Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Howt to unlock my verizon GT704WG router ?
It been a year since my wife left, and i took evey thing down to move but i dont remember our pass for the wireless
  • 628 Answers
SOURCE: Unable to Access GT704WG Router with Laptop
normally there is a small hole for reset to factory default, just put a pin inside...
Other than that, u can also connect using network cable and access the router configuration, inside, u can edit the wireless security keys
Posted on Feb 27, 2009
SOURCE: I bought a GT704WG wireless
Try this link:
http://driverscollection.com/?H=GT704WG&By=Actiontec
It has usb drivers, firmware update, and an ISO CD image of the device's manual.
Posted on Mar 07, 2009
  • 36 Answers
SOURCE: Wireless Connetion Password
by default your routers ip should be 192.168.0.1. type this in the address bar of your web browser. this should bring up your routers page. Navigate your way to the security settings, You should have to login at this point.
User names and passwords can be found here.
http://artofhacking.com/etc/passwd-actiontec.htm
try all of those and see which one lets you in.
now youre in simply choose a type of password WEP etc and create the password (one you will remember). This password will be required when you logon to the network. Windows should then remember the password for you. If you do forget the password which you wont (remember!) you can go back to your routers page and reset everything or just the password. This will take off the password or change it to what you want.
Hope this helped
Bob.
Posted on Mar 12, 2009
  • 161 Answers
SOURCE: passphrase for router?
It means the same thing as password, used for secure wireless.
Posted on Jun 12, 2009
  • 72 Answers
SOURCE: Actiontec (GT704WG) Router wireless access point problem
Please check with the power cable.may be power fluctuation,your power cable get damaged.
After power cable changed,check it once.
Posted on Jan 04, 2010
GT704WG wont pass internet connection
need to configure the router again with PPPOE settings on the router.
Oct 20, 2012 | Actiontec (GT704WG) Router
Hi I want to know on how to setup the verizon Modem/Router I already have a Westell 6100G and i want to upgrade to the new one called Verizon Wireless modem/router model:GT704WG.
Are you on Consumer Verizon DSL? Fair warning if you are using Business Static- the Actiontec is a poor choice due to issues working on a static IP circuit. - I'd use a 6110 and a third party router! However, by default, the only thing you would need to do to setup the modem is go through the activation page when you plug the modem in. If you require an user name and password, it would set that up. Bar any problems, you can contact Verizon technical support since the Actiontec Gateway is fully supported.
Aug 28, 2010 | Actiontec GT704WG Wireless Router...
NO PSN with Actiontec GT704WG Verizon
If you can access the internet it is not a problem with the router. Are you able to access the PSN site but rejected when you enter your credentials?
Feb 04, 2010 | Actiontec GT704WG Wireless Router...
ActionTec GT704WG - can it be "unlocked" ?
hi,
you can try to reset the router itself,there is a little button at the back of it where you can insert a pin or a pencil,make sure that the router is on then press and hold the reset button for one minute then turn it off,then connect it to you ATT and access the firmware,if its still the same,theres no way for you to use it since thats the only way that you can do...
thanks and God Bless
Jan 26, 2010 | Actiontec GT704WG Wireless Router...
Verizon GT704WG modem/router firmware update
You will ahve to log on to the web interface of the modem to find out what the firmware you have is.. See if there is an option to upgrade automatically. Else, look on the Verizon website. That might help
Thanks
Ranjit
Nov 04, 2009 | Computers & Internet
We have actiontec verizon router/modem GT704WG. We have to reboot our computer and router multiple times a day to get the internet to work. It will be working, then all of the sudden it just stops, and we...
I have had this same problem with Qwest using a new iMac and MacBook on the Actiontec modem. Qwest did two things: first we reset the modem which was fairly simple and took only about 5 minutes. However, this fix lasts only a few weeks and it comes back. I have just ordered a new modem since there seems to be a problem with the Actiontec device with the newer high speed internet.
I'd try the reset before doing anything else. Good luck.
Jun 25, 2009 | Actiontec GT704WG Wireless Router...
Passphrase for router?
Jun 12, 2009 | Actiontec GT704WG Wireless Router...
Verizon AGT704WG modem/router conflicts w/ T-Mobile WRTU54G-TM
your Verizon AGT704WG is a gateway, meaning, it's a modem that has router functions (wireless, support for multiple pc's etc.). If you want to connect your T-Mobile wireless router, it would cause certain conflicts with your Verizon 704WG because it is also a wireless router. That's why you can't configure it.
So, if you want to connect your T-Mobile wireless router, you would have to set up your 704WG first to BRIDGE MODE. Which means you would have to disable its routing functions so that only the T-Mobile will function as your router and will not cause any conflict.
If you want to set your GT704WG to bridge mode, follow these steps.
1. Hardwire (connected using ethernet cable) your compuer to your 704WG.
2. On your Internet Explorer or Firefox, type in 192.168.1.1 (default address for your GT704WG). You will then see a verizon page which is the configuration page of your gateway (for newer modems, the background is usually red and black).
3. When prompted, enter username and password. default username is ADMIN, password is PASSWORD or if you've called Verizon tech support, password would be ADMIN (lower case).
4. Click on the MY NETWORK icon from the top bar.
5. Click NETWORK CONNECTIONS from the left navigation box.
6. Click BROADBAND CONNECTIONS (DSL)
7. Under the VC’s section, click the EDIT icon.
8. Select BRIDGE on the PROTOCOL drop down box.
9. Select ROUTED BRIDGE in the BRIDGE MODE field.
10. Click on APPLY and then click on YES to confirm reset.
You would notice that the wireless light on your gt704WG will be off. That's ok because that would indicate that your modem is in bridge mode.
Powercycle (turn off modem for 30 secs and turn it back on) your Actiontec.
That should do it. Good luck.
Apr 20, 2009 | Actiontec GT704WG Wireless Router...
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
24 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
