
thank you and thanks for using fixya.
Jun 01, 2010 | Morphy Richards 43072 Cordless Electric...
Awful smell and taste to water boiled in a stainless steel kettl
I have the same problem. Noticed it was in two different pots. The comment number one must be correct because I only use VERY high alkaline water to boil my foods. I had a feeling it was my water. So interesting! I will clean it w white vinegar and see if the smell goes away. SAME weird chemical smell- turns your stomach.
May 25, 2010 | Kitchen Appliances - Others
New kettle leaves a metalic tast to water after boiling.
Try different water. If you use tap water normally, buy a jug of water at the store. The pH may be wrong (particularly if it is too low) and leeching metal from the kettle. Good luck.
Jan 05, 2010 | Microwave Ovens
Strong metal taste, how do I get rid of it. Coffee tastes terrible with very strong metal taste. I have boiled kettle about 8 times, but am unable to get rid of bad taste.
Oct 20, 2009 | Breville SK500XL Stainless Steel Cordless...
Smell and taste from water after it has been boiled in kettle. Water from tap, or boiled in a pot has no taste or smell. We are ina soft water area and have no limescale. anyone else complained?
Oct 17, 2008 | Le Creuset Kone Electric Kettle
Kitchen Appliances - Others Logo
2,271 people viewed this question
Top Morphy Richards Kitchen Appliances - Others Experts
Oloyede Monsuru
Mike
Are you a Morphy Richards Kitchen Appliances - Other Expert? Answer questions, earn points and help others
