Question about Roper RAX7244KQ Top Load Washer
Dial turned to the left
Dial was turned to the left by a child, now all cycles are messed up and leaves water in washer after spin cycle.
  • 172 Answers
Hi wittoetr1,
Usually turning the knob to the left will only unscrew the timer knob. If someone has actually turned the timer left it is possible for the contacts inside the timer to bend causing lots of different problems. In this case the timer would need to be replaced. The part number is #3953146
The retail on the part is $98.23 and I do have these available for shipping. I can usually have this at your home anywhere in the United States within 1-2 days. I can ship for no extra charge. One other thing to consider before replacing. It is possible for a item like a child sock to be lodged in the pump and that would cause the water to pump out slowly and cause the problems you describe. I would check the pump first, then consider the timer. You can gain access to the pump by removing the cabinet to the washer. To do this you will see two phillips screws on the back left and right of the control panel., remove these screws and the control panel will flip up, then you can remove the clamps on the left and right sides that hold the cabinet to the back panel. Unplug the lid switch and tilt the cabinet forward and slide it forward. You will then see the pump directly under the tub held on the motor with two clamps. Remove the clamps and hoses but be ready to catch the water in a tub or get a heavy trash bag. Once removed check the pump for any obstructions. Please let me know if this helps and dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Posted on Oct 28, 2008
Why does my top load whirpool washer restart on its own after it finishes the last rinse and spin cycle. It does this on all settings, delicate, normal or heavy.
  1. Turn the washer off.
  2. Set the mode selector dial to NORMAL.
  3. Turn the dial counter clockwise ONE click (LEFT), clockwise THREE clicks (RIGHT), counter clockwise ONE click (LEFT) then clockwise ONE click (RIGHT).
  4. Now press the start button.
  5. All the cycle indicating lights should be illuminated.
  6. Press the Start Stop button once.
  7. Rotate the dial until Rinse, Wash, and Stop light illuminate.
  8. Turn the washer off and unplug it for 10 seconds.
  9. Finally, turn on the washer and it should now be reset.
  10. Run a test load empty to be sure the reset worked. If not perform the reset procedure one more time.
Oct 07, 2016 | Whirlpool Whirpool 3.5cu ft Top Load...
SPEED QUEEN WASHER WON'T ALWAYS AGITATE
see this causes:
Lid switch
test for open or defective use the DVOM OR VOM
Motor coupler
COUPLER wears see the diagram
Belts
broken or worn replace
Clutch
clutch worn replace
Drive motor
bearing and winding burn in one directionor defective by overheating
Drive pulleys
drive pulley frozen or worn replace
Transmission
broken gear or worn
Agitator
can be worn too replace
Jun 21, 2012 | Washing Machines
Washer stopped at the drain cycle Model LSR8233JQ1
Could be either a bad lid switch or a bad water valve.
Set the timer dial to SPIN and turn the machine on.
If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
If it does not fill with COLD water and the screen is clear,replace the water valve.
Oct 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
My Maytag Washer
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
LWH0050P Stackable Compact Washer not spinning
sounds like it could be the transmission. Does the tub turn when you turn the pulley in either direction with your hand? And take the belt off see if the motor turns when you close the lid and turn it on without the belt??
Aug 30, 2008 | Washing Machines
Maytag Atlantis -won't spin
Find out where your filter is & clean it out thoroughly, refit.
May 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Apr 01, 2007 | Asko W6221 Front Load Washer
Roper RAX7244KQ Top Load Washer Logo
96 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
