Washer is on wood floor and when on spin cycle it jumps all around.
  • 94 Answers
Hi pat
try adjusting the feet and use a spirit level to ensure the machine is totally level and this problem should disappear
Posted on Oct 28, 2008
How do I balance a Kenmore 70 series washing machine.
Wood laminate flooring is never a good idea in areas that can get wet often. But, that being said, there should be leveling feet on the washer which should allow you to get it stable on the floor, if that's what your problem is. If your problem is that the washer tends to walk around the room when in the spin cycle, well that is partially due to the fact that washers often vibrate when they spin, especially when spinning large, bulky objects like quilts and comforters, that the feet on the bottom of washer are smooth plastic, and that smooth plastic feet don't stay in one place to well on wood laminate floors.
Mar 04, 2015 | Kenmore Washing Machines
Bosch Exxcel Vario Perfect washer
What You Do is go and get Yourself a Sheet Of Thick Plywood, At Least 3/4", Get Marine Grade because the Glue Will stand up to Water. If you are installing this on a wood floor, you might want to put a few Screws Where you can Screw into a Joist Having the wood Wider than the Washer is a Good Thing, Washers Inherently want to Jump Around, Sounds like your floor is acting a a springboard, you can double up on the Plywood too.....~~*BB
Jan 03, 2018 | Washing Machines
My washing machine keeps getting water in it after the cycle is over. This morning I came in and my empty washer was filled with water and had overflowed onto the floor. Help! There are also times when...
mine also remains wet and soggy, even after the spin cycle. However, I have not, as of yet, (and hopefully won't) begin having overflow problems.
Mine is jumping around the laundry room - as though in an unbalanced cycle. We discovered that one of the "feet" that the washer stands on needs to be adjusted, upward or down, so that the washer stands balanced and evenly. The "foot" does not make contact, and when we turn it to change its height, it just goes in circles without changing height.
Mar 09, 2010 | Whirlpool Washing Machines
How do you keep washer from jumping around during spin cycle? The washer is on one of the Maytag storage stands. It is leveled on a concrete floor but jumps around when on medium or high spin cycle. Any...
first of all if this is a new washer you need to make sure all the shipping straps or bolts are off. one way to find out is to open the door reach and grab on to the tub it supposed to be able to move up down and side to side. if not then the shipping bolts has not been removed.
Nov 05, 2009 | Maytag EPIC MFW9700S Front Load Washer
Can not keep the HE 3 washer from jumping around on the spin cycle. Floor is level and machine is level with legs locked in place. Have lowered leveling legs to the base and locked them tight with the...
these machines can have this problem when placed on a pedestal and/or the floor may be level but not solid. a "bouncy" floor will amplify any movements. remember, these machines are much heavier and spin much faster than top-loaders. just because it doesn't jiggle doesn't mean the floor is level. you may have to brace to floor or foundation somehow
Sep 24, 2009 | Kenmore Elite 45986 Front Load Washer
Wm 2487H. My machine is off balance and shake the house terribly bad. It also has a metalic scraping sound sometimes when the drum spins. I just purchased my LG washer and dryer a couple of months ago. I...
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
Jul 16, 2009 | LG WM2487H Front Load Washer
Unending Heavy Vibration on Spin Cycle - Maytag Neptune
level the machine, if you are on a wood floor it could be the floors fault, you could try using aanti vibration pads.
Feb 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front Load Washer moving around because of the high rpm
if you dont have a weak floor just lock the legs,,,on the legs theres a nut on each leg..your unit came with a little wrench..that fits theses nuts,,,now you have to put unit on spin ,,when you get in highest or fastest spin ..adjust leg nuts than thighten them one at a time all the way up to the base of unit,,you might have to spin on high speed twice ..you will see when unit becomes steady...this wont work as well if you have a wooden floor or a weak floor..onthejob
Jan 31, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool washing machine
Welcome hendrik,
You said, jumping around during spin cycle
How old is your GHW9150 washer?
Usually it is overload or load unbalanced due to uneven load.You must stop the machine and re-distribute the load and or weight!
Here are some Whirlpool reasons for you.
But if nothing helps you may have a mechanical problem to be serviced!
Try these ideas first!
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Washer makes noise or vibrates
Is the washer level?
The washer must be level. The four feet should be properly
installed, and the nuts should be tightened against the
washer cabinet.
As water is drained from the washer, you may hear air being
pulled through the pump. This happens during the end of
draining. It is normal.
Are you washing items with metal snaps, buckles or zippers?
You may hear metal items touching the washer drum. This is
normal.
Is washer installed on a sturdy and solid floor?
Refer to the “Installation Instructions” for flooring
requirements. Noise and vibration may be reduced by placing
a piece of ¾" (19.1 mm) plywood underneath your washer.
The plywood may extend underneath both washer and dryer
to keep them at equal heights.
Let me know If you have any questions and what happens!!!
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
