Question about Nintendo Wii Console
I want to access netflix through my wii. it gives me an error code of 204904. How do i fix it?
4 Suggested Answers
  • 1340 Answers
SOURCE: making connection between WII and internet and Netflix
Sounds like a netflix issue.Contact them with any information you have from them.Here is the link.
http://www.netflix.com/HowItWorks
Posted on Jul 26, 2010
  • 1234 Answers
SOURCE: Trying to connect my Wii
Error Code: 52030 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. If your connection was working previously, try power cycling your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. (Some routers may lose their connection to the Wii console while it is in Standby or turned off for a period of time. Check with your router manufacturer's website for the latest firmware, as there may be an update that will help prevent this issue from occurring in the future.)
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Posted on Aug 25, 2010
  • 1335 Answers
SOURCE: connecting to netflix cannot find the location on
You need to connect to netflix via a PC or a Mac to get the access code for the Wii.
Go to your Wii menu, download and install the Netflix application from within the Wii Shop Channel, and follow the on screen instructions to connect your Wii to your Netflix account.
To connect via Wi-Fi go to the tutorial at
http://www.nintendo.com/games/wifi/wii
Posted on Oct 25, 2010
I can't get connected to Netflix.All that pops up is error code 209826
1 (866) 579-7172
this is Netflix customer support phone number. Basically their are at least 9 way to contact them the link is below. Good luck.
https://gethuman.com/contact/Netflix/more
Dec 30, 2014 | Netflix
Tip
Nintendo Wii Error Code 51330 usually indicates that the WEP/WPA key you set on...
<span><span style="font-weight: bold;">Nintendo Wii Error Code 51330</span> usually indicates that the <span style="font-weight: bold;">WEP/WPA</span> key you set on your Wii is not the correct one to gain access to your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>router</span></a>. <br /><br />When you setup a router for wireless internet, you usually set a WEP key or by default one is set. This is basically a <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>security</span></a> key(<span style="font-weight: bold;">password</span>) that you set so any device that wants to use your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>internet</span></a> has to enter correctly in order to gain access.<br /><br />If you know your router security key, go into your <span style="font-weight: bold;">Wii network settings</span> and make sure it is entered correctly. Click <a href="/../support/r9198848-connect_nintendo_wii_internet">here</a> to read my tech article on how to configure your Wii's network settings. <br /><br />If you do not know the security key of your router, then read my other article by clicking <a href="/../support/r9359087-find_wep_key_router_router_security">here</a>. This article will go over <span style="font-weight: bold;">how to find the router security key</span> or if need be, set one.<br /><br />Be sure to check out my other <span style="font-weight: bold;">Tips</span> by clicking on my profile name and then clicking "<span style="font-weight: bold;">Tips</span>" at the top left. <br /><br />Regards,<br />G33k<br /><br /><br /><br /><br /><br /><br /><span>Keywords</span><br style="font-weight: bold;" /></span><span style="font-weight: bold;">Nintendo Wii Error Code 51330, error </span><span style="font-weight: bold;">51330, Wii </span><span style="font-weight: bold;">51330, Wii error </span><span style="font-weight: bold;">51330, Wii network settings, can't connect Wii to netflix, Wii netflix, Nintendo error code </span><span style="font-weight: bold;">51330, Wii code </span><span style="font-weight: bold;">51330</span>
on Jun 14, 2011 | Nintendo Wii Console
Wii error message 51030
How to fix: Power cycle your router; redo the connection settings on the Wii and try again.
Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this, unplug both the modem and the router from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response.
Erase your old connection settings on the Wii and set up a new one, as your router's settings may have changed since you last connected. We suggest following our guide to create a new connection file and start over.
visit the CBR Tech Solutions
Jan 12, 2014 | Netflix
Trying to hook it with netflix keeps giving me an error code 51420
  1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
  2. Select "Wii Settings".
  3. Click the left arrow to get to Wii System Settings 3
  4. Choose "Wii System Update"
  5. Choose "Yes" to connect to the internet and perform a Wii system update.
This should remove the error and allow you to watch Netflix.
Jul 23, 2011 | Nintendo Wii Console
I downloaded netflix on my computer became a member then downloaded it on my wii and did all the steps, code and everything, but it will not let me connect to it! HELP!!!
First setting to check is does your wi-fi allow Netflix. If that is all good. Then make sure you have every ounce of info right for the wii. It usually requires both the wii and computer to be on at the same time to verify it. For example when you sign into netflix on the wii it will give you a code to input on the computer. When that is done you will then have access to the netflix on the wii. Hope this helps :)
May 06, 2011 | Nintendo Wii Console
I can't get my Netflix Wii thing to connect to the internet Wirelessly. Can you help or at least give me advise? Thank You!
Sorry to hear your having problems with your wii. You can connect the wii via wifi or wired with an adapter. Check out Nintendo's tutorial for instructions on how to do this:
http://us.wii.com/connect/
You basically goto:
Wii Options at the bottom left corner of your home screen, then Wii Settings, Click the right arrow to goto the next page, Click Internet, Click Connection Settings, Click Connection 1, Click Wireless Connection. Click Search for an Access Point. Click OK to view the found access points. Select the Access point for your wireless internet, enter your encryption key, click Ok and then OK again to save settings, and then OK again to test the connection.
If you have done all these setups make sure your selected network and encryption key are correct. If you have an error code search on that error code online.
If you haven't downloaded the netflix channel yet you have to goto the wii store channel and download that first. Then you can link your netflix channel to your netflix account using the on screen instructions when you first start up the netflix channel.
Apr 29, 2011 | Nintendo Video Game Consoles & Games
Connecting to netflix cannot find the location on the Wii how do you hook up to netflix have internet connection but i dont know how to get conected to netflix to get an access code
Oct 25, 2010 | Nintendo Wii Console
Nintendo Wii Console Logo
351 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
