Question about Sprint Travel Charger PLUS
Turning off 'travel charger Plus"
I cannot seem to turn off my travel charger and it saps the energy.
Travel charger wont charge my phone
IF U CONNECT THE BATTERY PROPERLY DEN ONLY THIRD LIGHT BLINKING UP.
Mar 14, 2014 | Sprint Travel Charger PLUS
I have a go go elite traveller plus , the battery pack will not lift off my scooter it seems to be stuck , i need to replace the batteries
The manual for this scooter is at http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
The closest info I can find is page 14. MOVING AND TRANSPORTING YOUR Easy Travel Elite
6.1. Moving Your Easy Travel Elite in Freewheel Mode when unfolded:
The Freewheel switch (Fig. 1/17) is used for releasing the brake and moving the Easy Travel Elite without operating the motor. Before activating, make sure your Easy Travel Elite is switched on. Turn Freewheel switch to the "freewheel" position and push or pull the Easy Travel Elite manually.
NOTE: The Freewheel mode can only be activated after the battery is in place and the power switch (Fig.9/1) is turned on. Doing otherwise will cause a fault situation indicated by rapid flashing of the Indicator light (Fig. 9/4). See section 4.2.
WARNING: The Freewheel switch should never be engaged on a slope.
CAUTION: The seat back must remain in the upright position.
They seem to assume removal is obvious, I would check any connections from battery to scooter are pulled out and that freewheel mode is not engaged.
Oct 07, 2013 | Pride Mobility Products Go-Go Elite...
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
Doesn't seem to hold charge
right so it's one of two things, either the charger or the batteries,
can you try another charger ?
regards
Dec 18, 2012 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Sap
Be sure when you try this to look in the set menu first and THEN IF USING A CABLE OR SAT BOX FOR SIGNAL look there also as almost all modern boxes have SAP feature as well.
Issue can be either in set (seems not to be) or a BOX.
SD TECH
Apr 25, 2012 | LG 42LG50 42 in. LCD HDTV
How to I disable the SAP function on RCA FLAT 19 INCH screen?
Hello
From its main Menu, surf towards its sound Menu.
By using UP/DOWN buttons of the remote handset, select SAP
SAP (Second Audio Program) (for analog channels only) Plays the
program's audio in a second language, if one is available. The TV displays
the word SAP in the channel banner when you tune to a program that is
broadcast with SAP information. SAP audio is broadcast in mono. SAP is also
used to broadcast a program's audio with descriptions of the video for the
visually impaired. Press the right arrow button to turn SAP on or off.
OK.
Sep 22, 2011 | RCA TruFlat 27F520T 27" TV
How do I turn off the SAP? My mom somehow turned it on and now only gets sound on some of her channels and some in spanish!
U have the original tv remote?Yes.Look for it on the remote for a button that said SAP pushes to turn it off.If u don't have the tv original remote,might could also be turn it off inside the tv internal Menu functions setup,but probally not because the SAP design in tvs are mostly just a SAP button on the tvs original remote design only.Try website like Remotes.com to buy the tv original remote.
May 10, 2011 | Sanyo DS32224 TV
How I increase battery lifebon my enV
turn down the brightness to minimum required ,turn off anything unnesseary that you dont use as bluetooth ,Ir anyting like that, a trick use on my phone which seems to work atleast on my zte blade and my iphone 3GS is to connect the phone to the charger and let it charge to max then i restart the phone and connect the charger again for another hour and the batterylife seems to last one day more
Feb 21, 2011 | LG Pcmicrostore Brand Lg Env Vx 9900...
Sprint Travel Charger PLUS Logo
52 people viewed this question
Top Sprint Cell Phones Experts
TekkiDave
 steve
steve
celticsel
celticsel
Level 1 Expert
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
