Question about Sharp Viewcam VL-Z1 Mini DV Digital Camcorder
Camera shuts off
When I turn on the camera, it acts like its on and within a few seconds it turns off. This is doing this after being fully charged.
0 characters
1 Points
Why doesn't it recognize the correct battery?
If your camera do not recognize the original battery, it means some wrong information is stored in its software data, to override this please open the camera take out the small memory backup lithium battery, short the battery contact , after a five minutes connect that battery again.
Mar 02, 2016 | Sony Video Cameras
Sony ccd trv218e
The symptoms you describe suggest the battery will not charge and should be replaced.
Mar 04, 2014 | Video Cameras
My Flip Mino HD camera turns off while recording!
I had the same problem! But I turned it off, stuck a paper clip in the little hole inside the hole at the bottom for 10 seconds, then i held the power button for 5 seconds till it turned on and it works just fine now :)
Nov 18, 2012 | Flip Video Mino Camcorder
Use infolithium battery pack
I believe Shahid is correct... it's probably the pins.. try this... first make sure all switches are off during the entire process (viewfinder pushed in and keeping the LCD closed, try cleaning the pins on the back of the camera with a Q-Tip and Isopropyl alcohol (91% if possible)... leave it a bit damp and push the battery into place several times to clean it's contacts too.. then let everything dry, reconnect the battery and turn it on. The problem will hopefully be all gone.
Apr 29, 2012 | Sony Video Cameras
I've had my ZR90 Mini DV for a couple years. Just stopped working and bought new batteries. I fully charged it and it still won't turn on. What could be the problem
This is usually caused by a failed component in the power circuit within the camera and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
Aug 12, 2010 | Canon ZR90 Mini DV Digital Camcorder
Camcorder will not turn on without being plugged
If the camera is turning on and is able to be used normally while plugged in to an AC wall pack, but not using the battery, there is probably a problem with either the battery or the internal power switch to go from AC to battery.
Check the battery with a voltmeter to insure you have a fully charged battery. It would also be a good idea to use the voltmeter on the camcorders power tabs to make sure the camcorder is passing the correct voltage to the battery. The amount of volts should match the volts on the battery.
If it's a battery issue, batteries plus has a replacement for this camcorder. If not, it's a switch within the camera (software most likely) and there's not much you can do other that try to reload the camcorders firmware if it is available fromt eh Insignia-Products web site.
Hope this helps!
Feb 08, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
I have a sony dcr-dvd108. the battery is fully
it might be battery to used and it's charging quick and loosing power to quick. have tried to change battery for new
Aug 24, 2009 | Sony Handycam DCR-SR300 Camcorder
LCD problem with Sony DCR-SR200
O& ..)& '''ho 7... 007 I see his movies are old and so is your battery. Break down and buy a new and charge it to full capacity replace the battery
Buy the heavy duty isf there is. and when you store it when not in use ut the battery in the freezer. When you want it thaw it out and put a charge to it for a good practice and install
Jul 27, 2009 | Sony Handycam DCR-SR200 Camcorder
Sony DCR-SR290 camcoder- turns off abruptly
ribbon cable located in the rotating lcd is cut. thats why the shut down its grounding it self out. needs to be replaced. real pain though, cable is serpintined around the part that rotates. sony does flat rate for prob. about 250 US
Jun 01, 2009 | Sony Handycam DCR-SR40 Camcorder
Shuts off
It sounds like the battery is flat - I realise that you've probably already thought of this, and charged up the battery, however batteries have a finite life and number of charge cycles they can go through, and may appear to be fully charge (According to the charger, at any rate), but they are unable to hold any decent charge. My suggestion would be to head down to the local camera shop, and ask if you can try a new battery in-store.
Sep 14, 2007 | Quasar VM-L450 Camcorder
Sharp Viewcam VL-Z1 Mini DV Digital Camcorder Logo
14 people viewed this question
Top Sharp Video Cameras Experts
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
