Question about Dishwashers
20 year old Maytag jetclean model WU482 small hole in front bottom of tub leaks water
Just began leaking yesterday. Puddle on floor. Removed lower panel and found hole about 1/8 inch in diameter. LOVE this dishwasher. Never a bit of trouble before in its 20 or so years. Works like a charm. Noisier than the new ones, but energy efficient no-heat cycles, mechanical dials, cleans wonderfully, love it! Any hope of repairing it? I felt around the rest of the tub base and could find no other rusted spots. Hate to give it up. Hopeless??
    Top Expert:
  • Dishwashers Master
  • 41,875 Answers
At 20 appliance years of age, your Maytag may start leaking like a sieve but you can try patching the hole you see and hoping for another 20 years.
Posted on Jun 19, 2017
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Leaking dishwasher
Are you washing cereal bowls or mixing bowls on the bottom rack? If so, are you placing them in front? Sudden leaks that form huge puddles can often be attributed to improper loading of the dishwasher. Most dishwashers don't have a seal across the tub front. The door closes over it and does a pretty good job of deflecting water back inside the wash cavity. However, if you place bowls in the front on the bottom rack rack they can divert the water right over the tub lip and onto the floor. This is usually the culprit that causes most leaks in dishwashers. Now, if you don't think you have a loading problem, remove the kick panel on the bottom of the dishwasher and check the drain line and pump housing for leaks. Check the door gasket for tears or cracks. Lastly, feel inside the bottom of the door with your hand. You should be able to feel the door insulation. If it is wet, then the problem could be a leak around your soap or rinse-aid dispenser. Depending on the model, some dispensers are mounted to the door with a gasket behind it. Sometimes this gasket can form leaks. I hope this helps.
Posted on Jun 05, 2007
SOURCE: water leak
Mine also started leaking. Element also too hot. Mine has a 20 year warrenty on the tub (which I was NOT aware of) Repairman came today and the whole tub unit and element will be fixed for free! Look in your whirlpool instruction book to see if yours is warrentied. BTW, my dishwasher is only three years old.
Posted on May 03, 2008
gamerfixer07
  • 344 Answers
SOURCE: Dishwasher tub leaks underneath
Hello. Anything is worth trying! But I would recommend epoxy. It works alot better with plastic and rubber items. Most of the leaks I have found in Kenmore machines are at the water pump. You may want to take a peek while it's running, just stay away from the wires!! Thanks!
Posted on Jan 18, 2009
  • 127 Answers
SOURCE: Maytag Dishwasher WU482 had a big puddle of water
a pluged or should i say a partially pluged lower spray arm nozzle redirecting the water spray under the door causing it to spray water in a direction it shouldn't be, causing your leak.
another spray arm could again have a partially pluged spray hole causing water to spray in a direction it shouldn't, or more forcefully so it blows past the door seal..
the float switch could be bad allowing an overfill, but thats usually more substantial.
best of luck,
ttfn
Posted on Oct 25, 2009
Water leaks on passenger floor in my 97 honda civic
I have a 1997 Toyota Camry. Water was collecting on the front PASSENGER floor after a rain. I opened my sunroof and found the front drainage holes (about 1/8" diameter) in the corners of the track sunroof track. They looked clear. I poured a bottle of water in track and watched the result. Sure enough, water started dripping from the right ride of the glove box on to the floor. I started tearing out the interior panels to trace the leak. What I found is that if I poured the bottle of water REALLY slow into the sunroof hole = no leaks. But if I pour it too fast the small 1/8" hole cannot keep up and the track overflows! THAT is where the leak comes from in my car! If water overflows the track, then it makes its way down the column trim, around the glove box and on to the floor.
So I need to help the 1/8" sunroof hole drain faster. I took some 18AWG TFFN electrical wire and jammed it into the hole to help clean it out. I then removed the black plastic mud flap behind my front tire and blew out all of the leaves and rotted debris that where behind that flap. It was packed with junk! I poured more into the 1/8" hole and it seemed to drain quicker.
I hope this information helps others.
Apr 28, 2010 | 1997 Honda Civic
Whenever it rain, water gets into the floor on the
A leaking windscreen,door seal or window seal. Run a garden hose over your car and use baby powder to pin point where the water is in running from.
Apr 20, 2010 | 2006 Ford Taurus
I have water leaking on the passenger floor board when it rains and I can't find were it's coming from.
Check the seal around your interior air filter. The seal can come off at one corner and allow water to run down the firewall and into the passenger side.
Apr 02, 2010 | 2002 Chevrolet Impala
Kitchenaid dishwasher is leaking
depends. take the lower panels off the dishwasher below the door right at the floor. Once this is done you will need a flashlight. If possible lay on the floor with the flashlight and activate the dishwasher. Look for the leak at that point. If it starts leaking in the drain cycle then the impeller is leaking and will need to be replaced. These can be a little pricey so take the model and serial numbers and call an appliance parts house for the cost and it is a little bit of a hassel to replace so only you will know if you want to tackle it yourself or buy a new dishwasher. If is leaking during the rinse cycle then the gasket at the base if the washer (where the motor connects to the dishwasher itself) has gone bad and this is a bugger bear to repair. So it's up to you if you want to repair or replace.
Good luck on repairs Hope I helped you some
Dr Berry
Feb 17, 2010 | Dishwashers
I have a crosley refridgerator approximatly 8 or 9 yrs. old, and it has started leaking water on the floor. We will find a puddle on the floor about every 2 days. Yesterday, (march 24th), We noticed water...
First make sure than the drain hole in the freezer floor is not clog also check the water plastic lines under the front and back of the refrigerator
Mar 25, 2009 | Refrigerators
2001 Chvy van: overheat+water leak/from strange(new?) hole
seems u have a blown head gasket or cracked head!
Mar 18, 2009 | 2001 Chevrolet Astro
Hear the motor running, no water in dishwasher
I thought I would fix this myself - but hubby took a look, wiggled a few wires and said 'there's your problem'. The water valve would not open because a connecting wire was loose. It was the kitten after all - I'd better pop that panel back on.
Feb 07, 2009 | Maytag MDB9600A Jetclean II Built-in...
Water leak on fill cycle
this type of fill mechanism is a pain in the butt and causes many problems. a likely cause is a blackage in the transparant pipe on the rhs of you picture about 1 inch diameter or a little more. recommend you use a dishwasher cleaner 3-4 times as year
Apr 24, 2007 | Bosch 24 in. SHU30 Built-in Dishwasher
Pin hole leak in metal under dishwasher
difficult to weld stainloess steel. another way is to drill out the hole slightly and fit a small nut and bolt with fibre washers
Apr 12, 2007 | KitchenAid 24 in. KUDI02CR Built-in...
Dishwashers Logo
Top Dishwashers Experts
