Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Konica malfunction code C-12CO - Konica Minolta bizhub 350 All-In-One Laser Printer
3 Suggested Answers
taminol
  • 62 Answers
SOURCE: Malfunction Detected code C-12CB konica Minolta
Hi bellotasuelt,
I can't find any reference to that code in the Bizhub C250 Service Maunual.
Having said that, all C-11xx codes relate to the finisher/sorter.
Try opening and closing it. Have a general look in the finisher for jammed paper.
Make sure nothing is obstructing the unit from moving.
Sorry I can't be more specific.
Good luck.
Posted on Jan 29, 2010
djklermund
  • 3 Answers
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
Posted on Oct 18, 2009
Di550 error code
1. Run "Hard Disk Format" selected in the following sequence: Tech. Rep.
Mode  Function  Image Memory.
2. If the same malfunction persists, change Hard Disk Drive.
3. If the malfunction is detected a third time, change Memory Board.
service mode :meter count, stop 00 stop 01
Jan 22, 2014 | Konica Minolta Office Equipment & Supplies
C 1038
Open the front door, up left small access cover remove and push trouble reset button. Once reset the malfunction and turn OFF and ON the Power Switch. If the same malfunction is still detected, check cables for proper connection and, if they are okay, change PWB-B. If you can find one, quite old machine, a legacy Minolta, now Konica MInolta
Mar 04, 2013 | Genuine Konica Minolta Konica Minolta Di...
Error c-0200
konica minolta bizhub malfunction detected error code c-0200
Sep 01, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Error code c2152
good to
Imax Konica Minolta C451 Bizhub
I have a problem is the cod C2151 what to do Thanks
Sep 24, 2009 | Konica Minolta bizhub C450P Laser Printer
Malfunction C-0060
scaner unit in copier is bamotor scanet or original sensor. change or clean sensor and motor. clean the carid cable in the scaner fuction. im indonesian. not good language english
May 19, 2009 | Konica Minolta Office Equipment & Supplies
Konica 8031 Malfunction Code C-0990
http://www.pressa.net/info/?id=34
This page says, that this code is displayed on "Main tray up problem".
I suppose they didn't change the codes that much, so its possible that you can work with this one...
Apr 02, 2008 | Konica Office Equipment & Supplies
Copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Feb 10, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta biz hub c350 malfunction code c-0b4c
C0B4C Finishing option Exit Motor malfunction
Try reboot holding utility key down and do trouble reset, if it doesn't help then there is something wrong with exit motor, call for service
Dec 06, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
133 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
