HP IPAQ hx2000 main battery won't charge
I have an older HP IPAQ hx2000 with Windows 2003 and the main battery won't charge. It works fine as long as it is hooked to the AC charger, but shuts down seconds after it is unplugged. What do I do?
adib
  • 450 Answers
SOURCE: my iPAQ will not charge or turn on ...
Can you get the iPaq hooked up directly to AC power? There's apparently a charging threshhold for badly depleted batteries that the USB port cannot get over.
Posted on Sep 08, 2005
greenwallinc
  • 8 Answers
SOURCE: iPAQ Not Charging from AC Outlet
If you are not using the original chargers it could be the type of charging cable. Not all cables that fit will charge the device correctly.
Posted on Aug 12, 2007
Bogdan
  • 198 Answers
SOURCE: Ipaq 4155 wont turn on, dont charge, dont anything, is totally death
I had some similar experiences with these ipaq's when I was working in a specialised service center. I'll try to give some help or tips through the internet, altrough if i could have seen or diagnosticate these pda's myself it would have been more easier. First of all these problems have 2 main causes. Most of the pda's comply with one of them, it is very rare that a pda will develop this problem by having both causes.
The first cause is the hardware one. A component called the main voltage convertor is broken. It's a small chip that uses the voltage given by the main battery to convert it's value to various tensions required by some of the components on the pda's main board. If some sub-parts of this chip fails to work, the result will appear as the problem you face, In this case there isn't much to do. Most service centers will replace the whole mainboard because that particular chip is very hard to find as a replacement and difficult to desolder from the board.
The second cause could be a major firmware / ROM memory corruption. These things can happen out from nowhere. In my time working for service centers I've tried to isolate a pattern for this problem but without much succes. However it seems that most of these problem tend to appear durring charging cicles due to power spikes or drops on the main AC voltage supplied to the charger. This is only a supposition, I'm not sure yet on this cause. What to do here? Well this problems are fixable but first of all you must be sure that this is a software problem, not a hardware one. So let's diagnosticate some things.
Try to charge the pda. Ignore any lights or beeps or whatever your pda is showing on the screen. As long as the charger is connected the charging process is based on the most primary charging circuits on the pda's motherboard. If the pda is not charging or cannot hold any charge (when you unplug it the screen fades away or it simply doesn't do anything else) maybe that circuit is broken (this is a a sign of serious hardware problems ) or maybe the battery is to old/weak. Batteries don't die out of nowhere, if you remember your pda to work and have some 2-3 hours of standby time it's imposible that now, suddently the battery has drained out so much that even if charged it can't hold out at least 30 min.
So we will assume that you charged the pda for at least 2-3 hours and you see some sign that the battery is working. The next step is crucial. TRY TO PUT THE PDA IN BOOTLOADER MODE. You will achieve this by pressing (and keep them pressed!) the following buttons : power, the far left and right buttons near the control pad (joystick or whatever some people call it) and reset button. You may need another person to help you press these buttons. the order should be the following (first power, then the 2 keys, then reset button for as long as it takes to enter bootloader mode). YOU SHOULD SEE A WHITE SCREEN WITH THE HP LOGO.
If your pda fails to do that, there is nothing more you can do to restore it in a DIY fashion. Probably the bootloader is corrupted or you have a hardware fault. Only a specialised HP service center can help you now. In most cases this will end up with a motherboard replacement.
If your pda does that, then there is a chance to fix it. We will need to probe the bootloader for direct data acces. This is needed for having the ROM memory (and operating system) rewritten. A small program called Mtty will be required to access the bootloader via an usb link.
Please make this tests first and then reply with your results. If anyone of you is in situation #2 there may be a chance.
Posted on Feb 10, 2008
SOURCE: iPAQ hx 2110
does it matter if usb charging is enabled? just looked through the menus and it has a slow/fast charge option etc?
Posted on Dec 21, 2008
  • 16 Answers
SOURCE: I just got a hp ipaq 3100 and it won't charge.It
the battery is not holding it charge so id recommend new battery
Posted on Mar 04, 2009
Unlock code hp hx2795b
If you mean the hdd or system is locked, contact the manufacturer with the code and they may be able to help.
Oct 29, 2016 | HP Computers & Internet
Have had a HP ipaq rx1950 for about 2 years and last month it has stopped charging the battery. I bought 3 batteries and each one does not charge. I put these batteries in another person's ipaq and...
its just 3 things.
1; battery
2: charge regulator on the device.
3: power pack
one is bad.
so its not battery, now its #2 or #3
seen the regulator is toasted
very common
why not buy as used spark same device, and mix part to get good
or ditch it and upgrade,
Mar 12, 2017 | HP iPAQ rx1950 Pocket PC
Hello, I have HP iPAQ hx2000. It was present from my cousin. she bought it in London. It was working properly befor. After about year she gave it to me. But by all the year it was shut down. I live in...
sounds like she fried the power adapter, i know in the US 115volts on a normal wall oulet, outside of the US its 250/225?volts
get a new adapter, if your pc still works that is....
Sep 04, 2009 | HP Computers & Internet
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
HP iPAQ 2215 sync problems with Vista and Windows Mobile 6.1
I've decided to get a smartphone with Windows Mobile 6.1, so this issue has been "solved"
Feb 08, 2009 | HP iPAQ 612C Smartphone
My hp ipaq hx2495b screen is orange and hard to read
a relic of year 2004, now 14 years old, most are in the trash now.!
i presume you ask here is because HP wont answer on this relic device? (happens) or no shop shop in town will touch it? (sure)
or the labor to fix it is 10x value (it is!) or more !
it needs repair, so....
you have no spare parts
HP has no spare parts
only on EBAY can you find used parts.
why not just guess. like this. (I'd not but....)
1: new battery main (then charge it) fully! per manual. .
2: NEW hidden battery inside.
3: new screen (or used) on fleabay
the free manual. (free)
https://www.manualslib.com/manual/72006/Hp-Ipaq-Hx2000.html
Jan 08, 2018 | HP iPAQ HX2400 Pocket PC
Up grade to Windows Mobil 2003
Depends on the model of ipaq.
Jul 20, 2008 | HP iPAQ H5550 Pocket PC
HP ipaq hx 2000 pocket PC
It could be, or it could be something to do with configuration. I researched this earlier, and this CF card problem is something that has come up for several years now, on several different devices, but usually with the Windows OS 2003 or later. Here's a basic summary of the recommendations I found :
- Soft reset the device, using the reset button (on the hx2000 series, that's recessed on the left side of the bottom of the device, and you can press it with the stylus). This sometimes solves the problem, but you will often find that it recurs afterwards. It's more of a short term fix than a permanent one.
- Back up the CF card's data, then reformat it and make sure that it is FAT32. This is the most universally recognized file format and has the least problems.
- If this doesn't work, then a last resort option would be to try backing up your device's software and performing a hard reset to return the device to its factory defaults. Make sure you have everything you want backed up before you do this, though, as it will lose all programs and files that you don't have stored. To perform a hard reset on the hx2000 series :
1. Press and hold down the Calendar and iTask buttons.
2. While holding the buttons, press the stylus against the soft reset button and hold it there for about seconds.
3. Once the screen begins to fade, first release the Calendar and iTask buttons, then release the stylus from the reset button. (If you hold all three for more than two seconds, the device will disconnect itself from the battery and power off - apparently if this happens you can simply push the reset button again, or you can plug it into an AC adapter.)
The device should now begin to restart. After this, you need to select to restore the factory settings. Go to Start --> Programs --> File Explorer --> My Device, then open the iPaq File Store. In there, select all files, and then delete them.
If this doesn't work after restoring it to the factory defaults, then I think you may well be stuck with a faulty flash slot. However, let's hope it doesn't come to that - good luck with resolving this problem!
May 11, 2008 | Computers & Internet
I recently purchased 2nd hand a HP ipaq hx2000 pocket PC. It all appears to function ok apart from it will not recognise any compact flash card when I insert it into the slot. I have tried several CF...
Have you tried using an SD card? The hx2000 is supposed to support SD cards and CompactFlash Type II memory cards. If it doesn't respond, it's possible that your second-hand device simply has a faulty card slot.
May 10, 2008 | Computers & Internet
HP IPAQ hx2000
ipaq cannot detect the keyboard
Oct 23, 2007 | HP FA118AABA - HP Compaq iPAQ Foldable...
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
