Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Kenmore electric range
Put food in oven, ran errand, when returned lots of smoke and oven very hot. Turned off circuit breaker. Two codes on the stove E3 and F3. Any idea what these mean?
  • Anonymous Mar 30, 2014
    I was using the oven on 350 and then the broiler went on by itself and a F3 code was flashing it was really smoking the smoke alarms went off. The only way to shut it off was to shut the breaker off. When I turned the breaker back on after about 30 minutes the broiler came back on with the stove not even being on.
  • 172 Answers
Hi dlingquilt,
The f3 , e3 code is a faulty oven temperature sensor. If the temperatur sensor has gone bad during mid cycle then you may have overheated the oven aswell. It is never a good idea to leave a oven unattended while in operation. The temperature sensor can be replaced easily and inexpensively.
First off be sure to disconnect the power to the range. If you look inside the oven near the top you will see a little metal probe about the size of a pencil sticking through from the back. That is your temperature probe. It is held inplace by two 1/4 inch screws. You will need to pull the range out and remove the back panel to access the probe. This is a fairly simple repair and the error code should go away once the probe is replaced. If you would like me to ship you one of these I can send it out in the morning. The price is $59.99 shipped to your door. I can ship anywhere in the United States within 1-2 days. good luck to you and please dont forget to rate me.
Mike Anderson (owner)
Anderson Appliance Center
(865)945-3808
mca0824@aol.com
Posted on Oct 28, 2008
    Problem Solver:
  • 7 Answers
Runaway oven temperature, two possible causes. The oven temperature sensor is bad, or the oven control (The oven control has the clock built into it also)
GE Profile 30" slided in range/oven. Ran standard
shut down the power to the machine,disconnect the touchpad ribbon,turn the power back on and let it sit for a day,if the code comes back you have a bad board,if it doesn't come back you have a bad touchpad
Apr 02, 2011 | GE Profile 30" Self-Cleaning Slide-In...
Have a Kenmore Electric Range Model- 790.4671. Ran the self cleaning program. Error occurred at the end of cycle. F10 and F30. Oven will not unlock. Show oven locked and a picture of a lock. Oven is...
Sorry to read about your problem
Your F10 code means Runaway Temperature and f30 means open probe connection. try this and see problem comes back.
1. Unplug the unit or turn the circuit breaker off for 60 seconds.
2. Now, restore the power to the appliance by plugging it back in or turning the circuit breaker back on.
3. Check to see if the error code is still displayed on the range.
Note: General information for resolution to this problem, is based on information provided in question. Contact certified technician if problem persist. Sears Repair 1-800-469-4663
I have tried to help you.Pleas help me by Vote/Rate my response. Thanks.
If you are in the Denver,Co area I can help you out.
Dec 20, 2010 | Kenmore 46713 Stainless Steel Electric...
I have Super capacity ultrabake system electric won't turn off.
I had this with my oven, it just kept getting hotter and hotter. Had to replace the whole control panel. Mine was a Kenmore but I suspect they are similar.
Apr 10, 2010 | KitchenAid KERC607 Electric Kitchen Range
Kenmore Elite Oven/Stove Fire Hazard?
F05 has to do with the self cleaning mechanism. I know it goes with out saying, but sparks and smoke are a bad thing. i would strongly suggest turning off the breaker and calling in a service person.
Smoke means extreme heat or FIRE is melting something..
Please be safe and have it fixed..
Oct 23, 2009 | Kitchen Ranges
Oven gets very hot when all cntrols are turned off
Your electronic oven control has malfunctioned and must be replaced.
Feb 26, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Self clean mode causes a lot of smoke!
If the oven was really dirty, particularly with grease and unsolid food stuffs, then you will see smoke come out.
The self clean features basically incinerates the food residues in the oven. With incineration comes smoke.
If you feel there is a problem with the electrical circuits, then we would recommend that you call an appliance technician to inspect the unit for any faults.
Reply back what you find.
Feb 13, 2009 | Kenmore 96422 / 96424 / 96429 Electric...
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven sparking problem
i think you will find the power cord is burned this happens if it wasnt tightend up properly and gets loose turn the oven breaker off before you pull it out
Jan 24, 2008 | KitchenAid KERC601 Electric Kitchen Range
Oven Heat
THE OVEN SWITCH IS BAD ITS STAYING CLOSED.FAIRLY EASY TO REPLACE AND NOT THAT EXPENSIVE.ANY APPLIANCE STORE CAN ORDER THE PART OR YOU CAN FIND IT ONLINE.
Aug 28, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
170 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
