I have a Canon Pixma MP830. I had a paper jam earlier today. I have been unable to clear the jam. I have carefully pulled out any paper I could see. I have turned it off and on but the movable ink station seems to be blocked.
    Master:
  • 505 Answers
Take the printer cartridge out. Make sure there is no dirt or small piece of paper which is blocking the ink station from moving. Clean it with soft cloth and clear the dirt with small pin.
Put the cartridge back and turn on the printer. This should help in making the ink station move.
Please let me know if it worked.
Thanks.
Posted on Oct 28, 2008
  • 6,487 Answers
There's a possibility that there's still some foreign object inside your printer and you may need to open it up and check again the inside part of the printer for any foreign object there tha is causing this problem.....
I HAVE A CANON PIXMA MP830 INK JET PRINTER WHICH HAS A PAPER JAM CAN YOU HELP
Here are the basic steps that can resolve your issue.
- Paper jam in the Paper feeder or in the output slot
pull out the paper slowly, if the paper tears open the printer cover(scanning unit) and remove the paper (careful not to touch any printer components) after removing the paper restart the printer, then redo the printing process.
-Paper jam inside the machine
Open the rear cover, if you seen the paper remove it, then close the back cover then restart the printer and redo the printing process, if your unable to get the paper from the rear cover, open the casette infront of the printer and slowly pull out the paper, return the casette and restart the machine..
If your still unable to get the paper,
remove the casette, stand the machine with the left side on the buttom (make sure its not the right side) pull out the paper while pulling the green cover toward you, return the casette, restart the machine and redo the printing.
If your having difficulties or still unable to remove the paper contact the canon support center in your area.
Here is a link where you can see visual step by step procedures.
I hope this will help you a lot.
Thank you for choosing fixya.
Mar 03, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Hi!! I have the error 6A00 in my canon pixma mp830
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 14, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830: Error Code 6A00
Sir,
I think there is a piece of torn paper lodged inside due to carriage is stuck, try to do manually moving the carriage and also blow some compressed air around hoping to clear any foreign objects. Opened top manually. Moved print heads to left. About one inch from the right wall on the floor of printer are two soft spongy rectangular pads sitting in two abutting small trays. With the end of a ballpoint pen, pulled the right tray toward the front of the printer and the whole assembly snapped into place.
Thanks Good Luck
Sep 14, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp 830 getting error 5000
Canon site if the link does not work just go to canon.com -> support-> select Multifinction --> Inkjet --> Pixma MP830
Then type in - error code 5000 - (Leave off the " - "
Select #3 - ERROR LCD: Error code (5xxx through 9xxx) appears on the display -
1. Press ON/OFF switch to reset the multifunction device
2. Press Stop/Reset and ON/OFF to reset the printer
3. Removing paper jams MP800R / MP830 / MP530
4. The MP830 may require repair
5. Unlock the scanner lock switch (MP800R / MP830)
The links above detail each instruction. If they do not work here then got directly to the Canon Site.
Basically at one point there was a paper jam so clear it and then reset the machine.
Worked for me. Good luck to you :)
Oct 24, 2008 | Office Equipment & Supplies
LCD Error message: Paper output slot. Thye paper is jammed. clear the paper and press OK.
A jam sensor may be stuck or have something stuck on it, causing the machine to think it is jammed. These sensors are normally located where the paper feeds into the printer, and where the paper exits the printer. Try forcing a sheet of paper through the machine in the direction paper normally. feeds. This may free up the jam sensors.
Jul 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Paper jam
My buddy Roy went in to have a look after I was ready to toss the copier, he moved the ink cartridge to the left and there was the paper jam. he used a flashlight and a pair of needlenose pliers to fish out the paper. Checking again there was more paper, that wqs saturated with ink. Clearing all the ripped corners out the display cleared to normal. There not kidding when they say to watch for curled or deformed paper in the feeder tray.....
Thanks Roy, Good Luck
Mar 01, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Pixma mp830
see if you can open a back door on the feed side. sounds like a paper is not feeding properly inside and must be removed.
Would be nice to know the model, make.
Jan 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 paper jam
Your "Best Solution" posted 10/01/07 needs just a little bit more. I followed the directions and saw the jammed paper but couldn't get hold of it. I then called Canon support and they told me that the green plastic can be pulled up and then the paper under it is accessible. I pulled up the green plastic and was able to grab the jammed paper and pull it out. He also told me that the solution could be found in the Canon knowledgebase with a color picture as well.
Sep 27, 2007 | Canon PIXMA MP830 All-In-One InkJet...
jasbo
jasbo
