Question about ASUS Computers & Internet
Asus x53s laptop won't connect to wifi - ASUS Computers & Internet
5 Suggested Answers
shindou
  • 70 Answers
SOURCE: NVIDIA GeForce 9300
Hi!
You can download the drivers from this site: http://www.laptopvideo2go.com/.
Hope this helps..
Posted on Sep 17, 2008
  • 2973 Answers
SOURCE: i have a asus x53s laptop when i boot up
This is a pre-crash stage of Windows. Re-install Windows by following the link given below as a guideline:
Crashed Windows : No Problem
Posted on Jan 19, 2010
  • 116 Answers
SOURCE: I just bought this asus
Change Your Wireless Channel
If you're using a Linksys router, you'll need to browse to the address of your router, which is probably set to http://192.168.1.1 but could be assigned to another address. You can run a quick ipconfig command at the command prompt to check:
In my case the address is different (because I changed it, of course), but what you're looking for is the Default Gateway for your Wireless connection, and then go to http:// in your browser. Enter in the password that you hopefully remember, and head to the Wireless -> Basic Wireless Settings tab.
My router has two separate bands, but your router might just have a single band here. In my case, what I've done is set the 2.4 GHz band to only be used for Wireless-G, and the 5GHz one to Wireless-N only. Since I'm not having any problems with the Wireless-N settings, I've left those on auto.
Where I am having a problem, however, is my Wireless-G devices-so what I've done is chosen channel 9, since it's the only channel that's not being used by any of my neighbors, who are using mostly channels 1 and 6, though a few are using 11 as well.
Channels 1, 6, and 11 are the most common channels to choose, and most routers will use one of them as the default channel-but the general idea is to be as far away from everybody else as you can.
Note: I've also configured my router for 20 MHz only on the 2.4 GHz Wireless-G band, just because that was the only way it would let me choose the standard channel manually.
If you are using a different router, the IP address will generally be the same, but you'll have to figure out how to change the Wireless channel without any screenshot tours. It's usually fairly easy, though, once you know what you're looking for.
Fun Technical notes
Posted on Jul 18, 2011
emb_solution
  • 40 Answers
SOURCE: wifi is on, but the
1. Make sure it is not disabled in device manager.
2. Make sure the WIFI switch is toggled to on
3. Hold down FN + F8 key to toggle wireless on/off
Let me know if any of the above works.
Best regards,
embraced support
www.embracedsolutions.com
Posted on Sep 05, 2011
Ds won't connect to wifi nintendo24 won't for the wii won't connect to the wifi
you need to get wifi at your house before you can use the wifi on the ds
Mar 24, 2013 | Video Game Consoles & Games
I have an Asus X53S, and I'm experiencing charging
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Feb 26, 2013 | Computers & Internet
Won't stay connected to wifi
reinstall your wifi driver downlodelatest driver from internet and use it if work then ok if not then problem is coming from hadware
Feb 04, 2013 | Computers & Internet
I can't have wifi connection
Make a LAN connection and get drivers from here or you can download driver finder program.
Jan 20, 2013 | ASUS Eee PC 1001PX 10.1 Netbook 1.66GHz...
My asus laptop won't turn on and so I have it
may be the wire of the charger has got defect in it. check thoroughly. If your charger is OK it is problem with your motherboard.Replace it to get rid of the problem.
Feb 08, 2012 | ASUS Computers & Internet
Is an Asus Eeepc 701 Linux OS & firfox browser compatible with a wireless N wifi router?
Yes, but the netbook only has a G card, so it won't be able to perate at the higher speed, and you'll have to make sure the router is in Mixed mode.
Sep 02, 2011 | ASUS Eee PC 701 Notebook
I purchased an Asus EeePad Tablet. How can I connect to the Internet and google? The tablet has WiFi.
You need to connect to your wireless router that is connected to the Internet via a cable or DSL modem OR to a Internet cafe WiFi hot spot at a location such as McDonalds, Star Bucks.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Jul 18, 2011 | ASUS Computers & Internet
I have a asus x53s laptop when i boot up
Jan 19, 2010 | ASUS A3H Notebook
NVIDIA GeForce 9300
Hi!
Hope this helps..
Sep 17, 2008 | ASUS A3H Notebook
Computers & Internet Logo
1,392 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
