Clearing a administrator password
I tried removing the cmos bat. already,but that didn't work,I only got a different screen with a "key logo",saying to enter the code.And what and how do I "flash the Bios "as you said?
  • sickning00 Oct 28, 2008
    Ok I found out it's the "Power On" password I've forgotten,can anybody help me to fix this problem,please?
    Scholar:
  • 136 Answers
Well, this is a procedure which requires patience, a very reliable AC socket and downloading the firmware and the flashing utility from the motherboards manufacturer.
First thing is to find the exact model. The new BIOS must be either the same version as yours or an update, and the manufacturer should have it available in their website.
But before you do that, when you removed the battery, were all power sources disconnected? AC and battery? If not, the CMOS was still beeing fed.
Posted on Oct 28, 2008
Remove password from acer laptops
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to set user password or supervisor password you can change or remove your password from there
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard.
Another way is to reset the clear CMOS jumper on the motherboard itself.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in
Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
Reboot the computer into Safe Mode
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears.
Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system.
Press ENTER. Shortly, the welcome screen should show.
Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control user passwords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
In User Accounts select the account you wish to change the password for, click change password and then enter the new password or click remove the password to remove the password from the account.
If all else fails you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard
Many RTC's require an external battery. If your RTC is one of this type you can clear the BIOS password just by unsocketing the RTC and reseating it
Hope it helps
Apr 22, 2012 | Intel Desktop Board D845PEBT2 Motherboard
Password reset dell latitude C610, BIOS A16
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
When logging into Safe Mode you should be prompted with an option to what account you wish to use. Select the Administrator account. If prompted for a password try pressing Enter on the keyboard for no password. If this does not work, try other passwords you may have used. If you're unable to log into the Administrator account skip to the next suggestion.
Once you've logged into the Administrator account open Control Panel and User Accounts.
In User Accounts select the account you wish to change the password for, click change password and then enter the new password or click remove the password to remove the password from the account. Hope this helps you
Oct 11, 2011 | Dell Computers & Internet
Need the bios password on my gateway solo 9500
also
Oct 04, 2011 | Axiom Audio Axiom 40GB for Gateway Solo...
Clear cmos
if you want to reset your password or your cmos
Restart your computer during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
if this fails to remove your password
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
also
if you are not the computer administrator and have not assigned a bios password during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab,click the name of the computer administrator you must have full control can change the password there
hope this helps you
start a windows xp system up n safe mode then click on control panel ten user accounts then the specified user which is password protected and it allows you to change the password without knowing the original one. Restart the computer. Repeatedly press the F8 key until the Advanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show.
Click the Start button. Choose Run and type in "control userpasswords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place. I do not recommend that a password hint be used.
hope this helps you
Sep 29, 2011 | Intel D946GZTS Motherboard
Has hdd password that i cant reminber any way to remove it
also
Sep 24, 2011 | Computers & Internet
Computer would not booy up. now it does but the password does not work
which operating system ant what type of computer??
also
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
also
or if using XP
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show.
hope this helps you
Sep 10, 2011 | Computers & Internet
Need to remove bios password
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. if its a laptop computer this cmos battery might be soldered in
Hope this helps you
Sep 01, 2011 | Computers & Internet
Hey I am trying to log on to my laptop and for some reason FORGOT my password HELP PLS
what operating system and type of computer???
hope this helps you
Aug 27, 2011 | Toshiba Computers & Internet
I need to reset my password on my desktop. I forgot mine
also
what computer and which operating system?
hope this helps you
Aug 25, 2011 | Computers & Internet
Im user of aspire 5536 andI just forgot my window password how stupid I am then tried to use Pcloginnow but thing is not reading cd I could hear the sound but it is not show up just show up window what can...
Hello startac88090,
Part1
"If another person is using the "Computer," or you have more than (1) "Account?"
Log-in using 'their password' or a 'different [Account Password]
"Try {Logging in as an "Type: "Administrator" {No Password}
Part2
"If by chance you didn't 'create a "Supervisor Password?"
"To prevent anyone from changing the configurations in the BIOS / CMOS Setup? than we are 'OK!'
Bootup / Start the computer, and follow these steps:
  • When you hear the computer start-up, there will be a message that flashes very quickly at the bottom of the screen, it will read; Press F2 or F12
  • "Or on other "Computers, the 'Key Sequence may be [F11]..."
  • The area of your attention will be [F2] Button / Key at the top of the keyboard.
  • paul7of9_15.jpg The {F2} Button / Key will open the CMOS / BIOS Setup.
  • Once this screen appear, you will see a 'Listing" of different set-ups.
  • There will be instructions in the [right] Help ? area.
  • You be using the "Arrow Keys" to (Select and Choose Items).
  • In the first screen, there will be on the (right of the screen).
  • Set Supervisor Password = This is the "Password Setting that will prevent anyone from getting into without authorization!
  • This area, that you are in now; to "Change or Configure" CMOS or BIOS setting.
  • Set User Password = This Password is use for "Logins / User Accounts..."
  • "You want to "Reset or Change" the User Password."
  • "Remember to use the [F10 Key] to "Save the Changes."
  • !Important: "If you cannot {Access the CMOS / BIOS setup}; because its "Password Protected too?"
    Part3
    Do the following:
    Turn-off the Computer.
    !Warning: "To prevent injury from "Electical Shock" to the body - "Static Electricity" to equipment."
    • "Unplug the Computer from the {Wall Power - Outlet}!
    • "Disconnect the "AC Adapter from the Computer."
    • Remove the {Lithium Battery}: "The 'Rechargeable Battery'from the Computer.
    • Once you have finish these "Task!"
    *Note: You will need a (very small phillips' screwdriver} to 'open the compartment
    • "You need to remove the CMOS Battery; located in the compartment (underneath the paul7of9_159.jpg Laptop)."
    • Remove the 'CMOS Battery,' for a [minium of 30 minutes].
    • "Replace the "battery!"
    • Now; reconnect, AC Adapter to the Computer = first!
    • Next, plug the AC Adapter into the 'wall power oulet'.
    !Warning: (Do not insert the Lithium Battery in the Computer)
    • Restart the Computer.
    • Do the 'same as above" to get into the [CMOS / BIOS Setup].
    • "Enter, and Save {New User Password}
    • "Press [F10] Button to 'Save."
    • The "Computer will restart!"
    • "Windows Log-on appear."
    • "Log-in with "New Password."
    !Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
    Thank you!" - paul7of9
    Mar 10, 2011 | Acer Computers & Internet
    Computers & Internet Logo
    3,066 people viewed this question
    David Payne
    David Payne
