Question about KitchenAid Dishwashers
Kud1021rblo wont start. the start light flashing
The start light blinking and won't start
Macmarkus
  • 2605 Answers
SOURCE: the clean light is blinking and won't go off.
Hello, welcome to FixYa.
I'm going to post the single most common reason for the "clean" light flashing...it is actually an error code as you may or may not know.
What typically happens is poor water circulation preventing the water from heating properly.
To resolve this, I'd start with the following...the wash pump area. You`ll need to follow these steps to clean it.
...Here`s a link which provides a pretty good video of how to do this, these guys aren`t pro`s but the "how to" video is pretty thorough nonetheless.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Once these actions have been performed you'll need to clear the error code. to do so is as followsPress the following buttons in this sequence...
HEATED DRY - NORMAL, HEATED DRY - NORMAL, HEATED DRY - NORMAL
This diagnostic cycle may take approx. 15-20 minutes to complete and may vary depending on the model number. Now allow the unit to proceed through to completion and you should be good to go...unless the heater itself is at fault or a wire has vibrated loose from the heater...those are steps to follow if OR when necessary.
Let me know how you make out or keep me informed if you need further assistance or anything is unclear. If this resolves the issue please take a moment to rate me assistance and a short testimony is appreciated as well
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on Jul 18, 2011
SOURCE: Bike won't start, won't turn over, lights
Changed the FOB battery in mine andf it was the problem, try it!!!
Posted on Jan 23, 2012
tayjoejoe
  • 2194 Answers
SOURCE: 2003 alero security light flashing and won't start
The security light is a visual indication that something in the car's antitheft system is failing. In most GM cars and trucks there is a hidden system that most people are unaware even exists. From the moment you put your key in the ignition, there begins a constant line of communication between your key's security chip or transponder, to the ignition's lock cylinder, and then to the car's TDM. (Theft Deterrent Module) The TDM is what tells your computer that the correct key is being used and that it is "OK" to allow the vehicle to start and run. These 3 parts must be in CONSTANT communication. If the key is in the ignition, then these parts are sending important signals to each other. The security light illuminates when that signal gets broken, even just for a second. When the signal breaks, (normally due to a failing/broken part) the car goes into antitheft mode. The car misinterperates this and thinks its being stolen or hotwired because it is NOT getting that signal from YOUR specific key. There is where the security light turns on and shuts down your vehicle. So basically, if that light is on, your system has some sort of failing part. This can start as an intermittent "no start", to your vehicle not running for days at a time, to the vehicle NEVER starting again. The problem is electrical and computer based, so don't count on an easy reset button, or the problem fixing itself. The hard part is isolating which part is the problem. You can spend a thousand dollars through a mechanic very easily. I have had great luck with bypassing the entire system. This way the problem will never return. It actually CAN'T ever return and can be done yourself at a much cheaper cost. Read through this link very carefully. You'll find alot of information and pictures, along with ways to help you fix this.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Posted on Feb 04, 2012
  • 4977 Answers
SOURCE: 2003 ford ranger theft light blinking and won't start
the anti-theft has been activated and needs to be reset.you may have to get it to a shop that has the tools to do this or go to the dealer to get it done.did you use a key that was cut as a spare and doesn`t have a chip in it.this usually can cause this.also if the wires at the switch break it can activate the anti-theft system.
Posted on Feb 09, 2012
tayjoejoe
  • 2194 Answers
SOURCE: 1999 2dr chevy tahoe security light flashes truck won't start
The security light is a visual indication that something in the car's antitheft system is failing. In most GM cars and trucks there is a hidden system that most people are unaware even exists. From the moment you put your key in the ignition, there begins a constant line of communication between your key's security chip or transponder, to the ignition's lock cylinder, and then to the car's TDM. (Theft Deterrent Module) The TDM is what tells your computer that the correct key is being used and that it is "OK" to allow the vehicle to start and run. These 3 parts must be in CONSTANT communication. If the key is in the ignition, then these parts are sending important signals to each other. The security light illuminates when that signal gets broken, even just for a second. When the signal breaks, (normally due to a failing/broken part) the car goes into antitheft mode. The car misinterperates this and thinks its being stolen or hotwired because it is NOT getting that signal from YOUR specific key. There is where the security light turns on and shuts down your vehicle. So basically, if that light is on, your system has some sort of failing part. This can start as an intermittent "no start", to your vehicle not running for days at a time, to the vehicle NEVER starting again. The problem is electrical and computer based, so don't count on an easy reset button, or the problem fixing itself. The hard part is isolating which part is the problem. You can spend a thousand dollars through a mechanic very easily. I have had great luck with bypassing the entire system. This way the problem will never return. It actually CAN'T ever return because it is eliminated. This can also be done yourself at a much cheaper cost. Read through this link very carefully. You'll find alot of information and pictures, along with ways to help you fix this.
Posted on Jun 26, 2012
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
TV Won't turn on, Has flashing red light.
Flashes of standby light is fault indication. Count it and confirm the number of flashes occurs at one time switch ON. If you wish to get more details about these blinking codes to Toshiba sets, check this link. Pull up older posts there.
Mar 02, 2013 | Toshiba TP50F60/61 TV
Secuity light flashes and car won't start
just turn the swich on let them blink than turn it off take key out thann try it agan
Nov 11, 2012 | 1997 Oldsmobile LSS
Blinking cancel light, had broken element replaced and still won't work and blinking cancel light still flashing
You probably have to replace the latch and strike, as well as a switch that is on the latch assembly. It may only be the switch, but when you have it taken apart it makes sense to replace all three parts. Parts should be available on Amazon.
Sep 12, 2012 | Kitchen and Much More Dishwashers
Notebook won't turn on
my nb500 netbook wont turn on i slamed it shut now wont turn on
Apr 23, 2012 | Toshiba NB500-12X
Won't turn on, light flashed 9 times
the 9 blinks is indicating a panel SOS which means the Panel itself is whats causing the 9 blink error code.
Mar 24, 2012 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Check engine light flashes car won't start
you can get the trouble codes out by turning key on off on off on then watch the check engine light it will flash a number of times n pause this will give you codes to take to the auto parts store n tell them they will know most of them the service writer at the dealer can find the rest (example) blink blink blink pause blink blink =32 there could be several so do it a couple times to make sure you get them right and get them all
Mar 15, 2012 | 1992 Plymouth Acclaim
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
When I try to start car, it won't start and security light blinks. I'v e had to ignition switches put on before and I had a new key made. Car still won,t start.
If any of the gauges are blinking and going haywire and the security light flashing then the instument cluster is faulty.But if it is just the security light flashing then its in the switch.If you only had the switch replaced then you need a new ignition lock cylinder because its worn out.
May 11, 2011 | 1995 Oldsmobile Cutlass Supreme
Dishwashers Logo
29 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
